ebinmaine 70,751 #2251 Posted May 5, 2019 12 minutes ago, pfrederi said: 13 minutes ago, pfrederi said: What kind of wood are you using for the raised beds??? It's just KD 2 x 8s 44" long each side. Recycled/repurposed warehouse shelf boards. They look weathered already from being super dust covered for 12 or 15 years. They'll last 2 or 3 years. Then we'll pick em up and toss em in the pile to go back to Mother Nature's Forest and grade out the loam. 1 Share this post Link to post Share on other sites
Shynon 7,475 #2252 Posted May 7, 2019 Houston we have lift off 5 4 3 Share this post Link to post Share on other sites
Terry M-(Moderator) 2,204 #2253 Posted May 7, 2019 4 minutes ago, Shynon said: Houston we have lift off Looking good Tom! 👍 1 1 Share this post Link to post Share on other sites
19richie66 17,577 #2254 Posted May 7, 2019 Nice work .👍 1 Share this post Link to post Share on other sites
WHX?? 50,740 #2255 Posted May 7, 2019 (edited) Really looks clean Tom and leak free ... rams look all brand new??? That is just a killer tire/weight setup! Lemme know when yer ready to thin the herd some more! Edited May 7, 2019 by WHX22 3 Share this post Link to post Share on other sites
adsm08 2,668 #2256 Posted May 7, 2019 I removed the HY-2 to start resealing it and reinstalled the metal fuel line with new seals and fittings. 1 Share this post Link to post Share on other sites
WHX?? 50,740 #2257 Posted May 7, 2019 9 minutes ago, adsm08 said: I removed the HY-2 to start resealing it and reinstalled the metal fuel line with new seals and fittings. And the are where??? 1 Share this post Link to post Share on other sites
adsm08 2,668 #2258 Posted May 7, 2019 2 minutes ago, WHX22 said: And the are where??? Didn't take any yet,. I got the line in, had to run for dinner, and I basically took the pump off, flopped in in my drain pan to drain, and then ran to my kid's baseball game, just got home. I will take lots of pictures tomorrow as I take the pump apart. 3 Share this post Link to post Share on other sites
WHX?? 50,740 #2259 Posted May 7, 2019 12 minutes ago, adsm08 said: Didn't take any yet,. ran to my kid's baseball game, We'll ok that's a good excuse .....for now ..... but don't let it happen again ... next time send the Missus to the game and tell her you have to get some pics for the boys on RS....yah...that's gonna get ya lucky... 1 4 Share this post Link to post Share on other sites
adsm08 2,668 #2260 Posted May 7, 2019 1 hour ago, WHX22 said: We'll ok that's a good excuse .....for now ..... but don't let it happen again ... next time send the Missus to the game and tell her you have to get some pics for the boys on RS....yah...that's gonna get ya lucky... Oh yea, because she doesn't get mad enough about all the time I spend posting pictures to TRS, which would go up drastically if I ever bothered to start migrating my years of pictures from Photobucket. 1 Share this post Link to post Share on other sites
Stormin 9,983 #2261 Posted May 7, 2019 My plough tractor, the C-121 Black Horse, started to refuse to run right after standing all night in the cold at the HVC rally. Would only run on half choke. Managed to get it to where it was on display with it's stable mates. When the rally ended and I eventually found the time to load up, it refused to start at all. With some help it was pushed up onto the trailer. Back home and rolled off and put away. The following morning I decided to investigate, as I wasn't due back at the rally site till after lunch, to collect rally equipment to take back to the farm. Good spark from the plug but plug dry. Disconnected pump from carb and a good flow through the pump. Removing float bowl from carb revealed bits of black dirt in there. So off with carb and cleaned out the jets. In line filter look clean so I drained the fuel tank. Some dirt was evident in the fuel, so I removed the tap. I then poured fuel into the tank to flush it out. After putting everything back together, the engine fired up straight away. I then tuned the carb and now he Black Horse runs as normal. I suspect the bouncing of the trailer disturb some bits of dirt. Hopefully all will be back to normal, but if it happens again I will take the tank out for a thorough clean and also replace the fuel lines in case the are starting to deteriorate inside. 1 Share this post Link to post Share on other sites
ebinmaine 70,751 #2262 Posted May 7, 2019 2 minutes ago, Stormin said: replace the fuel lines Norman, do you guys have the garbage ethanol in the gas like we fight all the time over here.? Share this post Link to post Share on other sites
Stormin 9,983 #2263 Posted May 7, 2019 Our unleaded petrol contains 5% ethanol, Ed. I've been adding Redex. A fuel additive supposed to improve things. Reduce carbon build up etc. 1 Share this post Link to post Share on other sites
Pullstart 64,571 #2264 Posted May 7, 2019 Drove the Kohler carb’ed Commando 6 around and checked on my new tree line. 6 1 1 Share this post Link to post Share on other sites
Tractorhead 9,093 #2265 Posted May 7, 2019 Sounds great, look at a huge Funride. 1 Share this post Link to post Share on other sites
Tractorhead 9,093 #2266 Posted May 7, 2019 56 minutes ago, ebinmaine said: Norman, do you guys have the garbage ethanol in the gas like we fight all the time over here.? This is in the whole Europe fact and given from the European Union by Law Since 2007 i think. At Law it must be 5% , more is possible and depends on the Filling Stations. Seen last month a station, where 10% was printed on the gas pump.😱 Also Diesel is without sulfur and mixed with 5% Biodiesel whatever this will be. To compensate that miss of sulfur on Diesel engines, i use bit 2 stroke oil. 1 Share this post Link to post Share on other sites
953 nut 57,932 #2267 Posted May 7, 2019 1 hour ago, Stormin said: bouncing of the trailer disturb some bits of dirt. Ran into that problem last year, Should have changed out the fuel lines when I bought it, but hadn't. Share this post Link to post Share on other sites
ebinmaine 70,751 #2268 Posted May 7, 2019 31 minutes ago, Tractorhead said: This is in the whole Europe fact and given from the European Union by Law Since 2007 i think. At Law it must be 5% , more is possible and depends on the Filling Stations. Seen last month a station, where 10% was printed on the gas pump.😱 Also Diesel is without sulfur and mixed with 5% Biodiesel whatever this will be. To compensate that miss of sulfur on Diesel engines, i use bit 2 stroke oil. Sounds like a similar situation to over here. Varies a little state-to-state but I think the minimum is 10% ethanol most places. Hasn't been any sulfur in the diesel in quite a while. Share this post Link to post Share on other sites
adsm08 2,668 #2269 Posted May 7, 2019 1 hour ago, ebinmaine said: Sounds like a similar situation to over here. Varies a little state-to-state but I think the minimum is 10% ethanol most places. Hasn't been any sulfur in the diesel in quite a while. We have up to 10% ethanol in the 'regular' gasoline, and 10 ppm or less sulfur in on-road diesel here in the States. We also now have E-15 with is supposed to be useable in non-flex fuel vehicles 2010 and up, in addition to the E-85. Federal law says it is actually illegal to use E-15 or higher in non-flex fuel or off road (small engines, lawn mowers, marine etc) older than 2010. 1 Share this post Link to post Share on other sites
Pullstart 64,571 #2270 Posted May 8, 2019 Jada took a parade lap with dear old Daddy! That Commando 6 sure does steer easy! Probably the best 80 bucks spent in quite a while! 5 4 1 4 Share this post Link to post Share on other sites
Stormin 9,983 #2271 Posted May 8, 2019 (edited) Made up another exhaust stack for the C-125 this morning. The one on was an old BSA motorcycle silencer. The outlet pipe was rather holey, with a cut up tin can wrapped round and held by jubilee clips. So cut off the bad bit off the BSA one and the tail end off a tractor one. The result. Edited May 8, 2019 by Stormin 7 Share this post Link to post Share on other sites
dannyj74 5 #2272 Posted May 9, 2019 Added LED lights to the front 3 Share this post Link to post Share on other sites
adsm08 2,668 #2273 Posted May 12, 2019 I sat on it. 4 Share this post Link to post Share on other sites
PeacemakerJack 10,743 #2274 Posted May 12, 2019 Finally took the Deuce off of Kelli’s RED (523Dxi) and slapped the monster 60” deck on there in time to help Caleb finish cutting the lawn. He was giving JackRabbit(418-C) a workout for the third time this season. Judge (my 8 year old) helped me do the switch over and so while Caleb and I were mowing, I let him wake up Vader (Super C) and tool around the yard awhile—staying away from us. That KT-19 sure sounds tough even just cruising the yard at half throttle! 5 7 Share this post Link to post Share on other sites
Achto 28,787 #2275 Posted May 13, 2019 I had Radpferd on roller duty. After about 1.5hrs of putting around, I think he sipped down about a cup of fuel. 2 11 1 Share this post Link to post Share on other sites
