Similar Content
By Xearl
While plowing today the spring popped off . I screwed it back on twice and the last time I had to go searching for it . I'm thinking of welding or brazing ,any thoughts ? I think the ends are cast or steel .
By Xearl
Well we got the snow and halfway down the driveway the augers stopped turning . Well once before the belt came off , not this time . I can turn the auger but the impeller shaft doesn't move . Looking at the parts diagram there are keyways on both gears and I'm hoping one of them sheared off . Has anyone worked on one of these ? I could use some advice on the best way to go about this . I just spent two days with the 518 XI with a plow clearing enough to get out and have enough room for delivery trucks to turn around .
By Xearl
I have a 523dxi with a 2 stage snowblower and I popped the belt off the engine pulley. I don't know how to release enough tension together it back on without taking it apart. Can someone please help me.
By Xearl
I bought this John Deere weight bracket from doc724 and mounted some weights from and old exercise machine . It's 120lbs. This is on my 523DXI .
