BrianKoch 307 #18901 Posted May 1, 2023 Installed hitch receiver from wheel horse parts & more Installed adjustable hitch Pulled the 4x8 utility trailer around cleaning up storm damage 6 5 Share this post Link to post Share on other sites
The Freightliner Guy 1,327 #18902 Posted May 2, 2023 today i took one of the wheels off reese the rj so i can take it home and find a replacement 5 Share this post Link to post Share on other sites
oliver2-44 9,743 #18903 Posted May 3, 2023 7 hours ago, The Freightliner Guy said: today i took one of the wheels off reese the rj so i can take it home and find a replacement Are you looking for a tire or the actual metal rim? Front or rear? Share this post Link to post Share on other sites
The Freightliner Guy 1,327 #18904 Posted May 3, 2023 9 hours ago, oliver2-44 said: Are you looking for a tire or the actual metal rim? Front or rear? front tires looking for both rims and tires Share this post Link to post Share on other sites
Lane Ranger 10,968 #18905 Posted May 3, 2023 (edited) Putting the RJ back together that I had a very tight turning transmission on. I took this to Florida in February and worked on it . Started assembling last year. I finally gave up on the two RJ ⚧️s I had for this rebuild and contacted Keith Jones in Ohio. I madd a wild deal with Keith to give him several boxes of RJ and Suburban transmission parts and a couple full transmissions for a replacement rebuild in trade. Keith also had His friend Larry “Ratpack” Eads assist him and analyze the problem. Larry suggested two new axle’s which he machined as the old ones were pretty worn. I had given Keith all new bearings, seals, brass bushings, gaskets and side plate gaskets for the rebuild. This transmission is an early 8 tooth brake gear not the later 11 . Keith and Larry worked on this thing over five Sundays getting all the old parts out, the new parts in and finding out what was causing the tightness in the axles Turing the gears. It turned out that one of the axle tubes on the inside of one of the side plates was slightly bent and needed to be straightened! I picked it up on Sunday April 3pth which was the date Keith and I set for pick up back in March. I can’t thank these two guys rnough as this transmission is the smoothest turning thing! Waiting for my wheel paint to dry before putting in my rear routes but racing to go ride this RJ. I built this for my brother David. Edited May 3, 2023 by Lane Ranger 4 7 Share this post Link to post Share on other sites
kpinnc 12,015 #18906 Posted May 4, 2023 I got a little tinkering done today. I swapped front sneakers (16x7.50-8) out on the 314-8, and finally added the front wheel weights. The Vanguard is awesome, but very light weight compared to a Magnum. Given the lift on the back, every extra pound of ballast counts. 2 11 Share this post Link to post Share on other sites
ebinmaine 67,455 #18907 Posted May 4, 2023 7 hours ago, kpinnc said: every extra pound of ballast counts You hang a Mackissic chipper off the front of that and your ballast concerns are forever solved. 2 1 5 Share this post Link to post Share on other sites
Pullstart 62,841 #18908 Posted May 4, 2023 My little buddy chose Chloe first for our rides, but the field is still too wet to turn a furrow for the food plots. It needs a new H10C plug as well, fouling up and loosing power with a load. We parked the 953 and grabbed the WHRat for some golf ball pickin’. She got quite a bit of drive time logged! *Any time she was by herself, the tractor was in low/1st. Crawl speed indeed. 5 7 Share this post Link to post Share on other sites
kpinnc 12,015 #18909 Posted May 4, 2023 4 hours ago, ebinmaine said: You hang a Mackissic chipper off the front of that and your ballast concerns are forever solved. I'd put it up there if I had one! 2 Share this post Link to post Share on other sites
ohiofarmer 3,265 #18910 Posted May 4, 2023 Back in post 18898, I spoke of fixing the flat tires. Here they are, with tubes inserted and the things uninflated so that it would be easy to paint behind the outside bead. Used the Rust-Oleum red primer and let it dry and then painted the inside of the tim with Almond Gloss. Then we mounted it to the tractor and spun on a finish coat and carefully coated the tim edge while keeping the tire back from the rim . The tire will be inflated later..While not as perfect as spraying the paint on, it worked very well using the rotating tire and holding the brush against it. 5 5 Share this post Link to post Share on other sites
Ed Kennell 38,159 #18911 Posted May 4, 2023 Loaded for the Steam-O-Rama Spring Fling. I'll be there Fri. and Sat. 9 Share this post Link to post Share on other sites
ebinmaine 67,455 #18912 Posted May 4, 2023 1 hour ago, Ed Kennell said: Loaded for the Excellent. If all goes right we will be loaded up and strapped down before bed. Headed out in the morning. 1 Share this post Link to post Share on other sites
Handy Don 12,216 #18913 Posted May 4, 2023 1 hour ago, Ed Kennell said: Loaded for the Steam-O-Rama Spring Fling 47 minutes ago, ebinmaine said: we will be loaded up and strapped down before bed. Headed out in the morning Safe travels to you both and I hope you have a great time! 2 1 Share this post Link to post Share on other sites
squonk 41,079 #18914 Posted May 4, 2023 Pressed in bearings in a 5025 Trans. Waiting for 1 more input shaft bearing. Used press on the capped ones and custom arbors and 7/16" fine thread rod for the axle bearings and non capped ones. They have a lip to set the depth for the seals. 7 Share this post Link to post Share on other sites
ebinmaine 67,455 #18915 Posted May 4, 2023 1 hour ago, Handy Don said: Safe travels to you both and I hope you have a great time! You as well !! Share this post Link to post Share on other sites
BrianKoch 307 #18916 Posted May 4, 2023 Chores! 2 3 Share this post Link to post Share on other sites
ebinmaine 67,455 #18917 Posted May 5, 2023 Added decals to the seat of the newly restored '75 C160 Automatic. @Pullstart @c-series don I'd put more there if I had 'em. 1 5 Share this post Link to post Share on other sites
Pullstart 62,841 #18918 Posted May 5, 2023 Sweeeeeeeeeeeeet! 1 1 Share this post Link to post Share on other sites
c-series don 8,690 #18919 Posted May 5, 2023 @ebinmaine Wow Eric! That’s awesome, I’m honored! Thank you 🙏👍🏻 1 Share this post Link to post Share on other sites
ebinmaine 67,455 #18920 Posted May 5, 2023 41 minutes ago, c-series don said: @ebinmaine Wow Eric! That’s awesome, I’m honored! Thank you 🙏👍🏻 That'll be on display at Zagray this weekend. Share this post Link to post Share on other sites
Pullstart 62,841 #18921 Posted May 5, 2023 I’m going to try to link this video here… fun with my niece and I’m not in jail for endangerment yet! https://www.tiktok.com/t/ZTRwgQxEf/ 2 Share this post Link to post Share on other sites
squonk 41,079 #18922 Posted May 5, 2023 Just watin on an axle. 3 Share this post Link to post Share on other sites
bswet1 39 #18923 Posted May 5, 2023 New front tires and some deck work on my 312-8. Hoping to mow with it for the first time this weekend. 3 1 Share this post Link to post Share on other sites
pfrederi 17,734 #18924 Posted May 5, 2023 Used the 310-8 (with 10 pinion LSD) to haul my new roller ..finally one that has some real weight...+/- 400 lbs WH is my "Mudder" tractor fat tires LSD no weight no ruts 10 Share this post Link to post Share on other sites
bswet1 39 #18925 Posted May 5, 2023 And said first mow with my new to me 312.... Sounds like a B52 bomber but cuts really well! A little fine tuning to do but super happy. 6 1 Share this post Link to post Share on other sites
