peter lena 8,625 #13626 Posted November 22, 2021 @76c12091520h bob , being a lubrication nut , I regularly marvel at the rusted state of the exposed wheel well / chassis areas in virtually new trucks . none of my stuff is lie that , my cure for that is LUBRIPLATE , CHAIN AND CABLE SPRAY AND LUBRIPLATE OPEN GEAR HEAVY DUTY EXTREME PRESSURE AEROSOL LUBES. nothing stays with metal like this stuff , moving up garage door co , https://www.movingupgaragedoors.com/lubriplate-l0152-063-gear-shield-extra-heavy-lubricant has the best prices . , no rust and stands up , pete 2 Share this post Link to post Share on other sites
Maxwell-8 4,275 #13627 Posted November 22, 2021 Oopps, she wont fit even with a 2" hood lift. 2 1 6 Share this post Link to post Share on other sites
Handy Don 12,218 #13628 Posted November 22, 2021 1 hour ago, Maxwell-8 said: Oopps, she wont fit even with a 2" hood lift. Time to get creative, there! You'll think of something, I'm sure. 2 1 Share this post Link to post Share on other sites
Oldskool 6,644 #13629 Posted November 23, 2021 It's getting time to put some horses away for the winter. There are alot of batteries to keep charged. Could I hook them all together and charge all at once? All positives together all negatives together. 1 Share this post Link to post Share on other sites
Gregor 4,846 #13630 Posted November 23, 2021 35 minutes ago, Oldskool said: There are alot of batteries Define a lot. I would like to bring all of mine up to the heated garage, but 11 batteries is a lot to find room for. I know there are some with more tractors than I. What do you do with the batteries you don't intend to use for the next 4 - 5 months? 1 Share this post Link to post Share on other sites
953 nut 55,228 #13631 Posted November 23, 2021 46 minutes ago, Oldskool said: put some horses away for the winter. There are alot of batteries to keep charged Only good way to keep them charged is to drive each one at least every-other week. 3 2 Share this post Link to post Share on other sites
ebinmaine 67,492 #13632 Posted November 23, 2021 7 minutes ago, 953 nut said: Only good way to keep them charged is to drive each one at least every-other week. I was going to suggest once a month but I only have four or five tractors to winter over. Not 10 or more or whatever. 4 Share this post Link to post Share on other sites
Gregor 4,846 #13633 Posted November 23, 2021 Once there is snow on the ground, there is no way to get them out of where they are. I'll post a pic once the sun comes up. 3 Share this post Link to post Share on other sites
SylvanLakeWH 25,557 #13634 Posted November 23, 2021 Warm and fully charged is the way I prefer to store them. Use meter to check voltage. If they need a boost charge them. 2 Share this post Link to post Share on other sites
squonk 41,108 #13635 Posted November 23, 2021 1 hour ago, Oldskool said: It's getting time to put some horses away for the winter. There are alot of batteries to keep charged. Could I hook them all together and charge all at once? All positives together all negatives together. If you keep batteries connected with out a constant charger a weak battery will draw down the others. I have 7 batteries to maintain so 7 battery tenders. 2 3 Share this post Link to post Share on other sites
cleat 5,970 #13636 Posted November 23, 2021 Mine for 6 of my tractors and 2 cars I just make sure are fully charged then put on a shelf that I mounted high in the shop out of the way. They sit there until spring. Never had one lose a charge over the winter yet. Shop is heated though so they would never freeze. 4 Share this post Link to post Share on other sites
Roger R 447 #13637 Posted November 23, 2021 No problem connecting all and maintaining charge. I made up a "harness" and can connect all or any of my batteries to a trickle / maintenance charger. Not a bad idea to make sure each on is fully charged with your regular charger first. 5 Share this post Link to post Share on other sites
Gregor 4,846 #13638 Posted November 23, 2021 All of my tractors are under my garage, except for the 656. It has the snowblower? on it, up in the garage. I sometimes have trouble getting up into the door on wet grass, let alone snow. All the batteries except 2 are less than a year old. Even getting the batteries out of the tractors would be a chore. "The children were nestled, all snug in their beds, while visions of spring time danced in their heads" 5 1 8 Share this post Link to post Share on other sites
ebinmaine 67,492 #13639 Posted November 23, 2021 2 minutes ago, Gregor said: Even getting the batteries out of the tractors would be a chore If you can reach the batteries in the individual tractors to charge them I'd leave them right there. Figure out the timing to put a one or two amp charge for about 24 hours in each tractor maybe once a month? 2 Share this post Link to post Share on other sites
Maxwell-8 4,275 #13640 Posted November 23, 2021 2 hours ago, Oldskool said: It's getting time to put some horses away for the winter. There are alot of batteries to keep charged. Could I hook them all together and charge all at once? All positives together all negatives together. And get the Y.E.T.I. ready for action! 1 2 Share this post Link to post Share on other sites
Tuneup 1,433 #13641 Posted November 23, 2021 If the batteries to be placed in parallel are all of the same capacity AND they are all of similar level of charge at the start, no worries. The highest charged unit will discharge into the lowest until they all stabilize. Potentially, that's a pant load of current. Picture jumping a car battery when the cables are connected. The trickle charger will have quite the job as well! Be careful. 2 1 Share this post Link to post Share on other sites
chip61 658 #13642 Posted November 23, 2021 connecting them together seemed to work for a few years, then one year one battery went down, pulling the others down and causing all the batteries to overcharge even with a maintainer (at least I guess that's what happened I had 4 bad batteries at once). Now I have a couple maintainers that I move around from battery to battery every week or two and that seems to work fine. The couple tractors I use year round don't have any problem. 4 1 Share this post Link to post Share on other sites
Handy Don 12,218 #13643 Posted November 23, 2021 2 hours ago, Roger R said: No problem connecting all and maintaining charge. I made up a "harness" and can connect all or any of my batteries to a trickle / maintenance charger. Not a bad idea to make sure each on is fully charged with your regular charger first. Italics and underscore added. Trickle chargers typically do not have the capacity to charge a battery (hence the term "trickle"). Having the batteries all fully charged before ganging them up is necessary. Also, as noted, a failed battery can "bring down" all the others in the "gang". 3 Share this post Link to post Share on other sites
Maxwell-8 4,275 #13644 Posted November 23, 2021 Our trickle charger can charge up to 5 amps I believe. plenty for U1 30AH battery no? Trickle chargers are the only chargers I like with a "brain" 1 Share this post Link to post Share on other sites
Horse Newbie 7,069 #13645 Posted November 23, 2021 One Battery Tender per battery… 1 Share this post Link to post Share on other sites
Maxwell-8 4,275 #13646 Posted November 23, 2021 Do you guys keep them constantly plugged in? Is that not a fire hazard? I think my fire insurance states something about it... 2 Share this post Link to post Share on other sites
Handy Don 12,218 #13647 Posted November 23, 2021 16 minutes ago, Maxwell-8 said: Our trickle charger can charge up to 5 amps I believe. plenty for U1 30AH battery no? Trickle chargers are the only chargers I like with a "brain" That isn't a trickle charger -- it is a full range charger that can throttle down to a trickle! I'd read its instructions carefully as I doubt it was intended to be connected to more than one or two batteries at the same time. Trickle chargers (or more commonly "battery tenders") typically deliver 0.8 amps or less. 2 2 Share this post Link to post Share on other sites
Oldskool 6,644 #13648 Posted November 23, 2021 4 hours ago, Gregor said: Define a lot. I would like to bring all of mine up to the heated garage, but 11 batteries is a lot to find room for. I know there are some with more tractors than I. What do you do with the batteries you don't intend to use for the next 4 - 5 months? Well I was thinking 8 was alot lol. In retrospect not so much lol 2 Share this post Link to post Share on other sites
Oldskool 6,644 #13649 Posted November 23, 2021 2 hours ago, Maxwell-8 said: And get the Y.E.T.I. ready for action! I still have a bit to do yet on the Y.E.T.I. I ended up with a project that jumped ahead in line. 2 Share this post Link to post Share on other sites
Maxwell-8 4,275 #13650 Posted November 23, 2021 1 minute ago, Oldskool said: I still have a bit to do yet on the Y.E.T.I. I ended up with a project that jumped ahead in line. oooww Can't wait 2 1 Share this post Link to post Share on other sites
