GAJoe 850 #18776 Posted April 16, 2023 (edited) I've mowed with the refurbished deck a couple times now so I pulled it off and gave the bottom a good drill driven wire brushin'. Then I soaked it good with chain and cable lube and sun bath per @peter lena recommendation. Edited April 16, 2023 by GAJoe 7 2 Share this post Link to post Share on other sites
Darb1964 1,089 #18777 Posted April 16, 2023 Fired up the old girl and did a little yard work, now that most of the snow has finally gone. She's well used but still runs and works great. 1 9 1 Share this post Link to post Share on other sites
peter lena 9,051 #18778 Posted April 16, 2023 @GAJoe that lubrication and sun / heat breaking grunge time , really helps out a deck , been doing that for years , as well as before winter storage . anything I suggest , have been doing for years , pete 2 Share this post Link to post Share on other sites
spitfire 176 #18780 Posted April 16, 2023 We are blesed for a year. All is well! 2 2 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,360 #18781 Posted April 16, 2023 @spitfire the question is who got the parking ticket? Which one of the drivers is you? 2 Share this post Link to post Share on other sites
spitfire 176 #18782 Posted April 16, 2023 (edited) The man in yelow was the driver of my C165 😉 I was driving the B111, it didnt whant to go as it should this morning... Someone put it in low gear and i didnt think of that until we where going home again 😄 Edited April 16, 2023 by spitfire 3 2 Share this post Link to post Share on other sites
ohiofarmer 3,319 #18783 Posted April 16, 2023 So this is what I started with . A Toro 314 8 and a very nice tractor. It had some issues when I bought it last fall of glitchy starting as I needed to turn the headlights off and on and maybe punch the test lights switch.. I added a power switch to the solenoid to the start circuit and she started and mowed great. Until now. You can see where the red wires melted through the plug connector. The reason why is horrible pitted corrosion on the pin on the rear of the switch that connects to them. I am pretty sure that the MN sin red wire plus a secondary feed that goes to the Christmas tree indicator were once connected there, but now are just threads. I need a new switch and also one or more Female ends for the red wires at least. I am gonna cut the plastic from around the metal connector s to save as much as possible. I hope that I can order exactly what I need to repair the machine. 2 Share this post Link to post Share on other sites
ohiofarmer 3,319 #18784 Posted April 17, 2023 So this is what I started with . A Toro 314 8 and a very nice tractor. It had some issues when I bought it last fall of glitchy starting as I needed to turn the headlights off and on and maybe punch the test lights switch.. I added a power switch to the solenoid to the start circuit and she started and mowed great. Until now. You can see where the red wires melted through the plug connector. The reason why is horrible pitted corrosion on the pin on the rear of the switch that connects to them. I am pretty sure that the missing red wire plus a secondary feed that goes to the Christmas tree indicator were once connected there, but now are just threads. I need a new switch and also one or more Female ends for the red wires at least. I am gonna cut the plastic from around the metal connector s to save as much as possible. I hope that I can order exactly what I need to repair the machine. Toro wants 35 dollars for the five pin switch, but an Indak is a fraction of that. I may be able to put a new female connector and some shrink tube on those red wires . 1 Share this post Link to post Share on other sites
RandyLittrell 3,894 #18785 Posted April 18, 2023 Almost traded off my C-120, but pulled it out of the shed and remembered just how nice it is!! Guess I have to make it run now!! Randy 10 2 Share this post Link to post Share on other sites
spitfire 176 #18786 Posted April 18, 2023 Hi, We are restoring the mower deck for the A60 26". Does someone knows what size belt is fits from stock? 1 Share this post Link to post Share on other sites
Blasterdad 2,966 #18787 Posted April 18, 2023 29 minutes ago, spitfire said: Hi, We are restoring the mower deck for the A60 26". Does someone knows what size belt is fits from stock? # 225360 V Belt ( 4L 63 ) 1 1 Share this post Link to post Share on other sites
ebinmaine 70,291 #18788 Posted April 18, 2023 8 hours ago, RandyLittrell said: Almost traded off my C-120, but pulled it out of the shed and remembered just how nice it is!! Guess I have to make it run now!! Randy Keep it. Keep it. Keep it. Keep it. Keep it. Keep it. 2 1 1 Share this post Link to post Share on other sites
spitfire 176 #18789 Posted April 18, 2023 (edited) 24 minutes ago, Blasterdad said: # 225360 V Belt ( 4L 63 ) Greate, so much information. Thanks I cant realy find mower deck belts on the files, is it me or is in not in there? 24 minutes ago, Blasterdad said: # 225360 V Belt ( 4L 63 ) Is this the toro part number? 24 minutes ago, Blasterdad said: Edited April 18, 2023 by spitfire Share this post Link to post Share on other sites
Blasterdad 2,966 #18790 Posted April 18, 2023 9 minutes ago, spitfire said: is it me or is in not in there? It's there, click on download this file, download the top file, ( TIPL ). Scroll down to the bottom, deck belt is # 3. Yes they are Toro part numbers but a 4L63 is the belt type & length, ( 63 inches ). Any hardware store should have it. 2 Share this post Link to post Share on other sites
Lane Ranger 11,096 #18791 Posted April 18, 2023 Cleaned the 42 inch recycler mower deck, put new blades on and greased all the spindles. Mowed great after the maintenance work was done. 10 1 Share this post Link to post Share on other sites
Pullstart 64,338 #18792 Posted April 19, 2023 @kpinnc @SylvanLakeWH @TonyToro @Monstrosity Here’s what I did for Rylee’s Commando 800 “Screamin’ Jimmy” in 2018. I cut the back foot rest bar off a C series frame, adapted it to the Commando frame, and notched a foot rest to fit another pedal. If she ever chooses to put it back to stock, we can remove the pedal and foot rest, and cover the second bar with another foot rest. I told her that some day when she teaches her kids to drive it, she can put the second pedal kit back on. I often joke that I was born with my butt pretty close to the ground. I am 5’6” on an average day, if I’m standing proud, I might squeak by at 5’7”. I can drive it comfortably with the second pedal just fine. 4 7 1 Share this post Link to post Share on other sites
Pullstart 64,338 #18793 Posted April 19, 2023 I fluid filled a tire with no tube in it. I ended with bead sealer on both edges of the rim and also on the new valve stem. 6 2 Share this post Link to post Share on other sites
ebinmaine 70,291 #18795 Posted April 19, 2023 6 hours ago, Pullstart said: I fluid filled a tire with no tube in it. I ended with bead sealer on both edges of the rim and also on the new valve stem. You set the beads, then break one off to fill that side ? 1 Share this post Link to post Share on other sites
953 nut 57,435 #18796 Posted April 19, 2023 Rylee is a chip off the old block, boots and shorts, wonder where she ever got that idea. 1 3 Share this post Link to post Share on other sites
Pullstart 64,338 #18797 Posted April 19, 2023 3 hours ago, ebinmaine said: You set the beads, then break one off to fill that side ? Yes, and the bottom one has bead sealer from the get go. The top gets dried off, then bead sealer to finish. Bead sealer also on the new valve stem. 2 1 Share this post Link to post Share on other sites
ebinmaine 70,291 #18798 Posted April 19, 2023 8 minutes ago, Pullstart said: Bead sealer When you get a minute can you show a picture of the product you're using? 1 Share this post Link to post Share on other sites
Pullstart 64,338 #18799 Posted April 19, 2023 5 minutes ago, ebinmaine said: When you get a minute can you show a picture of the product you're using? It’s from the local parts store. Like anti-seize, it seems to travel a while 3 Share this post Link to post Share on other sites
WHX?? 50,462 #18800 Posted April 19, 2023 9 minutes ago, Pullstart said: It’s from the local parts store. Like anti-seize, it seems to travel a while Same stuff I used on Sylvia's A60. Comes off a little easier than anti seize on a plow handle tho... 5 Share this post Link to post Share on other sites
