Good Quality LED Lightbar for 520 Snow Cab
By
r1jakecfd, in Wheel Horse Electrical
Similar Content
By Wheel Horse 3D
Our "Caballo Diablo" ornaments add some extra flair to your customized ornament with the addition of a 12v led and light guiding filament to make the eyes glow or even flash! Available with solid red or flashig red LED, in unfinished, primed, or silver or multi-color painted finish, and in the same horse and head styles as our other custom ornaments. If ordered less than fully finished, the filaments are left long to simplify finishing, and can then be cut off leaving a clean end.They include mounting hardware and a bottom spacer for a clean finished look. Can be ordered here:Wheel Horse "Caballo Diablo" hood ornament
By WHX??
My new to me 520 came without headlights, well ones that worked anyway. All too often when one picks up a new to tractor one ends up having little things that need fixing or un-cobbling or just general maintenance. I guess these little things are the most enjoyable, for me anyway, mountains to conquer. Its not like when you get her home and discover the hydro has no go or the engine smokes like a chimney or the deck needs all three spindles. Its these little things they are most easy and least $$ to fix.
Since neither light worked I went right to the source first and checked the fuses and switch. Quickly discovered that wiggling the spade connectors at the switch at least one head light and one taillight would work. Cleaned the spade connectors and terminals on the switch resolved the intermittent problem but now only one tail light would work. More on the tail end later. A quick ohm & voltage check of both original 4411 sealed beam lamps revealed no one was home, both shot. A quick check of auto parts stores & TSC found that they are quite common anywhere with prices being anywhere between 11 and 18 bucks. In the interest of energy efficiency and better lighting the search was on for led replacements. I found there was no direct led replacement but these PAR36 bulbs were very similar. They are primarily used in low voltage outdoor accent lighting and can be had in many colors, wattages and light output.
I settled on these from the jungle site, about 16 clams a piece, but found them on flea bay and LED light retail places as well. Note the 36 watt equivalent spec. Most if not all 4411 replacements are 35 watts.
I half expected them to be encased in plastic but a nice surprise to find them all glass sealed beam with good quality.
Installation truly plug & play. Fit as perfect as originals.
Best off is this .311 amp draw per light or .625 per set! .
Leaves plenty of room on the 20 amp charge system for more lights, heated steering wheel, heated seat & vest!
More pics when it warms up abit out and I can get some decent night shots.
By shallowwatersailor
Finally it looked like Winter was going to arrive today! This - after the daffodils and cherry blossoms were already blooming. But, the line moved further North and the sleet and rain took over. We were in the 8-12" forecast range but was actually 4-5" of wet, wet snow and a lot of sleet. I have to admit for this snow storm I wish that I had a steel edge on the plow instead of the UHMW.edge. It had a tendency to "ride over" the ice underneath.
I always wait until the county plow comes by before going out to do my neighbors and my driveways. It was nice to have the second cab on the plow tractor considering my other cab never got installed this Winter!. With the 25-30 mph wind blowing I hardly felt the weather while plowing for two hours.
By Patrick J Murphy
I am looking at a Bercomac Universal Cab for my 1992 520-H. I live in eastern Canada and it's very hard to find a used Toro cab.
I would be interested to see if anyone has equiped a Toro with one of these universal cabs.
Thanks
Patrick
