Goldnboy 920 #15226 Posted April 10, 2022 Put on the ags and weights to prepare for garden tilling... 6 4 Share this post Link to post Share on other sites
WheelHorse520H 708 #15227 Posted April 10, 2022 Picked up a nice 416-H with some wheel weights and a home-made weight rack. Starts and runs good, glad to have tractor #3 here. Not to get the other 2 recommissioned. Photo Photo II Photo III Photo IV 5 Share this post Link to post Share on other sites
Horse Newbie 7,069 #15228 Posted April 11, 2022 3 hours ago, SylvanLakeWH said: Still looking for the oil drain plug on the E 141 You need to put an assistant in “charge” of it… 2 Share this post Link to post Share on other sites
davem1111 2,030 #15229 Posted April 11, 2022 I pulled the hydro pump back off of my 312-A, since it seems to be dead. (I have a thread going about this...). I think now I could probably remove one of these in about 5-10 minutes now (with the seat, fender & gas tank already off), assuming nothing is "frozen", and probably install one in about 15. My first removal took a while because it felt like the pump was welded to the housing. Took some conniving but it finally came off. Now hoping I can get a "known good" replacement pump for a reasonable price. 1 Share this post Link to post Share on other sites
balconio 606 #15230 Posted April 11, 2022 On 4/9/2022 at 8:12 PM, 76c12091520h said: One of my babies got hitched today....... That looks like a well made piece for sure. By far the most used accessory on my horse aside from the mower deck is the 2" rear receiver. With the ball hitch pinned on I tow my 4x8 harbor freight "yard cart" around with it, but it's also perfect for skidding logs and moving the camper and sailboat from the yard to the driveway. I also have a winch, MoJack tool rack, and an ATV rack that are all super useful. 2 1 Share this post Link to post Share on other sites
ranger 1,750 #15231 Posted April 11, 2022 On 4/10/2022 at 12:33 PM, ebinmaine said: 20", 21" / 50, 55 cm outside diameter? 20” on the front, 25” on the rear.🇺🇸 508mm front, 635mm rear.🇬🇧 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,297 #15232 Posted April 11, 2022 I hate putting tubes in tractor tires. Only got one of 4 done. Enough said . 2 Share this post Link to post Share on other sites
squonk 41,107 #15233 Posted April 11, 2022 29 minutes ago, elcamino/wheelhorse said: I hate putting tubes in tractor tires. Only got one of 4 done. Enough said . I was outside today getting the ElCamino 800 out of the shed. The wind was a blowin pretty good. Figured you were doin somethin! 3 Share this post Link to post Share on other sites
JoeM 7,874 #15234 Posted April 11, 2022 Worked on putting together the first set of duals. Those Farm Specialist tires are tough to work with when your not trying to bugger up the rims. Talk about a Jane Fonda workout! 8 10 Share this post Link to post Share on other sites
SylvanLakeWH 25,557 #15235 Posted April 11, 2022 3 minutes ago, JoeM said: Worked on putting together the first set of duals. Those Farm Specialist tires are tough to work with when your not trying to bugger up the rims. Talk about a Jane Fonda workout! Looks great! What type of spacer did you end up using? 2 1 Share this post Link to post Share on other sites
Ed Kennell 38,171 #15236 Posted April 11, 2022 I had plans to replace the axle seal on the 312. Three hours and the hub moved 3/4". Let it soak and try it tomorrow. 1 4 Share this post Link to post Share on other sites
lynnmor 7,306 #15237 Posted April 11, 2022 12 minutes ago, Ed Kennell said: I had plans to replace the axle seal on the 312. Three hours and the hub moved 3/4". Let it soak and try it tomorrow. You can borrow my tool, let me know if you want it. 1 1 Share this post Link to post Share on other sites
JoeM 7,874 #15238 Posted April 11, 2022 51 minutes ago, SylvanLakeWH said: What type of spacer did you end up using? made these shorter versions up. 7 2 1 Share this post Link to post Share on other sites
sjoemie himself 3,068 #15239 Posted April 11, 2022 1 hour ago, JoeM said: That looks tasty! If I can find more rims for less than an arm and a leg I might try to put duals on my project aswell. Just instantly says 'tractor' instead of 'lawnmower' imho. 3 1 Share this post Link to post Share on other sites
JoeM 7,874 #15240 Posted April 11, 2022 2 hours ago, Ed Kennell said: Three hours and the hub moved 3/4". Ed you think it is rust or a key issue? Seem like when they start to move the come on off. ??? 1 Share this post Link to post Share on other sites
ebinmaine 67,492 #15241 Posted April 11, 2022 3 minutes ago, JoeM said: Seem like when they start to move the come on off. ??? Could still be rust. I've had the lovely things do that too. 2 Share this post Link to post Share on other sites
Ed Kennell 38,171 #15242 Posted April 12, 2022 15 hours ago, lynnmor said: You can borrow my tool, let me know if you want it. Thanks Lynn...I'll see if it moves today and let you know. 1 Share this post Link to post Share on other sites
Ed Kennell 38,171 #15243 Posted April 12, 2022 13 hours ago, JoeM said: Ed you think it is rust or a key issue? Seem like when they start to move the come on off. ??? I can see 1/2 of the key and it looks like it is in place and not damaged, so it must just be the rust. I don't have a bearing splitter so I actually cut 1 1/8" flat washers into C shaped spacers and wedged those between the hub and transmission case, then used a BFH to shock it loose. This did work and it is moving, but looks like it will be a fight to the finish. 3 Share this post Link to post Share on other sites
ebinmaine 67,492 #15244 Posted April 12, 2022 26 minutes ago, Ed Kennell said: . This did work and it is moving, but looks like it will be a fight to the finish. 💪 Get em.. 1 Share this post Link to post Share on other sites
JoeM 7,874 #15245 Posted April 12, 2022 30 minutes ago, Ed Kennell said: BFH to shock it loose. better to heat than beat! 2 Share this post Link to post Share on other sites
Ed Kennell 38,171 #15246 Posted April 12, 2022 3 hours ago, JoeM said: better to heat than beat! I did heat it Joe. It still took a rap to get it started. It banged like a shotgun when it popped loose. 2 Share this post Link to post Share on other sites
Ed Kennell 38,171 #15247 Posted April 12, 2022 It's off. The key was OK and in place. I know pulling on that flange is not a good practice, but that is what I had at the time. For the next one, I'll make a proper puller or borrow Lynns. @lynnmor Next challenge...get the key out. I cut a small notch in the end to get a chisel under and was able to tap it loose. Alll cleaned up and nice sliding fit going back together. The new NAPA seal will be in tomorrow. Mike. @squonk, I gave your number 11124 to my local guy and he says the new NAPA # is 27SS2259. $9.69 each 5 2 Share this post Link to post Share on other sites
squonk 41,107 #15248 Posted April 12, 2022 @Ed Kennell Funny. That # doesn't even come up in my Napa Prolink. If I go to Napa online it says it's not available in my region. Hope it shows up. Knowing Napa they are changing suppliers again and have the cart before the horse! 2 1 Share this post Link to post Share on other sites
Maxwell-8 4,275 #15249 Posted April 12, 2022 51 minutes ago, Ed Kennell said: Next challenge...get the key out. A trick I use: are these kind of wire cutters Makes removing those keys real easy. even when pretty stuck 3 3 1 Share this post Link to post Share on other sites
OutdoorEnvy 1,522 #15250 Posted April 12, 2022 Cleaned up some old wheels today and was pleasantly surprised at the results... These are from my 1974 C100 project. I'm wanting it to be as original as it can be and keep the old vintage look. I wasn't wanting to repaint anything but I do not like the look of rust, and especially on WHITE! So was skeptical on how these wheels would turn out. Surprisingly the rust came off and left original paint mostly there. It'll be the perfect original aged but not crappy look I'm going for. So all I did was use 220 grit sandpaper soaked in water and dawn dish soap and wet sanded them down. Only pressing as hard as needed to get the rust coming off. Not hard enough to go through the paint. Anyways... I like how they turned out. Here's a before and after of one of them 8 4 Share this post Link to post Share on other sites
