Monstrosity 1,146 #18551 Posted March 10, 2023 (edited) 14 hours ago, ebinmaine said: Say whuuuut?? So you fill the fire extinguisher with fluid have an air source connected to the fill port cut the end off of the hose and place a locking fill chuck and viola you have pressurized fluid filler. Needs to be a water extinguisher. I have access to old extinguishers being the in volunteer fire service and they work great for filling transfer cases and differentials Edited March 11, 2023 by Monstrosity 9 1 Share this post Link to post Share on other sites
ebinmaine 70,407 #18552 Posted March 11, 2023 3 hours ago, Thegearhead0324 said: just ordered and dumped a very lot of money on new tires and tubes for the 1257 Worth. Every. Penny. 3 Share this post Link to post Share on other sites
CCW 1,329 #18553 Posted March 11, 2023 I have an old fire extinguisher if anyone wants it. Free for pickup in the Hartford, CT area. 2 Share this post Link to post Share on other sites
TonyToro 1,101 #18554 Posted March 11, 2023 21 hours ago, Wheelhorse#1 said: So I attempted to make a counterfeit WH lens cover.As you can see I boogered up the cut ! Ill try again and try to improve it some. Not having the WH logo makes me a bit sad but I can live without it. Looks good enough to me. I think this one is the replacement… https://wheelhorsepartsandmore.com/product/98-1713-7075-103771-toro-wheel-horse-headlight-lens-with-decal/ 3 Share this post Link to post Share on other sites
TonyToro 1,101 #18555 Posted March 11, 2023 16 hours ago, Thegearhead0324 said: Feeling sick to my stomach, as I just ordered and dumped a very lot of money on new tires and tubes for the 1257.... ouch. I know the feeling! 1 Share this post Link to post Share on other sites
johnnymag3 2,559 #18556 Posted March 11, 2023 8 minutes ago, TonyToro said: I know the feeling! Its really sad how we are being ripped off with all of this price gouging.............. 2 Share this post Link to post Share on other sites
SylvanLakeWH 27,260 #18557 Posted March 11, 2023 21 hours ago, Wheelhorse#1 said: So I attempted to make a counterfeit WH lens cover.As you can see I boogered up the cut ! Ill try again and try to improve it some. Not having the WH logo makes me a bit sad but I can live without it. @Vinylguy makes the logo decals... They are perfect! 4 1 Share this post Link to post Share on other sites
spitfire 176 #18558 Posted March 11, 2023 I came home with this today 12 Share this post Link to post Share on other sites
Handy Don 13,272 #18559 Posted March 11, 2023 16 hours ago, CCW said: I have an old fire extinguisher if anyone wants it. Free for pickup in the Hartford, CT area. Type? Share this post Link to post Share on other sites
kpinnc 13,514 #18560 Posted March 11, 2023 (edited) @spitfire You should name the one with headlights Gary... Nice score regardless! Edited March 11, 2023 by kpinnc 2 9 Share this post Link to post Share on other sites
Wheelhorse#1 1,758 #18561 Posted March 11, 2023 7 hours ago, SylvanLakeWH said: @Vinylguy makes the logo decals... They are perfect! Thanks ! Ill have to check the @Vinylguy out Share this post Link to post Share on other sites
ebinmaine 70,407 #18562 Posted March 11, 2023 18 minutes ago, Wheelhorse#1 said: Thanks ! Ill have to check the @Vinylguy out Give Terry a call or PM. Share this post Link to post Share on other sites
SylvanLakeWH 27,260 #18563 Posted March 11, 2023 41 minutes ago, Wheelhorse#1 said: Thanks ! Ill have to check the @Vinylguy out 22 minutes ago, ebinmaine said: Give Terry a call or PM. https://www.wheelhorseforum.com/forum/50-vinylguy/ 2 Share this post Link to post Share on other sites
CCW 1,329 #18564 Posted March 11, 2023 3 hours ago, Handy Don said: Type? I am out of town until the end of March. The photo below is the fire extinguisher, but the hose is no longer with it. 1 Share this post Link to post Share on other sites
GAJoe 850 #18565 Posted March 12, 2023 The C-160 rides again! I finished getting the C-160 back together today. Had a few challenges that took a while. Getting the roll pin back in the high/low range shifter and getting the dog point set screw back in after the tranny was back under it. Tried using one hand for too long. It was too big and getting in the way. I was able to hold the shifter between palms and use both index fingers to run the set screw in. Then the lock nut. I want to thank all of my new friends for all of your help. I ran it through all the gears successfully. Someone could have cautioned me hold on tight when starting off in third gear in high range. I'm nearly 200 lbs and the front tires came off the ground. 2 11 Share this post Link to post Share on other sites
Horse Newbie 7,194 #18566 Posted March 12, 2023 (edited) 37 minutes ago, GAJoe said: The C-160 rides again! I finished getting the C-160 back together today. Had a few challenges that took a while. Getting the roll pin back in the high/low range shifter and getting the dog point set screw back in after the tranny was back under it. Tried using one hand for too long. It was too big and getting in the way. I was able to hold the shifter between palms and use both index fingers to run the set screw in. Then the lock nut. I want to thank all of my new friends for all of your help. I ran it through all the gears successfully. Someone could have cautioned me hold on tight when starting off in third gear in high range. I'm nearly 200 lbs and the front tires came off the ground. Man that’s a good looking tractor! Glad you fixed it up and kept it after you had first had a slight inclination to sell… Glad the guys on here helped persuade you to wrench on it and keep it. Hope you spend many hours riding and working it ! Edited March 12, 2023 by Horse Newbie 5 2 1 Share this post Link to post Share on other sites
ebinmaine 70,407 #18567 Posted March 12, 2023 2 hours ago, GAJoe said: The C-160 rides again! Joe that's fantastic !! 2 hours ago, GAJoe said: Someone could have cautioned me hold on tight when starting off in third gear in high range. I'm nearly 200 lbs and the front tires came off the ground. Torque!! 4 Share this post Link to post Share on other sites
Monstrosity 1,146 #18568 Posted March 12, 2023 (edited) Built a moving raised bed, out of pallets, today on a old trailer that isn't road worthy without some welding and electrical work. Cleaned up the gazebo area as well. Edited March 12, 2023 by Monstrosity 10 Share this post Link to post Share on other sites
Easton Rich 455 #18569 Posted March 12, 2023 9 hours ago, kpinnc said: @spitfire You should name the one with headlights Gary... Nice score regardless! Totally agree there also nice steal 1 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,758 #18570 Posted March 12, 2023 13 hours ago, ebinmaine said: Joe that's fantastic !! Torque!! Wheelie horse ! 2 Share this post Link to post Share on other sites
GAJoe 850 #18571 Posted March 12, 2023 (edited) The rain let up long enough that I had to see how the (bought separately and rebuilt) mower deck and new belt would fit. I'm waiting until after my first grass cutting to see how the belts do before putting the pully guards back on. I got the new belt threaded through the Mule with a little YouTube help. I gave it a spin and all is smooth and quiet as @peter lena said it would be. I'll get the new cone on it from @ebinmaine so that I don't have to worry about the bearing coming out and be cutting grass next weekend. Edited March 12, 2023 by GAJoe 1 9 Share this post Link to post Share on other sites
ebinmaine 70,407 #18572 Posted March 12, 2023 8 minutes ago, GAJoe said: I'll get the new cone on it from @ebinmaine so that I don't have to worry about ..... Should see it tomorrow or Tuesday Joe!! While you suthin' folks is mowing we'll be digging out another 12+" of white stuff. 3 1 Share this post Link to post Share on other sites
Handy Don 13,272 #18573 Posted March 13, 2023 (edited) Mounted the 1-¼” riser onto the 854. Seat sides no longer touch the fenders when I lean (yay!). I’ll do a fender repaint when the weather warms up. Here the seat is centered over the rearward spring hole. The front (left) bolt only holds the riser to the spring while the rear (right) bolt holds the seat, riser, and spring. Rotating the riser 180º centers the seat over the forward spring hole, moving the seat 2” forward while keeping the rise. Seat forward position (square hole above front spring hole) Seat rearward position (square hole above rear spring hole) Edited March 13, 2023 by Handy Don 3 6 Share this post Link to post Share on other sites
spitfire 176 #18574 Posted March 13, 2023 (edited) I got rid of the square bosch lights, sorry guys. What size round lamp fits this model? Or do i set side lamps? This one needs some tinkering the old engine, everything works only 40 years of hard work is starting to show. First i need to finnish clean out my little shed, so they all get a spot out of the rain. Edited March 13, 2023 by spitfire 3 Share this post Link to post Share on other sites
ebinmaine 70,407 #18575 Posted March 13, 2023 10 minutes ago, spitfire said: What size round lamp fits this model? @SylvanLakeWH Resident black hood expert. 4411 bulbs? 2 Share this post Link to post Share on other sites
