ebinmaine 70,812 #15776 Posted May 16, 2022 (edited) 29 minutes ago, Monstrosity said: Could you share the link for that kit if possible? The kit I bought is no longer available. Prices have gone up as with many things lately. fleeeBay shows a kit for just under $80. If I was going to buy them today I'd order these 2 things. Total about $90. I've had good luck with this company so far. https://www.etrailer.com/Trailer-Hubs-and-Drums/etrailer/AKIHUB-545-2-EZ-1K.html https://www.etrailer.com/Trailer-Spindles/TruRyde/TRU94FR.html Edited May 16, 2022 by ebinmaine Wrong link 1 1 Share this post Link to post Share on other sites
Handy Don 13,340 #15777 Posted May 16, 2022 32 minutes ago, ebinmaine said: If I was going to buy them today I'd order these 2 things. Total about $90. I've had good luck with this company so far. You need two of each kit, of course! 3 Share this post Link to post Share on other sites
ranger 1,783 #15778 Posted May 16, 2022 (edited) On 5/16/2022 at 1:52 AM, ebinmaine said: Front wheel size really suits the tractor. with Ag’s on the rear, it’ll really stand out. I’ve just picked up two 7.00 x 14 and two 6.00 x 14 Firestone Ag’s, brand new with six stud wheels. Cost £35.00. From local vintage sale, now need to machine some adaptors, or weld in new centres, (or make some new hubs). Also fabricated a 3pt setup to mount a “Slug Pelleter” / “Fertiliser- Grass seed broadcaster”, (another local sale purchase, £15.00), to my C121. Edited May 17, 2022 by ranger Photos added 6 1 Share this post Link to post Share on other sites
Brockport Bill 1,825 #15779 Posted May 16, 2022 1 11 Share this post Link to post Share on other sites
ebinmaine 70,812 #15780 Posted May 16, 2022 17 minutes ago, Brockport Bill said: Musta Been a very small tank. 😂 1 4 Share this post Link to post Share on other sites
Wheelhorse#1 1,761 #15781 Posted May 16, 2022 Had some time after work to do some work on the ole 800.Added a couple switches to the dash,one for the head light and one for, soon to be installed rear spot light and ran the wires. Added wheel weights 45 pounds each.I just hope the Peerless tranny can Handel it going up hills.Will Soon find out 😁 7 1 Share this post Link to post Share on other sites
8ntruck 7,395 #15782 Posted May 16, 2022 While on my way home from a supply run in the next town over, I saw a late 60's square hood sitting in a front yard. No engine and a sign saying $200. Was on a time line, so I didn't stop. Gut reaction was that was kind of optimistic. 3 Share this post Link to post Share on other sites
Lee1977 7,044 #15783 Posted May 17, 2022 33 minutes ago, 8ntruck said: While on my way home from a supply run in the next town over, I saw a late 60's square hood sitting in a front yard. No engine and a sign saying $200. Was on a time line, so I didn't stop. Gut reaction was that was kind of optimistic. That was just a bit high unless it had four extra good tires. 3 Share this post Link to post Share on other sites
ebinmaine 70,812 #15784 Posted May 17, 2022 1 hour ago, 8ntruck said: While on my way home from a supply run in the next town over, I saw a late 60's square hood sitting in a front yard. No engine and a sign saying $200. Was on a time line, so I didn't stop. Gut reaction was that was kind of optimistic. 35 minutes ago, Lee1977 said: That was just a bit high unless it had four extra good tires. IIFF it has a 6 speed it's well worth it. 1 Share this post Link to post Share on other sites
Monstrosity 1,146 #15785 Posted May 17, 2022 Thanks! So now I'm positive everything is working as it should. It pulled a 18"x32" ground roller full of water about 300lbs with no issue at idle. Still need to figure out why parking brake lever won't move, need correct belt and need to change oils ASAP. Straight 30w is what the engine calls for right? And what is automotive type "A" automatic trans fluid can I use dex/merc fluid as I have atleast a case of that? Probably not going to being using much more after this just want to get PTO put together and all routing pulleys for snow thrower and mowing deck just so I can repaint everything together. I have a small decrepit trailer with 5 lug hubs that may fit this! @ebinmaine Fixed the ditch against the wall and leveled the pitch going to the wall. Pulled it upgrade with ease! 5 2 Share this post Link to post Share on other sites
Lee1977 7,044 #15786 Posted May 17, 2022 1 minute ago, ebinmaine said: IIFF it has a 6 speed it's well worth it. Not much way to check that transmission with out an engine. If they blew up the engine you have to assume they may have trashed the transmission. 1 Share this post Link to post Share on other sites
ebinmaine 70,812 #15787 Posted May 17, 2022 38 minutes ago, Monstrosity said: pulled a 18"x32" ground roller full of water about 300lbs with no issue at idle Excellent to see that ole rig working! Be aware that these engines are air cooled and splash oil lubed. The ONLY time they should be at idle is just before shut down. Also, the hydro transmission is air cooled. ALL driving/operating/working should be ¾ to full throttle. Can you show a pic of the transmission fluid you're asking about? 2 1 Share this post Link to post Share on other sites
8ntruck 7,395 #15788 Posted May 17, 2022 1 hour ago, Lee1977 said: Not much way to check that transmission with out an engine. If they blew up the engine you have to assume they may have trashed the transmission. I'm assuming it is a roller. If true, and if it is a gear jammer, I should be able to push it around in all of the gears. @ebinmaine - didn't think about it being a 6 speed. That's a limited slip, if I remember correctly. 1 Share this post Link to post Share on other sites
Monstrosity 1,146 #15789 Posted May 17, 2022 24 minutes ago, ebinmaine said: Can you show a pic of the transmission fluid you're asking about? Did a Google search it's the same fluid. If the fluid is DEXRON III compatible it is TYPE A compatible as well. So DEX/MERC is good fluid to use. I'm just going off the service manual. 1 1 Share this post Link to post Share on other sites
Lee1977 7,044 #15790 Posted May 17, 2022 22 minutes ago, 8ntruck said: I'm assuming it is a roller. If true, and if it is a gear jammer, I should be able to push it around in all of the gears. @ebinmaine - didn't think about it being a 6 speed. That's a limited slip, if I remember correctly. All I'm saying it's only worth what you can see. 2 Share this post Link to post Share on other sites
8ntruck 7,395 #15791 Posted May 17, 2022 1 hour ago, Lee1977 said: All I'm saying it's only worth what you can see. Yup. The fair price is the one that the seller and buyer agree upon. 2 Share this post Link to post Share on other sites
ebinmaine 70,812 #15792 Posted May 17, 2022 6 hours ago, 8ntruck said: I'm assuming it is a roller. If true, and if it is a gear jammer, I should be able to push it around in all of the gears. @ebinmaine - didn't think about it being a 6 speed. That's a limited slip, if I remember correctly. Both correct. Manual transmission Horses are usually savable or rebuildable. 1 Share this post Link to post Share on other sites
ebinmaine 70,812 #15793 Posted May 17, 2022 6 hours ago, Monstrosity said: Did a Google search it's the same fluid. If the fluid is DEXRON III compatible it is TYPE A compatible as well. So DEX/MERC is good fluid to use. I'm just going off the service manual. Check the COLOR of the fluid in your own transmission. It would have been ATF to start. There was/is a changeover point to engine oil by the mid 70s. Folks have been known to flush/fill with the oil. They can't be mixed so confirm which your machine has. 2 Share this post Link to post Share on other sites
Ed Kennell 40,547 #15794 Posted May 17, 2022 2 hours ago, ebinmaine said: Manual transmission and Hydro transmission Horses are usually savable 2 1 Share this post Link to post Share on other sites
peter lena 9,093 #15795 Posted May 17, 2022 @JPWH @Tony Toys , often refer to an opportunity while in a related area . rarely just do one thing in a spot , regularly see members fail to pick up or take advantage of A related issue . really ? if you are right there why not take advantage of it ? why not make a problem go away ? increase grounding or wire routing and cable wrapping, since going after my issues , the problems are gone . same goes for clunky / rusty linkage areas , why not make it solid and smooth / easy ? I refer to it because , I've been there , just an idea , you can make it better if you want to , pete 2 Share this post Link to post Share on other sites
ebinmaine 70,812 #15796 Posted May 17, 2022 1 hour ago, Ed Kennell said: Well played Ed. 1 Share this post Link to post Share on other sites
lynnmor 7,577 #15797 Posted May 17, 2022 12 hours ago, Wheelhorse#1 said: You should add a set of these: 2 1 4 Share this post Link to post Share on other sites
Wheelhorse#1 1,761 #15798 Posted May 17, 2022 49 minutes ago, lynnmor said: You should add a set of these: I was going to cut them flush but now you gave me a idea😉 1 2 Share this post Link to post Share on other sites
ebinmaine 70,812 #15799 Posted May 17, 2022 1 hour ago, lynnmor said: You should add a set of these: I like your thinkin' mister 1 Share this post Link to post Share on other sites
kpinnc 13,798 #15800 Posted May 17, 2022 15 hours ago, ebinmaine said: Musta Been a very small tank. 😂 If you haven't already, and really wanna have some food for thought- check how much $$ per mile you get these days... Our Tundra now costs $0.34 per mile to drive now in city MPG. That adds up in a big hurry! For us, MPG is 14 city and 22 highway. 2 Share this post Link to post Share on other sites
