pfrederi 18,334 #2426 Posted June 5, 2019 14 hours ago, Goldann520 said: Ok, ed, i can do that? This problem has been there since i first fired it up. Engine does shake quite a bit and isolators not so hot like i mentionedbefore. It will bolt to the frame and line up properly? Ive never had a wh with a cradle and isolators You could make a couple spacers like these used to mount a small base block K341 in a Charger 12 frame. 1 Share this post Link to post Share on other sites
Racinbob 11,726 #2427 Posted June 5, 2019 14 hours ago, cafoose said: Trying to hook my 7-1211 tiller to my C161 and I don't know how to hook up the lift cable. I'm thinking if I hook it to the top of the bar near where I'm stretching it to it will work shown in the eighth image. However, I would have to drill a hole in the top of the bar to attach the chain. It also will be very close to the gas tank when lifted as shown in the seventh image and I'm concerned whether it will damage the gas tank. Maybe I can cut off a section of the bracket where it comes near the tank? I'm also looking for a replacement idler pulley because the bearing is rusted tight. The 7-1221 tiller was designed to be lifted with a rod through the slot hitch. I used one for years on my 1976 c-series. One thing I didn't like about it was the idler setup mounted just in front of the transmission requiring you to space the running board out and use two belts. I changed things by using the later idler setup under the engine and just one belt direct to the tiller. The idler in front of the transmission was eliminated. I used a short piece of bar tock in the slot hitch to lift things. In my opinion the final result was an improvement over that style as well as the later style tillers. 1 Share this post Link to post Share on other sites
cafoose 3,387 #2428 Posted June 5, 2019 53 minutes ago, Racinbob said: The 7-1221 tiller was designed to be lifted with a rod through the slot hitch. I used one for years on my 1976 c-series. One thing I didn't like about it was the idler setup mounted just in front of the transmission requiring you to space the running board out and use two belts. I changed things by using the later idler setup under the engine and just one belt direct to the tiller. The idler in front of the transmission was eliminated. I used a short piece of bar tock in the slot hitch to lift things. In my opinion the final result was an improvement over that style as well as the later style tillers. I think at this point I'm going with the newer style mount. I'm going to need everything except the tiller itself to switch to the newer style. I'm posting a request for the parts needed in the Big Show thread. Share this post Link to post Share on other sites
adsm08 2,686 #2429 Posted June 5, 2019 8 hours ago, The Tool Crib said: Lucky it missed the glass!! Really. That is a mess to clean up. Share this post Link to post Share on other sites
19richie66 17,577 #2430 Posted June 6, 2019 Actually yesterday but I swapped the ags on the 418-A to the 418-C(Brian Miller’s), took the 522xi wheels and put them on the 418-A. Put the fatty ratty 24-12x12’s on the 522xi. The ags dig too much in my sandy soil. Shouldn’t get stuck now. 7 1 Share this post Link to post Share on other sites
Pullstart 64,576 #2431 Posted June 6, 2019 Those fatties look right at home on the XI! 2 Share this post Link to post Share on other sites
mhlmeader 689 #2432 Posted June 7, 2019 Fresh oil and filter for my newly acquired c-160 auto... 3 6 Share this post Link to post Share on other sites
ebinmaine 70,779 #2433 Posted June 7, 2019 5 minutes ago, mhlmeader said: Fresh oil and filter for my newly acquired c-160 auto... Boy that is a pretty paint scheme.... 3 Share this post Link to post Share on other sites
ZXT 2,401 #2434 Posted June 7, 2019 Got some mowing done while the storms were rolling in. 3 Share this post Link to post Share on other sites
lynnmor 7,567 #2435 Posted June 7, 2019 23 minutes ago, ZXT said: Got some mowing done while the storms were rolling in. Looks like you need to sharpen the blades. 2 Share this post Link to post Share on other sites
ZXT 2,401 #2436 Posted June 7, 2019 (edited) 1 hour ago, lynnmor said: Looks like you need to sharpen the blades. Thats’s what the donkeys are for! Looking the other way showing the yard was too dark for my camera to get a good picture. Edited June 7, 2019 by ZXT Share this post Link to post Share on other sites
Goldann520 242 #2437 Posted June 7, 2019 (edited) Well, put my new battery hold down on the bomb and pulled the drive sheave.waiting on that. If that doesnt fix the belt throwing i may take a match to it. Repaired the sloppy dipstick with "steel on a stick" the maint. Guys at work gave me. We'll see what heat and vibration does. Swapped the isolators around yest. But still throwing belt. Also repacked the pto bearing. Edited June 7, 2019 by Goldann520 Share this post Link to post Share on other sites
adsm08 2,686 #2438 Posted June 7, 2019 I undid everything I did to it yesterday, 1 1 Share this post Link to post Share on other sites
Shynon 7,475 #2439 Posted June 8, 2019 Put new field coils, bearings and brushes in the starter generator on the 1045. Gonna rewire it and the 1055 7 2 Share this post Link to post Share on other sites
71_Bronco 1,072 #2440 Posted June 8, 2019 18 minutes ago, Shynon said: Put new field coils, bearings and brushes in the starter generator on the 1045. Gonna rewire it and the 1055 Did you get a kit from I Save Tractors? Was thinking about doing a rebuild on my Commando 8 just to be on the safe side, seeing as my tractor is just over 50 years old. Share this post Link to post Share on other sites
Shynon 7,475 #2441 Posted June 8, 2019 6 minutes ago, 71_Bronco said: Did you get a kit from I Save Tractors? Was thinking about doing a rebuild on my Commando 8 just to be on the safe side, seeing as my tractor is just over 50 years old. got them off of Usually I only have to replace the brushes and bearings, but the field coils had some of the covering coming off exposing the coils. 1 Share this post Link to post Share on other sites
ebinmaine 70,779 #2442 Posted June 8, 2019 47 minutes ago, 71_Bronco said: thinking about doing a rebuild on my Commando 8 just to be on the safe side, Others might feel differently... But if it ain't broke don't fix it... 2 Share this post Link to post Share on other sites
Goldann520 242 #2443 Posted June 8, 2019 (edited) 11 minutes ago, ebinmaine said: Others might feel differently... But if it ain't broke don't fix it... I agree, if its keeping a charge run it. If its still doing work, run it Edited June 8, 2019 by Goldann520 1 Share this post Link to post Share on other sites
ebinmaine 70,779 #2444 Posted June 8, 2019 Went down to the gravel yard this morning and picked up about a yard of sand for the chicken run. How to get it down back..... Yeah, that'll do it. 2 Share this post Link to post Share on other sites
ebinmaine 70,779 #2445 Posted June 8, 2019 Earlier this morning I mentioned to Trina that I'd like to have a couple areas of the yard scraped down a little bit with "her" grader. Of course, any excuse for seat time for her is just as valid as it is for most of us. Here it sits basking in the sun after she was finished. 2 Share this post Link to post Share on other sites
adsm08 2,686 #2446 Posted June 8, 2019 I let the magic smoke out of a few wires. 2 Share this post Link to post Share on other sites
ebinmaine 70,779 #2447 Posted June 8, 2019 57 minutes ago, adsm08 said: I let the magic smoke out of a few wires. These things can happen. Did you get it back in? Share this post Link to post Share on other sites
AMC RULES 37,146 #2448 Posted June 8, 2019 Spent a 1/2 hour with a wire wheel on the grinder today. Though it's not perfect, at least not yet...it is getting there. 5 3 1 Share this post Link to post Share on other sites
adsm08 2,686 #2449 Posted June 8, 2019 1 hour ago, ebinmaine said: These things can happen. Did you get it back in? Well yes, yes I did. The important ones anyway. A wire got pushed up, and rubbed against one of the voltage regulator mounting bolts, shorted to ground, and burned both wires to the amp meter, and the one to the cig lighter. I replaced the amp meter wiring, and since I don't smoke and my phone was at about 75% charge I didn't bother with the cig lighter right then, I just pulled the burnt wire up out of the way and finished mowing. 1 Share this post Link to post Share on other sites
WHX?? 50,752 #2450 Posted June 9, 2019 S/G looks nice Tom mine are usually full of the black brush crap that is no fun to flush out.. One of these days when I get less time I intend to do an instructional on rebuilding them. Don't like sand blasting Craig? I would have taken it allpart and blasted. Those pits marks are gonna make for some nice character even after fresh red. 3 Share this post Link to post Share on other sites
