Monstrosity 1,128 #20151 Posted October 30, 2023 Rainy day not much work at the farm so came home and finally painted the rims 3 6 3 Share this post Link to post Share on other sites
davem1111 2,030 #20152 Posted October 30, 2023 53 minutes ago, Monstrosity said: Rainy day not much work at the farm so came home and finally painted the rims Great dedicated team of helpers you have there! 5 Share this post Link to post Share on other sites
peter lena 8,631 #20153 Posted October 30, 2023 @ML3 always experimenting on any issue ,repetitive problems are what you want, for a trail to failure point , eliminate , change , improve as you go . your picture of trans, shift rod / boot, idler pulley . a TYE WRAP , just ABOVE THE SHIFT BOOT ,that has been under lubricated , makes for a solid gain , that idler pulley , with the tiny side bearing shields , is telling you of a failure point , and related rusty linkage. Size on out , same size / type , with possible wider grease shields, carefully remove shields and re grease with a hi temp grease , eliminate a rusty failure . when you improve / change , any rotational movement point , you will notice a FUNCTIONAL EASE , of operation that makes things easy . just a thought , pete 1 Share this post Link to post Share on other sites
Pullstart 62,897 #20154 Posted October 31, 2023 Just rolled ‘em around. I’m starting to pack away my toys like a squirrel for the winter. I think I have enough 8” tires! 7 8 Share this post Link to post Share on other sites
Tractorhead 9,064 #20155 Posted October 31, 2023 On 10/28/2023 at 9:40 PM, Handy Don said: And who needs a cigarette lighter anymore?! Aem i do..😎 1 6 Share this post Link to post Share on other sites
ML3 1,203 #20156 Posted October 31, 2023 17 hours ago, peter lena said: @ML3 always experimenting on any issue ,repetitive problems are what you want, for a trail to failure point , eliminate , change , improve as you go . your picture of trans, shift rod / boot, idler pulley . a TYE WRAP , just ABOVE THE SHIFT BOOT ,that has been under lubricated , makes for a solid gain , that idler pulley , with the tiny side bearing shields , is telling you of a failure point , and related rusty linkage. Size on out , same size / type , with possible wider grease shields, carefully remove shields and re grease with a hi temp grease , eliminate a rusty failure . when you improve / change , any rotational movement point , you will notice a FUNCTIONAL EASE , of operation that makes things easy . just a thought , pete Agreed. That's why it's coming apart 2 1 Share this post Link to post Share on other sites
Pullstart 62,897 #20157 Posted October 31, 2023 Stormy has had a ripped valve stem since Memorial Weekend. Since I’m moving stuff around, it might as well roll (finally)! 7 Share this post Link to post Share on other sites
Colby G 233 #20158 Posted November 1, 2023 (edited) Got a new project today, needs a lot of TLC, but it was a great deal, and came with a gearbox Edited November 1, 2023 by Colby G 8 1 Share this post Link to post Share on other sites
TonyToro 1,049 #20159 Posted November 2, 2023 On 10/30/2023 at 9:43 PM, Pullstart said: Just rolled ‘em around. I’m starting to pack away my toys like a squirrel for the winter. I think I have enough 8” tires! Every time I see your shop I say….man I need to build one that big! My garage is over full. 😂 4 Share this post Link to post Share on other sites
Colby G 233 #20160 Posted November 2, 2023 Working on replacing the gearbox in the new charger 12, but it has a crack in the mount, so we've gotta weld that. Also going to put a bigger pin in the hood so it doesn't wiggle as much and got to get a hood latch and line up the hood yet. 6 Share this post Link to post Share on other sites
Colby G 233 #20161 Posted November 2, 2023 I'm trying to take the hubs off the shaft of the gearbox and was wondering if anyone knows why they won't come off 1 Share this post Link to post Share on other sites
ebinmaine 67,516 #20162 Posted November 2, 2023 2 minutes ago, Colby G said: I'm trying to take the hubs off the shaft of the gearbox and was wondering if anyone knows why they won't come off Wheel hub removal from an axle and be extremely difficult and requires Great patience with the possibility of specials. DO NOT USE A HAMMER OF ANY KIND. DO NOT USE A THREE-JAW PULLER. There are a few different ways of attacking the problem and I would highly recommend doing a search on the site and taking the time to read up on them. Patience is the answer. Remember, it took 40 or 60 years for them to rust in place and they won't come off in just a few minutes. 3 1 Share this post Link to post Share on other sites
rmaynard 15,461 #20163 Posted November 2, 2023 Go to the search icon, top right, and put in the phrase "hub puller". Use the quote marks. That will narrow your search. This will show you many of the ways we get our hubs off. Remember, no hammers, and no 3-jaw pullers. A lot of PB Blaster and patience. Good luck. 6 Share this post Link to post Share on other sites
TJ5208 1,824 #20164 Posted November 3, 2023 Hey guys sorry for not being on here much anymore. My business has been keeping me busy. But since the last time I was on here my family has grew from 2 to 3 tractors. So I have the 520-8 and 2 416-8s. 5 5 Share this post Link to post Share on other sites
TJ5208 1,824 #20165 Posted November 3, 2023 Some of you guys may remember a while back I got rims and tires for my tractor. Well I had a blowout pulling a big grain cart full of beans going down the Highway. So I had to stick turf tires back on it for a little while until I found this other for 416-8 that had ags on it then I put them on it. And then the other day I found a set of 26 12 12s on Marketplace and decide to go ahead and get them. So now I need to paint match the rims probably give the front rim an extra coat to match the Rears after I paint them 4 5 Share this post Link to post Share on other sites
sjoemie himself 3,068 #20166 Posted November 3, 2023 7 hours ago, TJ5208 said: Looks beefy! I like it 2 1 Share this post Link to post Share on other sites
ebinmaine 67,516 #20167 Posted November 3, 2023 In front of the shed there's an enclosure for the chickens. Trina removes it every fall so we can plow snow easier. Here she's dragging the cage out with Millie. Then she graded the area smooth with the 867 Pigpen. 5 7 Share this post Link to post Share on other sites
sjoemie himself 3,068 #20168 Posted November 3, 2023 28 minutes ago, ebinmaine said: Nice horn! Also, are those ma-hoo-sive zipties you've got on the rear wheel weights there? Share this post Link to post Share on other sites
ebinmaine 67,516 #20169 Posted November 3, 2023 3 minutes ago, sjoemie himself said: Nice horn! Also, are those ma-hoo-sive zipties you've got on the rear wheel weights there? Around our acreage it's sort of a requirement that you need to have a noise maker of some type on your tractor. Millie has thumb pusher ringalinger on the steering wheel. Giant zip ties would be awesome but no. Those are standard average everyday run of the mill tarp holder type bungee cords. Share this post Link to post Share on other sites
sjoemie himself 3,068 #20170 Posted November 3, 2023 40 minutes ago, ebinmaine said: noise maker of some Ha.. and here I was thinking an exhaust or maybe the driver would cause enough noises 42 minutes ago, ebinmaine said: standard average everyday run of the mill tarp holder type bungee cords. Check! To hold the chains toight.. Believe it or not we call those 'spinnekoppen' or spiderheads.. yeh I know, weird.. 2 Share this post Link to post Share on other sites
ebinmaine 67,516 #20171 Posted November 3, 2023 3 minutes ago, sjoemie himself said: driver would cause enough noises Interesting you'd say that..... Watch for a new thread about a word, soon. 1 Share this post Link to post Share on other sites
Tractorhead 9,064 #20172 Posted November 3, 2023 59 minutes ago, sjoemie himself said: Ha.. and here I was thinking an exhaust or maybe the driver would cause enough noises When the driver eaten too much Beans..... could be ... May be...😂 5 Share this post Link to post Share on other sites
Ed Kennell 38,178 #20173 Posted November 3, 2023 Made the winter change over. Put some mowers away and got the snow movers and wood hauler ready. Put the tiller on and tilled the garden. 3 12 Share this post Link to post Share on other sites
sjoemie himself 3,068 #20174 Posted November 4, 2023 9 hours ago, Ed Kennell said: Put the tiller on and tilled the garden. Hello mr. Ed, interesting setup. I want to make something similar. Does this tiller spin forward (pulling the tractor) or backwards (pushing back)? Greetings from the Netherlands, Mark 2 Share this post Link to post Share on other sites
Ed Kennell 38,178 #20175 Posted November 4, 2023 2 hours ago, sjoemie himself said: Does this tiller spin forward (pulling the tractor) or backwards (pushing back)? Hi Mark, It pushes the tractor backwards. It spins as designed with the sharp edge of the tines leading. 2 1 Share this post Link to post Share on other sites
