pfrederi 18,346 #14451 Posted January 29, 2022 7 minutes ago, kpinnc said: The design like any other has room for improvement. I think if it were a horrible design there wouldn't be thousands of them still working 50-60 years later. It works just fine when used for the loads it was intended for. WHs are tough but they are Garden Tractors.. Start using them like bulldozers or skid steer and guess what... 3 1 Share this post Link to post Share on other sites
kpinnc 13,798 #14452 Posted January 29, 2022 1 minute ago, pfrederi said: Start using them like bulldozers or skid steer and guess what... Exactly. I made some reinforcement for the Bronco because I have a disc set that weighs about 250 lbs. Extending it out almost two feet behind the tractor adds quite a bit of leveraged force on that plate. ...but that tractor was not designed for those forces to be applied. 4 2 Share this post Link to post Share on other sites
Oldskool 6,660 #14453 Posted January 29, 2022 When I built Hirams frame I made an integral cradle from the trans. 1 10 Share this post Link to post Share on other sites
Oldskool 6,660 #14454 Posted January 29, 2022 Snow has started to fall. I'm getting closer to having a new plow tractor. Front weights and chains are on so far. 3 2 1 Share this post Link to post Share on other sites
Ed Kennell 40,547 #14455 Posted January 29, 2022 3 minutes ago, Oldskool said: Snow has started to fall. I'm getting closer to having a new plow tractor. Front weights and chains are on so far. Be careful with he overrun on the winch. When I had that setup I had to install a big spring in line after breaking some parts. 2 3 Share this post Link to post Share on other sites
953 nut 58,024 #14456 Posted January 29, 2022 24 minutes ago, Oldskool said: Snow has started to fall. I'm getting closer to having a new plow tractor. Front weights and chains are on so far. Looks like the winch will be pulling back on the plow frame rather than up. May want to run the cable through a pulley block near the top of your brush bar. 5 Share this post Link to post Share on other sites
Lee1977 7,044 #14457 Posted January 29, 2022 If your using the remote, you need to disconnect the power when not using it as it will pull the battery down. I just disconnect the ground wire from the battery when it's not needed. Was going to put a 30 amp big truck light switch on it never got around to order one. 3 Share this post Link to post Share on other sites
Oldskool 6,660 #14458 Posted January 29, 2022 All good info guys. Thanks. I definitely will be changing a few things after this big snow. I'm running out of time at the moment. It's already snowing like heck 2 Share this post Link to post Share on other sites
Ed Kennell 40,547 #14459 Posted January 29, 2022 1 hour ago, 953 nut said: . May want to run the cable through a pulley block near the top of your brush bar. Yes, good idea Richard. That would also allow more room to install a safety spring. The anchor point on the plow frame could also be moved back so the lift cable is vertical. 3 Share this post Link to post Share on other sites
Oldskool 6,660 #14460 Posted January 29, 2022 5 minutes ago, Ed Kennell said: Yes, good idea Richard. That would also allow more room to install a safety spring. The anchor point on the plow frame could also be moved back so the lift cable is vertical. Lol I just moved the anchor point. Wrapped a short chain around the push tubes. Connected with a shackle which is where the hook is snapped in. 3 Share this post Link to post Share on other sites
Ifixoldjunk 778 #14461 Posted January 29, 2022 @johnnymag3 Hudson valley too. My job involves a lot of snow removal this time of year and that’s what we’re all being told. So far we’ve had around 3in and it just keeps coming. 2 Share this post Link to post Share on other sites
Ifixoldjunk 778 #14462 Posted January 29, 2022 18 hours ago, kpinnc said: The only ones I've ever seen break were from wheelies. It's a fair bet that if you get one that is broken, that or something similar caused it. There are several folks on here however, who have made nice braces under there for just such a concern. The pic below is not mine, but a good example. How well do those reinforcements clear the decks? I’ve been thinking about building some for the my 310 because it’s my primary wood hauler. 3 Share this post Link to post Share on other sites
Oldskool 6,660 #14463 Posted January 29, 2022 Rear ice chains are on along with the wheel weights and another 50lbs of weight. I think Hiram is as ready as he is going to be for this storm. If he does well maybe a cab will be something to think about. Time for a hot beverage and watch this white stuff pile up. 2 6 Share this post Link to post Share on other sites
kpinnc 13,798 #14464 Posted January 29, 2022 1 hour ago, Ifixoldjunk said: How well do those reinforcements clear the decks? I’ve been thinking about building some for the my 310 because it’s my primary wood hauler. Shouldn't be an issue. It's parallel with the belt guard. 2 Share this post Link to post Share on other sites
johnnymag3 2,559 #14465 Posted January 29, 2022 2 hours ago, Ifixoldjunk said: @johnnymag3 Hudson valley too. My job involves a lot of snow removal this time of year and that’s what we’re all being told. So far we’ve had around 3in and it just keeps coming. I ended up with 5 inches total in Clinton Corners. I take care of a bunch of local driveways, been doin it since 1989...same people.....same drives.....same truck.....same western uni-mount. Truck is it sit this year 2021 Sept. 205K....no issues.5.7 1 4 Share this post Link to post Share on other sites
Horse Newbie 7,202 #14466 Posted January 29, 2022 20 minutes ago, johnnymag3 said: Truck is it sit this year 2021 Sept. 205K....no issues.5.7 What year is the truck?… I have a 98’, 270,000 m, 5.7 liter Vortec. 3 Share this post Link to post Share on other sites
Ifixoldjunk 778 #14467 Posted January 29, 2022 @johnnymag3looks like you’ve taken care of that truck to get those years out of it. I’m hopefully replacing my 98 ram 1500 this weekend. NY salt finally got to her. 1 3 Share this post Link to post Share on other sites
Ifixoldjunk 778 #14468 Posted January 29, 2022 the single stage cut through this light fluffy 4-6in of snow like it was butter. That was the kind of snow I wanted to see all season. Did most of the driveway with my snowplow, but had to make a nice bathroom area for the dog with the blower.😅 6 4 Share this post Link to post Share on other sites
TonyToro 1,101 #14469 Posted January 30, 2022 16 hours ago, Ifixoldjunk said: the single stage cut through this light fluffy 4-6in of snow like it was butter. That was the kind of snow I wanted to see all season. Did most of the driveway with my snowplow, but had to make a nice bathroom area for the dog with the blower.😅 Nice! I was working since Friday 11pm came home midnight Saturday and today seat time on the C145 to make some paths for our pup. 1 1 Share this post Link to post Share on other sites
TonyToro 1,101 #14470 Posted January 30, 2022 20 hours ago, Oldskool said: Rear ice chains are on along with the wheel weights and another 50lbs of weight. I think Hiram is as ready as he is going to be for this storm. If he does well maybe a cab will be something to think about. Time for a hot beverage and watch this white stuff pile up. Your machine looks great! Did you get any video? My son and I want to see it doing work. 1 1 Share this post Link to post Share on other sites
johnnymag3 2,559 #14471 Posted January 30, 2022 19 hours ago, Horse Newbie said: What year is the truck?… I have a 98’, 270,000 m, 5.7 liter Vortec. 1989....I love it Neighbors think I am crazy to be washing it after plowing....10 degrees outside....hot water was. Solid as can be for 32 years old....and a plow truck with those miles...LOTS of regular services, makes a huge difference 2 2 Share this post Link to post Share on other sites
D_Mac 9,156 #14472 Posted January 30, 2022 Well living in western NY you better have something to move a lot of snow around. I normally use my snowblower, but so far this year I have only used this 875 to plow my driveway. I have high curbing on both sides of my driveway, making plowing it a little difficult. Way more fun sitting on the tractor plowing then walking behind a snowblower. Might have to just sell that blower!! 3 7 Share this post Link to post Share on other sites
KrazeyOlDave 860 #14473 Posted January 30, 2022 If there’s any witchcraft folks here, might you please cast a spell for me…I need snow, can’t plow, not happy, very sad, feeling robbed 😂 4 Share this post Link to post Share on other sites
Oldskool 6,660 #14474 Posted January 30, 2022 4 hours ago, TonyToro said: On 1/29/2022 at 11:55 AM, Oldskool said: Your machine looks great! Did you get any video? My son and I want to see it doing work. Thanks. No I didn't. That HF winch stopped working 10ft out of the garage 5 Share this post Link to post Share on other sites
Lee1977 7,044 #14475 Posted January 30, 2022 On 1/29/2022 at 12:06 PM, kpinnc said: Shouldn't be an issue. It's parallel with the belt guard. The only thing I have found is the level adjustment rod may rub on the one on the left side. I just bent the bar across the deck out a little to clear. 1 Share this post Link to post Share on other sites
