Achto 27,920 #176 Posted May 15, 2018 3 minutes ago, Shynon said: When you pull a 12" then you may charge admission I ain't sceerd!! Actually looking forward to trying a 12" behind it. 1 3 Share this post Link to post Share on other sites
WHX?? 49,494 #177 Posted May 15, 2018 Throw your 12 incher in the trailer for AJ's Tom.... Looking at the video on the big screen today didn't look to have a traction problem. One of the things I liked about your selection of that tractor for a plow rig, hydraulics aside, is the 5/8 drive belt.. no problem getting pwer to the rear! Have 'nuff weight out front? 1 Share this post Link to post Share on other sites
Achto 27,920 #178 Posted May 15, 2018 1 minute ago, WHX17 said: Have 'nuff weight out front? Front seemed to stick pretty good, no problem steering or climbing out of a furrow. Could use a little more weight on the left rear, but I will soon have that covered. I was thinking that pulling a double 16" trailer plow might be worth paying to see. But if it only takes a 12" plow to impress Tom, that should be easy enough. 5 Share this post Link to post Share on other sites
Shynon 7,470 #179 Posted May 15, 2018 1 hour ago, Achto said: Front seemed to stick pretty good, no problem steering or climbing out of a furrow. Could use a little more weight on the left rear, but I will soon have that covered. I was thinking that pulling a double 16" trailer plow might be worth paying to see. But if it only takes a 12" plow to impress Tom, that should be easy enough. Bring on the double 16 at Jim's I'm game. 4 Share this post Link to post Share on other sites
Howie 899 #180 Posted May 15, 2018 I have a twelve inch I have pulled behind my Raider 12 in the past. It did fine with it 1 3 Share this post Link to post Share on other sites
dclarke 4,046 #181 Posted May 15, 2018 Outstanding build, Dan! Gotta love this tractor! 2 1 Share this post Link to post Share on other sites
classiccat 548 #182 Posted May 15, 2018 7 hours ago, Achto said: I ain't sceerd!! Actually looking forward to trying a 12" behind it. that thing wasn't even breathing heavy. no problemo! 3 1 Share this post Link to post Share on other sites
PeacemakerJack 10,742 #183 Posted May 15, 2018 I was waiting for you to weigh in on this discussion since you now have a video to look at! Dan’s Raider is definitely a great plow tractor. @Rp.wh Ryan (another local circle buddy) also has one just about like it ‘Cept with manual lift. It will be fun plowing with both those tractors out in the field! Time to start looking for more 12” Brinly’s 3 Share this post Link to post Share on other sites
WHX?? 49,494 #184 Posted May 15, 2018 1 hour ago, dclarke said: Outstanding build, Dan! Gotta love this tractor! You will get to check it out @ AJ's Denny! 2 Share this post Link to post Share on other sites
Shynon 7,470 #185 Posted May 16, 2018 4 hours ago, PeacemakerJack said: Time to start looking for more 12” Brinly’s come on down to the Portage show and I can hook you up. 3 Share this post Link to post Share on other sites
Pullstart 63,205 #187 Posted October 23, 2019 Well worth taking another gander at this one! I was talking with @PeacemakerJack about installing a snow plow pump under the hood to make it look more like a starter generator. Well, I guess @Achto beat me to it by far! The pump I have is a Fisher and has strict warnings to not spin it faster than the engine. With your small drive pulley, it’s under driving, right? 1 Share this post Link to post Share on other sites
Achto 27,920 #188 Posted October 23, 2019 (edited) 29 minutes ago, pullstart said: With your small drive pulley, it’s under driving, right? When I got the tractor it had the 2" on the engine and a 5" on the pump, I thinkin' around 1500RPM pump speed. I've since replaced the pump pulley with a 4", it should now be around 1800RPMs at the pump. Edited October 23, 2019 by Achto 1 Share this post Link to post Share on other sites
TJ5208 1,824 #189 Posted April 19, 2022 Awsome looking Raider @Achto 1 Share this post Link to post Share on other sites
TJ5208 1,824 #190 Posted September 21, 2022 (edited) I went through this again to get ideas for my Raider 14. Its a good looking machine. @Achto got any updates for us. Did you name it. Edited September 21, 2022 by TJ Salyers Share this post Link to post Share on other sites
Achto 27,920 #191 Posted September 21, 2022 5 hours ago, TJ Salyers said: @Achto got any updates for us. Did you name it. I've got a little over 100hrs on the clock since I built this tractor. So far it's been a great machine. As for the name - Raider 12. 3 Share this post Link to post Share on other sites
