peter lena 10,021 #16701 Posted August 26, 2022 @Bill Winn liked your red grease swipe ! that related linkage is often neglected , and flaky with rust , not even an issue with me , very easy to vastly improve function, lighter aerosol lube makes the rust run out , then red grease tube nozzle right into the neglected area , done ! that can also get addictive , with experimental make it better thoughts , can definitely relate to greasy improvements , pete 1 Share this post Link to post Share on other sites
Heatingman 977 #16702 Posted August 26, 2022 I made a deal on a distant cousin twice removed. Be picking it up tomorrow morning. 1961 International Cub Cadet - I know its not a WH - but I always wanted one, and its worth more as is then Im paying for it. Has a mowing deck. It dont run, but I’ll fix that one way or another once Im done with my B80 resto. bonus garden trailer included. 5 Share this post Link to post Share on other sites
Pullstart 71,144 #16703 Posted August 26, 2022 Mounted up the other Hoosier today… It’s easy to see it was on the left side of a race car with all the pink paint on it! 7 Share this post Link to post Share on other sites
peter lena 10,021 #16704 Posted August 26, 2022 @Heatingman when I typically go after any problem , I break it down for ENTIRE INTENDED FUNCTION , that view , makes me VERIFY EVERY PART of iTS SET UP DESIGN . just start tweaking on sloppy / rusty areas , how about a washer or 2 with some lubricant to enhance its function ? how about a light spring pull on throttle / choke cable to lever connection ? that entire mower deck drive set up , needed help , once I found the common culprit , wrong / minimal lubrication , leverage design / set up , cables that need pull assist / mounting areas. was actually not that difficult to make a sled drag , turn into a smooth easy working starting point of use , what a concept ! realise this is totally off the chart for many , you can't do that , also regularly use my 40 + year c85 as a test bed for ideas . work out the bugs , and install it on the other 2 horses . why not ? stayin crazy , pete 2 Share this post Link to post Share on other sites
Heatingman 977 #16705 Posted August 26, 2022 5 hours ago, Pullstart said: Mounted up the other Hoosier today… It’s easy to see it was on the left side of a race car with all the pink paint on it! Makin a street rod? 1 Share this post Link to post Share on other sites
Pullstart 71,144 #16706 Posted August 26, 2022 2 minutes ago, Heatingman said: Makin a street rod? There’s a pile of those old tires outside, so why not 1 1 Share this post Link to post Share on other sites
ineedanother 2,826 #16707 Posted August 27, 2022 Pulled the frame out from under what I believe is a 310-8 to hopefully re-purpose in a c-160 with a broken one. Not sure if it will work, definitely have to engineer a couple things... 5 2 Share this post Link to post Share on other sites
953 nut 68,678 #16708 Posted August 27, 2022 9 hours ago, ineedanother said: I believe is a 310-8 to hopefully re-purpose in a c-160 with a broken one. Front axle/mule drive mount probably will need to remain 310 to save a lot of needless work, otherwise probably a direct bolt up. Share this post Link to post Share on other sites
ebinmaine 80,428 #16709 Posted August 27, 2022 10 hours ago, ineedanother said: Pulled the frame out from under what I believe is a 310-8 to hopefully re-purpose in a c-160 with a broken one. Not sure if it will work, definitely have to engineer a couple things... 24 minutes ago, 953 nut said: Front axle/mule drive mount probably will need to remain 310 to save a lot of needless work, otherwise probably a direct bolt up. If the parts pile pictured above is the supposed 310-8 I'd say that's... Not a 310. Looks like a mid 70s B or C. The ID tag is circled in blue. Unless maybe that's the parts of the C160 setting on that pallet. ...? 3 Share this post Link to post Share on other sites
rjg854 13,327 #16710 Posted August 27, 2022 The engine does have a 10hp label on it. 1 Share this post Link to post Share on other sites
peter lena 10,021 #16711 Posted August 27, 2022 @ineedanother noting that original frame set up , have a few pieces of that angle steel in 3/8x 3 and 3/8 x 4 , from my working days , if I were building up an experiment , think I would go for a similar yet much stronger frame base start , duplicate original mounting holes , set up . really add terrific foundation strength in your build , just a brain fart , pete Share this post Link to post Share on other sites
ebinmaine 80,428 #16712 Posted August 27, 2022 4 minutes ago, rjg854 said: The engine does have a 10hp label on it. Yepp. If the parts in the pallet are what was disassembled that's a B100 or C100 from '74 to '77. Share this post Link to post Share on other sites
Lee1977 7,750 #16713 Posted August 27, 2022 11 hours ago, ineedanother said: Pulled the frame out from under what I believe is a 310-8 to hopefully re-purpose in a c-160 with a broken one. Not sure if it will work, definitely have to engineer a couple things... That's a 1977 or older frame for a B or C series tractor It's the right frame for a C-160. All C series 1978 and later, also the 300 400 and 500 have a senos set of 3/4" bars right in front of the rear wheels. 1 1 Share this post Link to post Share on other sites
ineedanother 2,826 #16714 Posted August 27, 2022 1 hour ago, ebinmaine said: Looks like a mid 70s B or C. I think you're correct @ebinmaine. Likely a b-100. I'll look at the tag when I get back over there but was really just glad to get my hands on it since the frame I have is in pretty bad shape. From what I can tell the major difference is that this one lacks the main lift bar and a small bracket for the right foot rest. Other than that I think things will swap over without any issues. Share this post Link to post Share on other sites
ebinmaine 80,428 #16715 Posted August 27, 2022 9 minutes ago, ineedanother said: one lacks the main lift bar and a small bracket for the right foot rest Those should be bolt on parts and switch over fine. 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,218 #16716 Posted August 27, 2022 Lawn day. Decided to remount the E141 mower deck and try it out. Wow! I like…! Quiet, quick, nice cut… 1/2 hour run time with deck and no issues with batteries… (3 - 12 volt batteries). I’m thinking another 15-30 minutes easy… I had deck listed for sale but nope. Gonna keep it. Although I must say, I like side discharge better… cleaner machine, better clipping dispersal… 4 3 Share this post Link to post Share on other sites
Handy Don 17,359 #16717 Posted August 27, 2022 1 hour ago, SylvanLakeWH said: Although I must say, I like side discharge better… cleaner machine, better clipping dispersal… I really like the 42" RDs for their cut and maneuverability for medium-sized lawns. Several of us have hung a 3-4" flap on the rear edge of the 42 RD, trimmed to miss the rear wheels, of course. I used cove base from the HD. It really settles the discharge down nicely and keeps the rear of the machine a lot tidier. 3 1 Share this post Link to post Share on other sites
Handy Don 17,359 #16718 Posted August 27, 2022 (edited) Yesterday I finished assembling a mower deck for the 854. It's an amalgam of parts mostly from an RM-367 but with some from a couple of RM-366's in there, as well. (Next week I'll be going through the leftover parts to see if I just stock the good ones or if I have enough to consider building a backup deck.) This morning I got it mounted and took it for a test spin on the dried grassy plain that used to be the front lawn. No loud noises, no parts thrown, no vibrations, belts are tracking smoothly and not getting thrown when engaging/disengaging the PTO, and, it cuts. I'm very pleased! I do have one question for those of you using one of these decks. I don't have any belt retainers anywhere. Should I, and where? The OM/IPL describes one on the engine (I suspect it uses the same bolt that holds the front of the drive belt guard. In pictures here on the forum, I've seen another that seems to be attached to the idler pulley, but I don't see a way to do that without messing with its alignment. I know its a detail and it seems to be working well now, but I'd like it to stay that way! And, to you sharp-eyed folks: yes, there is a six-speed LSD in this tractor, and yes, the hood is bare metal right now about to be painted! Edited August 27, 2022 by Handy Don 3 2 Share this post Link to post Share on other sites
Pullstart 71,144 #16719 Posted August 27, 2022 Watching some art happen… 4 1 3 Share this post Link to post Share on other sites
The Freightliner Guy 1,364 #16720 Posted August 27, 2022 You have a hot rod to what else do you have in there 1 Share this post Link to post Share on other sites
rick 310 #16721 Posted August 27, 2022 Not today, but yesterday I sharpened all six sets of blades for the 48" deck. Before I retired I used to buy a new set of blades instead of sharpening them, my skills sharpening with a grinder and a piece of round stock in a vise to balance the blades was not to my liking. MagnaMatic for the win... 2 Share this post Link to post Share on other sites
Pullstart 71,144 #16722 Posted August 27, 2022 2 hours ago, The Freightliner Guy said: You have a hot rod to what else do you have in there not my place 1 Share this post Link to post Share on other sites
Rob J. 1,944 #16723 Posted August 27, 2022 I bathed the 1045 with the big can of WD-40 and wiped it down today. Looks pretty good but might give it another can. Located a proper seat. Starting to feel like an orphanage or something. I go pick up a 753 pretty soon. Another Michigan tractor staying in Michigan. Pure Michigan baby! 7 5 Share this post Link to post Share on other sites
Wheelhorse#1 1,963 #16724 Posted August 27, 2022 2 hours ago, Rob J. said: I bathed the 1045 with the big can of WD-40 and wiped it down today. Looks pretty good but might give it another can. Located a proper seat. Starting to feel like an orphanage or something. I go pick up a 753 pretty soon. Another Michigan tractor staying in Michigan. Pure Michigan baby! Nice looking herd you have here.Is that original seat on the B80 fairly comfortable ? 1 Share this post Link to post Share on other sites
ebinmaine 80,428 #16725 Posted August 27, 2022 Pulled a fair sized tree stump outta the way. ..... 2 6 1 Share this post Link to post Share on other sites
