pfrederi 18,334 #17901 Posted December 5, 2022 9 minutes ago, WHX?? said: Those are some head lights.... hope they are LEDs That 3 amp charging system might have an issue otherwise Share this post Link to post Share on other sites
ebinmaine 70,761 #17902 Posted December 5, 2022 2 hours ago, lynnmor said: EB probably will have a major leaf problem with gutters, but it might be worth it to prevent erosion. Although I realize full well that all water flow causes some level of erosion, it takes a torrential rain to effect the groundwork that's been recently done in any visible manner. We've talked about multiple ways of controlling the water flow. We put consideration to having gutters and capturing the water or even piping it down to the frog pond so we could use it in the garden. We've also thought about digging a ditch right where the water falls off the roof that would be able to capture the rain in a controlled and slow manner instead of all willy-nilly. This past Sunday and at least a couple occasions before that we've looked at where the rain water is washing down through the rocks. Another possibility is to keep adding stones that are 4 to 12 inches diameter wherever they are needed and even filling around them in the wall area with concrete that can't be seen. There are some pretty significant pockets in between those giant boulders so a lot of work could be done in there. Share this post Link to post Share on other sites
Handy Don 13,340 #17903 Posted December 5, 2022 15 minutes ago, ebinmaine said: We've also thought about digging a ditch right where the water falls off the roof that would be able to capture the rain in a controlled and slow manner instead of all willy-nilly. A shallow, carefully pitched swale is a good technique for diverting a water flow. It spreads the water out and slows it down. Have to be sure they are not ankle-twisters, though. 1 Share this post Link to post Share on other sites
ebinmaine 70,761 #17904 Posted December 5, 2022 4 minutes ago, Handy Don said: A shallow, carefully pitched swale is a good technique for diverting a water flow. It spreads the water out and slows it down. Have to be sure they are not ankle-twisters, though. No place for us to really do that the way things are set up so we would fill it right back up with rocks as designated by our excavator dude. 1 Share this post Link to post Share on other sites
SylvanLakeWH 27,556 #17905 Posted December 5, 2022 (edited) @ebinmaine 21aa will lock right up and not erode / move... Edited December 5, 2022 by SylvanLakeWH 2 4 1 Share this post Link to post Share on other sites
peter lena 9,089 #17906 Posted December 5, 2022 @Panther416-8 was going to say the smaller v trac tire with hundreds of extra lbs needs extra air , would get some extra grease in the front end joint areas , off the ground so the green grease comes out the top , probably help out , looks good pete 2 Share this post Link to post Share on other sites
peter lena 9,089 #17907 Posted December 5, 2022 https://www.walmart.com/ip/Champion-Electronics-Clamp-Light-with-8-5-Aluminum-Reflector-150W-CCL150-85/889980959? 2df342838346c230b7&gclsrc=3p.ds have these under my engines with incandescent rough service bulbs , silicone dipped , they stand on the squeeze clamp off floor , held in place with the center tech a matic bracket , just slightly warms the engine , and battery tender plug in , start ups are a non issue , using this for years , ready , pete 1 Share this post Link to post Share on other sites
ebinmaine 70,761 #17908 Posted December 5, 2022 1 hour ago, SylvanLakeWH said: @ebinmaine 21aa will lock right up and not erode / move... Yeah buddy I'm pretty sure that's basically what I've got. In my area we call that 3/4 Stone dust. Once it is compacted properly and a few rain storms get on it, it doesn't move anymore. 3 Share this post Link to post Share on other sites
TJ5208 1,824 #17909 Posted December 5, 2022 Well I bought another one. 4 3 Share this post Link to post Share on other sites
WHX?? 50,740 #17910 Posted December 5, 2022 5 hours ago, pfrederi said: Those are some head lights.... hope they are LEDs That 3 amp charging system might have an issue otherwise No they are not and funny you should mention that.,,, both diodes were toast. After I replaced them they liked to overcharge as high as 16 volts. The book says to remove one diode this happens.. An amp check is in order just for grins but I doubt I will ever use them. Prolly should hide one of those cheap 1 inch volt meters on it up under the hood, 1 Share this post Link to post Share on other sites
Monstrosity 1,146 #17911 Posted December 6, 2022 Got the blower attached to the front hitch and I need to cut the bracket and drill new holes BECAUSE I didn't realize this one bolted to the frame so I'll make it so that it'll attach to the front hitch. And i ordered the wrong hydro hoses from wheel horse parts and more (awesome customer service) and got the right ones coming! 5 1 Share this post Link to post Share on other sites
WHX?? 50,740 #17912 Posted December 6, 2022 What did you do FOR a today @Pullstart ?!?! BTW wish my girl a happy happy... hear tell she be getting a DL soon?? 1 2 Share this post Link to post Share on other sites
Pullstart 64,573 #17913 Posted December 6, 2022 On 12/4/2022 at 6:02 PM, Panther416-8 said: I'm not sure Sparkys toy but if the blower is lowered with the skid shoes in contact with the ground I don't imagine there would be much additional weight on the front axle from the blower. In that case it would be good to have the additional front wheel weights to help with traction/steering up front. I could be wrong, hopefully some others will chime in with their thoughts on this. BTW, the whole 2 stage blower is more like 360 lbs or so. The only thing I can add, is to turn your front tires around “backwards” for snow use. When you have them in “forward” arrangement, they turn into skids. Backwards, they actually grab and turn. 4 2 Share this post Link to post Share on other sites
Pullstart 64,573 #17914 Posted December 6, 2022 45 minutes ago, WHX?? said: What did you do FOR a today @Pullstart ?!?! BTW wish my girl a happy happy... hear tell she be getting a DL soon?? I did a run to mid MI today and grabbed a D series tiller for @jeremi3210 and Jacob of course… it’s a monster! Paul was a great host, with a propane heater, hot cup of Joe and he even started his awesome wood stove up too! Ran up to the big city after that and delivered a seat pan from Uncle Jim to AC Man Jeff’s cousin for his 520H Retro too. 7 Share this post Link to post Share on other sites
Pullstart 64,573 #17915 Posted December 6, 2022 And yes, Jada is 15 today! Happy Birthday Girl! 1 year and you can drive! Maybe we should start working on her truck (and a job) soon! 3 3 4 Share this post Link to post Share on other sites
ebinmaine 70,761 #17916 Posted December 6, 2022 23 minutes ago, Pullstart said: The only thing I can add, is to turn your front tires around “backwards” for snow use. When you have them in “forward” arrangement, they turn into skids. Backwards, they actually grab and turn. I concur. I've tested this on my 1974 C160 8 speed. 22" AGs on front. Definitely a difference. 2 Share this post Link to post Share on other sites
Pullstart 64,573 #17917 Posted December 6, 2022 53 minutes ago, ebinmaine said: Definitely a difference Look at me. Do I look like I’d be lying? 6 Share this post Link to post Share on other sites
ebinmaine 70,761 #17918 Posted December 6, 2022 8 hours ago, Pullstart said: like Nice shirt 1 1 1 Share this post Link to post Share on other sites
WHX?? 50,740 #17919 Posted December 6, 2022 13 hours ago, Pullstart said: Paul was a great host, So what else did he have?? No roundys peeking through weeds? Why is he not a member here or does he not need a support group? Share this post Link to post Share on other sites
Pullstart 64,573 #17920 Posted December 6, 2022 22 minutes ago, WHX?? said: So what else did he have?? No roundys peeking through weeds? Why is he not a member here or does he not need a support group? he’s on FB. Can’t win ‘em all! He has a cool 704 and a 59 RJ, but they are keepers. Lots of 3/4/500 series stuff, two D tractors, a GT14, lots of mower decks, and a 1054 he wants to plow with.. 4 Share this post Link to post Share on other sites
SylvanLakeWH 27,556 #17921 Posted December 6, 2022 Any battery electrics? 3 1 Share this post Link to post Share on other sites
RandyLittrell 3,894 #17922 Posted December 6, 2022 (edited) 14 hours ago, Pullstart said: And yes, Jada is 15 today! Happy Birthday Girl! 1 year and you can drive! Maybe we should start working on her truck (and a job) soon! I grew up in western Kansas where you used to be able to get your permit at 14 and drive to school and back, work and back plus during the job and with an adult. I drove a 76 chevy 4x4 with a 400 small block to school in 8th grade!! Happy Birthday and hope your Dad and you build a cool truck!! Randy Edited December 6, 2022 by RandyLittrell 2 Share this post Link to post Share on other sites
WHX?? 50,740 #17923 Posted December 6, 2022 26 minutes ago, SylvanLakeWH said: Any battery electrics? 1 Share this post Link to post Share on other sites
Pullstart 64,573 #17924 Posted December 6, 2022 37 minutes ago, SylvanLakeWH said: Any battery electrics? he had a handful of U1’s on the shelf… 1 Share this post Link to post Share on other sites
SylvanLakeWH 27,556 #17925 Posted December 6, 2022 24 minutes ago, Pullstart said: he had a handful of U1’s on the shelf… Any electric tractors attached to those batteries...??? Share this post Link to post Share on other sites
