EB-80/8inPA 1,653 #13427 Posted November 5, 2021 On 11/3/2021 at 8:12 PM, Wheelhorse#1 said: I can’t stop now,I may have a problem.😬 You’ll know you have a problem when @ebinmaine says “I don’t see a problem here.” 1 2 Share this post Link to post Share on other sites
ebinmaine 67,592 #13428 Posted November 6, 2021 18 minutes ago, EB-80/8inPA said: You’ll know you have a problem when @ebinmaine says “I don’t see a problem here.” Accurate statement Share this post Link to post Share on other sites
Renrag 69 #13429 Posted November 6, 2021 Motor swap FAIL!!! Got the 14h ohv installed and everything buttoned up, well in-between bench starting it and installing it the compression relief stopped working, so I can't start it now. Leaves me one more option I have a 12.5 Briggs to put on it instead. That's not much increase from the 11h I took off. I was really hoping the 14 would work out my. 1 Share this post Link to post Share on other sites
ebinmaine 67,592 #13430 Posted November 6, 2021 39 minutes ago, Renrag said: Motor swap FAIL!!! Got the 14h ohv installed and everything buttoned up, well in-between bench starting it and installing it the compression relief stopped working, so I can't start it now. Leaves me one more option I have a 12.5 Briggs to put on it instead. That's not much increase from the 11h I took off. I was really hoping the 14 would work out my. Is it worth repairing while you're in the project process? Share this post Link to post Share on other sites
Pullstart 62,905 #13431 Posted November 6, 2021 Just got a tiny bit acquainted with a handful of new rides today… 9 5 Share this post Link to post Share on other sites
Ed729 57 #13432 Posted November 6, 2021 Built a receiver hitch out of some scrap metal to move around my 25 foot equipment trailer. It towed great on mostly flat ground. 7 1 Share this post Link to post Share on other sites
kpinnc 12,083 #13433 Posted November 6, 2021 Dang Pullstart! Thank you! This makes me feel so much better about the times I wondered if my addiction was obvious! Nice haul! 2 Share this post Link to post Share on other sites
Pullstart 62,905 #13434 Posted November 6, 2021 2 hours ago, kpinnc said: Dang Pullstart! Thank you! This makes me feel so much better about the times I wondered if my addiction was obvious! Nice haul! not my first rodeo with big hauls… have you seen these photos floating around? this was following Mrs. P. telling me “you go get a new zero turn mower and you can have as many wheel horses as you want!” Just before the 2018 big show. 1 1 6 Share this post Link to post Share on other sites
ebinmaine 67,592 #13435 Posted November 6, 2021 @Pullstart Buddy. I can't buh-leeeve you left it like that! I'm quite sure there was a little space left over near the right rear corner..... 2 Share this post Link to post Share on other sites
PeacemakerJack 10,738 #13436 Posted November 6, 2021 I managed to break a lift cable on @Coulter Caleb’s 854. Uncle Jim @WHX?? came to the rescue with a Lowell product and we were in business! Caleb did the work and changed it out. Hoping to turn some earth today with my boys and my fellow plow dogs…or for those on the other side of the pond “plough dogs”! 7 2 Share this post Link to post Share on other sites
Snoopy11 5,714 #13437 Posted November 6, 2021 11 hours ago, Pullstart said: you can have as many wheel horses as you want Did you get that in writing? You definitely could have fit 2 more on the roof of the truck... Don 1 Share this post Link to post Share on other sites
pfrederi 17,741 #13438 Posted November 6, 2021 Modified a front weight mount I made in the past and mounted it, now have 65 lbs on front, Question if you run front weights how much do you use??? Good news while i was trying to get t bolts through the mount and frame I bumped against the tie rod, it fell off.. Dug out a spare and put it on. Checked the other one it was ok.. Pain but better in the shop than at the end of the driveway plowing snow. \ 6 1 Share this post Link to post Share on other sites
Sparky-(Admin) 21,326 #13439 Posted November 6, 2021 One of the dead 312’s I dragged home a few weeks ago has fired up! Carb and fuel pump were both disassembled, cleaned and reassembled. She is alive and running off my “life support fuel tank” …now to remove the tank and clean it inside and out and get some new fuel line on her. 3 4 Share this post Link to post Share on other sites
SylvanLakeWH 25,598 #13440 Posted November 6, 2021 (edited) Changed trans oil in the E 141… wasn’t to bad… Fabricated a custom belt guard out of a standard Black Hood guard. Works perfect. Rerouted some wires. Full lube all grease points and Everything else that moves… Took it for a long spin to see how long the batteries would last… after20 minutes I know it will do what I need to do… train rides usually last 10 minutes or so… She’s charging now… IMG_1048.MOV Edited November 6, 2021 by SylvanLakeWH 4 4 Share this post Link to post Share on other sites
Pullstart 62,905 #13441 Posted November 6, 2021 1 hour ago, Snoopy11 said: You definitely could have fit 2 more on the roof of the truck... Believe you me, we talked about building a double decker! 1 3 Share this post Link to post Share on other sites
ebinmaine 67,592 #13442 Posted November 6, 2021 2 hours ago, pfrederi said: Question if you run front weights how much do you use? My oversized front tires have gallons each of Rimguard. That's 110 lb Plus the larger wheels and tires. Say 115 lbs total front weight added. Trina's 867 has a bracket that has 45 lbs on it. Really could use more. 1 Share this post Link to post Share on other sites
AMC RULES 37,130 #13443 Posted November 6, 2021 (edited) Set up the Honda-Horse with it's 54" plow today. Edited November 6, 2021 by AMC RULES 6 8 Share this post Link to post Share on other sites
19richie66 17,508 #13444 Posted November 6, 2021 12 minutes ago, AMC RULES said: Set up the Honda-Horse with it's 54" plow today. That should do well. 3 Share this post Link to post Share on other sites
Maxwell-8 4,277 #13445 Posted November 6, 2021 Secured the hubs, as they were dancing all over the place. Wet-sanded the hood, and cleaned and repainted my frontlight lens. 4 4 Share this post Link to post Share on other sites
Snoopy11 5,714 #13446 Posted November 6, 2021 17 minutes ago, Maxwell-8 said: Wet-sanded the hood, and cleaned and repainted my frontlight lens We are not worthy Don 1 Share this post Link to post Share on other sites
Snoopy11 5,714 #13447 Posted November 6, 2021 2 hours ago, SylvanLakeWH said: Full lube UH OH!!! @Jeff-C175... Don 2 1 Share this post Link to post Share on other sites
PeacemakerJack 10,738 #13448 Posted November 6, 2021 Had a great morning plowing with some of my buddies and my boys. I’m guessing Dan will start a thread and I can post most of my pics there but for now… Achto and Uncle Jim! I love this pic of Zach and I!!!! 4 9 Share this post Link to post Share on other sites
AMC RULES 37,130 #13449 Posted November 6, 2021 Not a bad pict of Uncle Dan & Aunt Jim too. 5 Share this post Link to post Share on other sites
76c12091520h 3,621 #13450 Posted November 7, 2021 Had a couple out soaking up some rays 1 7 Share this post Link to post Share on other sites
