Rick3478 434 #16226 Posted July 10, 2022 2 hours ago, peter lena said: @Rick3478 https://www.bing.com/images/search?q=wheel+horse+pto+inner+needle+bearing&qpvt=WHEEL+HORSE+PTO+INNER+NEEDLE+BEARING&tsc=ImageHoverTitle&form=IGRE&first=1 you are talking about the outer bearing , I was talking about the inner bearing , sorry about not defining that .the inner bearing carries the horizontal cone load the outer bearing handles the pto lever engagement hand off . site pictures explain it all , that grease is made for hi loading temps , also anti sling , so a little goes a long way , pete Oh, I see, you're talking about the PTO. Sorry, didn't mean to be dense. The pulley I replaced is the clutch for the transmission drive, the one under the seat linked to the clutch pedal. It's a pressed together sealed ball assembly that most of us can't do much with except buy a replacement. 2 Share this post Link to post Share on other sites
Wheelhorse#1 1,761 #16227 Posted July 11, 2022 4 hours ago, Rick3478 said: It's a pressed together sealed ball assembly that most of us can't do much with except buy a replacement. You can drill the the spot welds out.Split the two half’s of the Pully,pull the old bearing out then replace. Rivet back together.If you have the time that is. Bearing is cheaper than buying a replacement Pully. I just did this…I’m cheap ! 2 Share this post Link to post Share on other sites
Kevin Bowley 140 #16228 Posted July 11, 2022 I installed new rubber motor mounts on my '78 c-161. Not something I want to ever do again! But it needed to be done as the old ones were delaminated and it had the shakes. 5 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,335 #16229 Posted July 11, 2022 Today I’ve broke the steering in my rj 5 Share this post Link to post Share on other sites
TJ5208 1,824 #16230 Posted July 11, 2022 23 hours ago, Achto said: Had my Raider 12 out for some exercise this morning. Probably the last time that I will be able to get through the pumpkin patch with the cultivator, they are really growing fast now. Pumpkins seem to be doing well. Patch looks real purty with all of the blooms. After a hard morning's work out, my Raider got to enjoy some spa time. Fully groomed & ready to go to a show next week. 3 1 2 Share this post Link to post Share on other sites
Snoopy11 5,717 #16231 Posted July 11, 2022 On 7/6/2022 at 3:53 PM, SylvanLakeWH said: Put some of the black back in the C 105 Black Hood… Rattle can Rustoleum satin black… That is gorgeous, buddy! WOW! I'm really diggin' it! If I ever get the hood straightened out on the 416... I may copy that look with the satin black... Don 1 1 1 Share this post Link to post Share on other sites
Rick3478 434 #16232 Posted July 11, 2022 20 hours ago, Wheelhorse#1 said: You can drill the the spot welds out.Split the two half’s of the Pully,pull the old bearing out then replace. Rivet back together.If you have the time that is. Bearing is cheaper than buying a replacement Pully. I just did this…I’m cheap ! Yeah, long way to go for a couple bucks vs. my time is worth something too. In only a little more than the time it took to write this, I searched it on eBay, ordered and was done with it. Car needs pads and rotors at the same time, I got the fronts done...I'm busy ! Share this post Link to post Share on other sites
D_Mac 9,156 #16233 Posted July 11, 2022 (edited) 8 hours ago, kbowley said: I installed new rubber motor mounts on my '78 c-161. Not something I want to ever do again! But it needed to be done as the old ones were delaminated and it had the shakes. I had a heck of a time when I replaced mine as well. I went with the solid mounts. Glad I did too. Edited July 11, 2022 by D_Mac 1 1 Share this post Link to post Share on other sites
ebinmaine 70,790 #16234 Posted July 12, 2022 I had decided yesterday it would be the Cinnamon Horse C160-8 that attended The Owl's Head Transportation Museum annual Truck And Tractor Show this year. I stopped on the way home to pick up a pair of tubes for the front tires I thought I had. I say it that way because when I got home I found that they were a fair mile narrower than I'd hoped. Well... That's what I have to use so that's what we went with. They're Carlisle of some sort but the tread is a FULL inch narrower than another Carlisle here. That's less than desirable because the wheels I have are a FULL inch wiiiiider than I remembered. 😂 Well I got them all mounted up with the standard amount of sweat and "sentence enhancers". The new BBT helped me remove the Mackissic chipper shredder and swap all four wheels and tires. Here's some before and after etc..... 3 5 Share this post Link to post Share on other sites
ineedanother 1,414 #16235 Posted July 12, 2022 Hey @ebinmaine, don't fret too much... the fronts remind me of a girl I once knew (kinda narrow on the top and bottom, but not so much in the middle), and the rear tires, well, let's just say those look pretty good on that red machine and leave it at that. 1 1 Share this post Link to post Share on other sites
Kevin Bowley 140 #16236 Posted July 12, 2022 (edited) 1 hour ago, ebinmaine said: I had decided yesterday it would be the Cinnamon Horse C160-8 that attended The Owl's Head Transportation Museum annual Truck And Tractor Show this year. I stopped on the way home to pick up a pair of tubes for the front tires I thought I had. I say it that way because when I got home I found that they were a fair mile narrower than I'd hoped. Well... That's what I have to use so that's what we went with. They're Carlisle of some sort but the tread is a FULL inch narrower than another Carlisle here. That's less than desirable because the wheels I have are a FULL inch wiiiiider than I remembered. 😂 Well I got them all mounted up with the standard amount of sweat and "sentence enhancers". The new BBT helped me remove the Mackissic chipper shredder and swap all four wheels and tires. Here's some before and after etc..... Eric, do you have a link to purchase those rear wheel spacers? Nice looking tractor! I like the color, looks great. Edited July 12, 2022 by kbowley 2 1 Share this post Link to post Share on other sites
ineedanother 1,414 #16237 Posted July 12, 2022 Short story (my intention at least), sorry no pictures but I might get some in the coming days... The WHs I've recently come to own are a bit of a hobby rather than a necessity. I have lots of stuff, as do my neighbors, that we share back and forth so no one has to have one of everything. It works out really well and my neighborhood is great. The neighbors across the street are really good folks, love them. 5 kids, but they're moving to Germany on in a couple weeks. They had 17 tons of topsoil dumped in their driveway last week to address some yard issues, by wheel barrow, not Wheel Horse. Tonight I offered my Auto12 and wagon to make the task a bit easier. Mind you now that my neighbor is every bit of 300 lb. and has never run a tractor of any sort. He ran mine around the yard a bit, we hooked up the trailer and off he went. He's a great guy and uses a trailer behind his jeep regularly so I'm not worried (it's just stuff), but this will no doubt be a new experience for him. Reports by text are that he's moved some 6 x 6 x 8 and will begin moving dirt in the morning. More to come, and hopefully some pics... 2 1 Share this post Link to post Share on other sites
8ntruck 7,395 #16238 Posted July 12, 2022 The proper PTO clutch bell for Clyde the C-195 arrived today. Needs a little wire brush work, paint, and bearing cleaning/greasing before it will be ready to go on the tractor. Got to pick up one of those small hitch pin thingies that pin the hoop onto the PTO stub shaft, too. That will be in a few days. I had to take an unexpected trip to our Ky. location today to help our son a little. I threw the chain saw into the back of the truck in case I get some time to do a bit of work in our patch of woods there. Had brain fade though. Last time I used the saw, I dinged the blade up bad enough that I took it out for sharpening. When I picked it up, I also bought a spare chain. Somewhere around Indy, I remembered that both chains were still sitting in boxes on my bench at home. 1 1 Share this post Link to post Share on other sites
ebinmaine 70,790 #16239 Posted July 12, 2022 5 hours ago, kbowley said: Eric, do you have a link to purchase those rear wheel spacers? Nice looking tractor! I like the color, looks great. Sure do. I'll PM you the info.. Thanks! Share this post Link to post Share on other sites
ebinmaine 70,790 #16240 Posted July 12, 2022 2 hours ago, 8ntruck said: Somewhere around Indy, I remembered that both chains were still sitting in boxes on my bench at home As you know the BBT and I go camping quite a bit. We keep a list of needed supplies. We check that list every time we go. We've been known to forget things, even then. Share this post Link to post Share on other sites
sjoemie himself 3,076 #16241 Posted July 12, 2022 7 hours ago, ebinmaine said: You could join the EU or Japanese car scene with those! I thought 'stretching' 'baggin' 'ricing' and 'stancing' only applied to cars? 4 Share this post Link to post Share on other sites
ebinmaine 70,790 #16242 Posted July 12, 2022 1 minute ago, sjoemie himself said: You could join the EU or Japanese car scene with those! I thought 'stretching' 'baggin' 'ricing' and 'stancing' only applied to cars? Geeeeez. Now everybody and their brother is going to want the look I accidentally produced. I guess I'm an accidental trendsetter??? 5 Share this post Link to post Share on other sites
sjoemie himself 3,076 #16243 Posted July 12, 2022 4 minutes ago, ebinmaine said: trendsetter For sure! Now would be the time to cut up those front spindles and rear axle housing to give it some much needed camber for better cornering and stuff.. 6 1 Share this post Link to post Share on other sites
D_Mac 9,156 #16244 Posted July 13, 2022 Brought it back home today. 7 1 Share this post Link to post Share on other sites
Blasterdad 3,039 #16245 Posted July 13, 2022 Got some seat time mowing, cut in around the house & trees with the C-81 & drained her oil while I finished with the C-120. It was perfect mowing weather today. 8 3 Share this post Link to post Share on other sites
The Freightliner Guy 1,335 #16246 Posted July 13, 2022 Today my rjs front tires are leaking even more fluid like substance 1 Share this post Link to post Share on other sites
WheelHorse520H 708 #16247 Posted July 14, 2022 This is more of "What Have I Done to my WH this week" but I finally finished rebuilding the greyhound engine for my 607, and have been breaking it in. I increased the compression about a year ago to get more power and efficiency by shaving the cylinder head down about 0.030" and because of this I have broke 3 pull ropes, one being the original, and two being made of Paracord. Now it runs great and starts the first pull every time. I changed the oil in it 2 or 3 times as I broke it in, and it seems to be doing very well. It still needs some small adjustments here and there, but overall it runs fabulous for being a 12 year old engine. On my 416 I took the top of the carb off and cleaned it, put in a new fuel line, changed the transmission fluid and filter, changed the engine oil and filter, and re-adjusted the governor. It used to idle around 2000 rpm for some reason, now it is back to the proper 1100. On my 520 I have been troubleshooting an issue with starting, I am planning on swapping the starter on my 416 with this one to see if it's the starter, or a wiring issue. That's about it here. 3 2 Share this post Link to post Share on other sites
D_Mac 9,156 #16248 Posted July 14, 2022 Got out the tiny paint brush and painted the KOHLER U.S.A to match the pinstripes. 4 5 Share this post Link to post Share on other sites
The Freightliner Guy 1,335 #16249 Posted July 14, 2022 Nice looks great D Mac 1 1 Share this post Link to post Share on other sites
squonk 42,579 #16250 Posted July 14, 2022 Haven't spent a lot of time lately. 14HP in and running. New loom for the wiring, new steering link. Retorque the head and timing to check then the hood and grill go back on. 7 3 Share this post Link to post Share on other sites
