Pullstart 62,864 #13451 Posted November 7, 2021 16 hours ago, AMC RULES said: Set up the Honda-Horse with it's 54" plow today. Craig though it looks funny, you might want to turn those fronts around during snow season Share this post Link to post Share on other sites
AMC RULES 37,130 #13452 Posted November 7, 2021 (edited) Will give it a try... just for you der die das Hosen. Edited November 7, 2021 by AMC RULES 1 1 2 Share this post Link to post Share on other sites
AMC RULES 37,130 #13453 Posted November 7, 2021 Scored the mother load of Sears weights today. Just a tick over 32lbs each, think I did OK for $80. Also, got the solid 50lb Jacobsen set I got back from the Squonk mounted up on the Honda-Horse today as well. 4 6 Share this post Link to post Share on other sites
Handy Don 12,217 #13454 Posted November 7, 2021 12 minutes ago, AMC RULES said: Scored the mother load of Sears weights today Covers your next four tractors! 2 1 Share this post Link to post Share on other sites
rjg854 11,361 #13455 Posted November 7, 2021 Nice part of that style of weight is that you can stack them, if you choose to. 3 Share this post Link to post Share on other sites
ebinmaine 67,487 #13456 Posted November 7, 2021 4 minutes ago, Handy Don said: Covers your next four tractors! Nahhh. Double em up. More weight the better!! @AMC RULES VERY nice score there! 2 Share this post Link to post Share on other sites
ebinmaine 67,487 #13457 Posted November 7, 2021 2 minutes ago, rjg854 said: Nice part of that style of weight is that you can stack them, if you choose to. On some wheels you can do inside/outside mounting too. Easily get 3 weights per wheel. 2 Share this post Link to post Share on other sites
squonk 41,105 #13458 Posted November 7, 2021 8 hours ago, Pullstart said: Craig though it looks funny, you might want to turn those fronts around during snow season Yup turn AG's around for steering. 2 Share this post Link to post Share on other sites
Handy Don 12,217 #13459 Posted November 7, 2021 31 minutes ago, ebinmaine said: Nahhh. Double em up. More weight the better!! @AMC RULES VERY nice score there! 29 minutes ago, ebinmaine said: On some wheels you can do inside/outside mounting too. Easily get 3 weights per wheel. So one really heavy tractor! 2 Share this post Link to post Share on other sites
Pullstart 62,864 #13460 Posted November 7, 2021 31 minutes ago, ebinmaine said: On some wheels you can do inside/outside mounting too. Easily get 3 weights per wheel. those weights don’t quite have a big enough hole to clear the hub… Nice score nonetheless Craig! Almost beats my set of 4 for free on a SS12 on the side of the road a few years back! 5 3 Share this post Link to post Share on other sites
Maxwell-8 4,275 #13461 Posted November 9, 2021 Started a small side project, You see where this is going? 3 7 Share this post Link to post Share on other sites
ebinmaine 67,487 #13462 Posted November 9, 2021 2 minutes ago, Maxwell-8 said: Started a small side project, You see where this is going? I Love it! Front mounted air compressor is on my list of things to build. I'd suggest a complete separate thread dedicated to all that's done to create and build an that as an implement. 2 2 1 Share this post Link to post Share on other sites
Maxwell-8 4,275 #13463 Posted November 9, 2021 1 minute ago, ebinmaine said: I Love it! Front mounted air compressor is on my list of things to build. I'd suggest a complete separate thread dedicated to all that's done to create and build an that as an implement. First need to get some materials, but then, a separate thread sure will be opened. I already know you would like it. and seeing @Pullstart compressor gave me the final push! 2 1 1 Share this post Link to post Share on other sites
Pullstart 62,864 #13464 Posted November 9, 2021 Looking forward to the build @Maxwell-8! 1 1 Share this post Link to post Share on other sites
ebinmaine 67,487 #13465 Posted November 9, 2021 @JCM Jim came by today. We spent some time messing about with one of the recently aquired 417As. Jim did a bunch of muck removal and general cleaning. I did some diagnostics on the electric system. After a few hours we had fire in the hole!! Just for kicks I also tossed/hucked/chucked a batt-tree in the 1974 C160 Tecumseh engine tractor. It fired right up!!! 5 9 Share this post Link to post Share on other sites
rjg854 11,361 #13466 Posted November 9, 2021 I took the deck off the c-160 today tore that apart by removing the recycler insert and scraped it all down, oiled it up real good. Stored it away for the winter then changed the oil and transmission oil and filter. Tomorrow I'll grease everything and put the plow and chains on. Weather changes next week with a highs only in the 40s so it's only a matter of time. 7 Share this post Link to post Share on other sites
AHS 1,440 #13467 Posted November 9, 2021 @ebinmaine Sweet! Awesome!! I had 414-8 time today. Adjusted the main jet. Drained the rear end oil... yum! 😀 It runs as it should. New carb. 6 2 Share this post Link to post Share on other sites
ebinmaine 67,487 #13468 Posted November 9, 2021 4 minutes ago, AHS said: @ebinmaine Sweet! Awesome!! I had 414-8 time today. Adjusted the main jet. Drained the rear end oil... yum! 😀 It runs as it should. New carb. That looks delicious! 1 Share this post Link to post Share on other sites
Maxwell-8 4,275 #13469 Posted November 9, 2021 5 minutes ago, ebinmaine said: That looks delicious! mmmh pumpkin soup with cream 1 4 Share this post Link to post Share on other sites
Andy N. 2,154 #13470 Posted November 9, 2021 Yesterday I got the key switch installed on the '86 417-A and went for a test drive/mow. This was a solid machine when I got it a month ago, just needed some TLC. I gave it a really good cleaning, idler pulley, sleeve hitch installed (thanks again @wheelhorseman), painted wheels and new tires, new key switch, Kirk Engines transdenser II electronic ignition (https://kirkengines.com if anyone is interested), new foot runners, new drive belt, LED headlights and tail lights, painted engine baffles, painted seat pan, foot rests and side covers, replaced front axle spindles and axle pin and plate. When I bought it, it had 6" wheels on the front. I did not have a spare set of 8" wheels to put on it, but I just found a set on eBay that is being shipped that will go on it once they are rebuilt. First video is tractor running. Second video is tractor and mower deck running. The deck was so quiet, I decided I need to replace the spindle bearings on my other decks. The mower deck got new pulleys, wheels, belt, rebuilt spindles, and painted Pour 15 on the underside. Blade were in good enough shape since they were installed upside down, that all I had to do was sharpen them. Still need to do some work on the tiller and plow blade and then it will go to my sister in KY. And yes, this was more than just today. IMG_0781.mp4 IMG_0782.mp4 IMG_0835.mp4 IMG_0838.mp4 IMG_0839.mp4 4 3 1 Share this post Link to post Share on other sites
JCM 9,165 #13471 Posted November 9, 2021 Looks like hot mustard at the Chinese restaurant @AHS Goes good with the pork fried rice. 4 Share this post Link to post Share on other sites
ebinmaine 67,487 #13472 Posted November 9, 2021 11 minutes ago, JCM said: Goes good with the pork fried rice. You go first... 3 Share this post Link to post Share on other sites
JCM 9,165 #13473 Posted November 10, 2021 Now I'm jonesin for some pork fried rice with hot mustard and egg foo yong. 1 3 Share this post Link to post Share on other sites
WHX?? 48,815 #13474 Posted November 10, 2021 Wow and I give the Hosen the business for goin .. guy changes his tranny oil and you get a hankering for food! Nice lookin tractor ther @Andy N. 2 8 Share this post Link to post Share on other sites
SylvanLakeWH 25,557 #13475 Posted November 10, 2021 Squirrel!!! 🐿 3 1 Share this post Link to post Share on other sites
