Handy Don 12,233 #12901 Posted September 25, 2021 30 minutes ago, Lee1977 said: The only thing on the front is a bumper. My guess with the 3/8" plate under the Vanguard and the heavy 3500 rated front hubs it still weights less then with a Kohler. Nifty rig. Clearly capable of lifting the front of the tractor, too, or even breaking its frame-to-transaxle connection at the extreme. In reasonable use, though, when the load is "on the hook" adding a bit of weight on the bumper would give it a bit of extra "hold down", too! Share this post Link to post Share on other sites
Lee1977 6,663 #12902 Posted September 25, 2021 8 minutes ago, Handy Don said: Nifty rig. Clearly capable of lifting the front of the tractor, too, or even breaking its frame-to-transaxle connection at the extreme. In reasonable use, though, when the load is "on the hook" adding a bit of weight on the bumper would give it a bit of extra "hold down", too! The frame is braced too. 5 Share this post Link to post Share on other sites
Handy Don 12,233 #12903 Posted September 25, 2021 Just now, Lee1977 said: The frame is braced too. or even breaking its frame-to-transaxle connection at the extreme. 2 Share this post Link to post Share on other sites
ebinmaine 67,567 #12904 Posted September 25, 2021 28 minutes ago, Handy Don said: or even breaking its frame-to-transaxle connection at the extreme. Nicely done correction there sir Share this post Link to post Share on other sites
JCM 9,177 #12905 Posted September 25, 2021 I have been thinking for some time now to remove the 2 stage and cab on the 91 520-H and decided to do that this morning. Two reasons, first for maintenance and second to give the machine a Winter break and get some of the other 3 seasons a shot at it. Would like to put the 48'' SD mower back on it for mowing and mulching the ridiculous amount of leaves we get here. After removing those items gave it a wash and wax, put the wheel covers back on it and went for a short trail ride. Probably will install those 2 accessories on the 418-A and try out the twin Kohler this Winter. 8 3 Share this post Link to post Share on other sites
SylvanLakeWH 25,596 #12906 Posted September 25, 2021 (edited) Rearranged the ‘s so Mrs Sylvan can get her car in the garage this winter… Put the SL&WHN RR up on the trailer for a long winters nap… Only a wee bit of grease and a shoehorn needed… Edited September 25, 2021 by SylvanLakeWH 5 2 3 Share this post Link to post Share on other sites
ebinmaine 67,567 #12907 Posted September 25, 2021 1 minute ago, SylvanLakeWH said: wee bit of grease and a shoehorn 1 Share this post Link to post Share on other sites
ebinmaine 67,567 #12908 Posted September 25, 2021 1 hour ago, JCM said: install those 2 accessories on the 418-A and try out the twin Kohler this Winter Nice of you to share the fun amongst the herd. 2 Share this post Link to post Share on other sites
AMC RULES 37,130 #12909 Posted September 25, 2021 Just pulled the deck today. 3 3 Share this post Link to post Share on other sites
ebinmaine 67,567 #12910 Posted September 25, 2021 Our latest decent sized project that the horsies get to play on is moving 14 yards of dark gravel from the front of the house to the backyard. Filling in an area so we can access it better and even drive across it. The darker gravel to the left is what we moved today. We still need to move another 20 or 25 garden trailer loads down there. Mostly off to the left, some over between the trees on the right. This wood frog was keeping an eye on us. Likely as a site supervisor. Here's a short video 😁. 3 3 Share this post Link to post Share on other sites
peter lena 8,634 #12911 Posted September 25, 2021 @ SYLVANLAKE WH , as you know its a good idea to keep the Mrs. happy , good luck with that , pete Share this post Link to post Share on other sites
Tuneup 1,433 #12912 Posted September 25, 2021 So, the 25 year old stopped by. We sharpened the 42SD blades and cleaned the deck. Spindles will get the snot grease treatment this winter. Removed the 48SD from the 125 and put the 42 there where it's very happy - adjusted nicely. Blades were down in front so curious as to how it will mow now that it's proper. Moved the 48SD to the 516. Not yet adjusted for transport - the 516 needs a look-see on the lever. Took it into the yard and mowed at full speed. That machine actually rips. The 42RD sits alone and the 77 120 with fresh battery is now my cart puller since its mule needs a rebuild. Good day! Even the Ford got a wash. 2 Share this post Link to post Share on other sites
Andy N. 2,154 #12913 Posted September 26, 2021 Finished a valve job on the 418-A. It was hard to start since I bought it and finally decided to rip into it. There was no valve clearance and the valves were pretty worn so I just decided to replace them. She starts strong now. Some high and low RPM adjustment and it's ready to work. Also painted the muffler with some high temp black and did a lot of engine cleaning. Pics are before and after leakdown test results. 6 9 Share this post Link to post Share on other sites
ebinmaine 67,567 #12914 Posted September 26, 2021 Been doing some welding practice today. Started with the 2 pieces bolted to the transmission. Made those back in April I think. Welded the other 2 pieces to those. 8 8 Share this post Link to post Share on other sites
SylvanLakeWH 25,596 #12915 Posted September 26, 2021 Looking good! 1 Share this post Link to post Share on other sites
ebinmaine 67,567 #12916 Posted September 26, 2021 3 minutes ago, SylvanLakeWH said: Looking good! Should hold Share this post Link to post Share on other sites
Ifixoldjunk 778 #12917 Posted September 26, 2021 18 minutes ago, ebinmaine said: Been doing some welding practice today. Started with the 2 pieces bolted to the transmission. Made those back in April I think. Welded the other 2 pieces to those. I need to make one now. Good welding man. 1 Share this post Link to post Share on other sites
ebinmaine 67,567 #12918 Posted September 26, 2021 4 minutes ago, Ifixoldjunk said: I need to make one now. Good welding man. Thanks! Certainly could be prettier but I'm lookin for function. 2 Share this post Link to post Share on other sites
Inspectorjoe 471 #12919 Posted September 26, 2021 Since I'm down to the last week or two where it's still warm enough to paint without needing heat (which I don't have), I figured I'd better get going on painting my snow blades. I'm only doing the front faces, to help the snow slide. I kind of like the patina on the frames. I just bought the second one last month from a fellow member here who lives only 10 minutes away. I wasn't looking for another snow blade, but I figured I'd see how a 54" one does, compared to my 48". I need to replace the wear bar on the new one - it was worn down so far that two of the bolts were being ground down. After I cut the bolts and took the bar off, I saw that this wasn't the first time it had happened, only the previous time, it had worn down to all of the bolt holes. Someone added a small strip of new metal. I don't know why they didn't just leave it as it was and drill new holes. 2 2 Share this post Link to post Share on other sites
Lee1977 6,663 #12920 Posted September 26, 2021 (edited) 22 hours ago, ebinmaine said: Here's a short video 😁. Is that all you've done since you since the three shovels of stone a few years back? We know who does all the work around there, Edited September 26, 2021 by Lee1977 1 Share this post Link to post Share on other sites
Andy N. 2,154 #12921 Posted September 26, 2021 Has anyone used Por 15 on the underside of decks and spindles? I know it's a little pricey, but it went on great and I didn't use very much of the quart can for 2 coats. Just wondering on the durability from slinging grass. 3 Share this post Link to post Share on other sites
peter lena 8,634 #12922 Posted September 26, 2021 @Tuneup when you rebuild that mule drive good opportunity to pop off those 6203 , side rubber grease shields , carefully use a small pocket screwdriver , wipe out existing " grease " and replace with lucas extra heavy duty grease, polyurea rated , anti sling and a drop point of 560 deg , this lube will not fail . with that pto heat . grease at walmart for $ 5 . use it on all my decks and drives , no bearing whining and no failures . picked up some new pto pulleys , first thing i did , was to change over to this grease. lots of hours on the lube and no problems , just an idea while you are there , pete Share this post Link to post Share on other sites
Ed Kennell 38,203 #12923 Posted September 26, 2021 Removed the 42SD from the 417A and gave it the PETE treatment. Out in the sun all this week to soak in. Put the clean 48SD on the 417A. The 417 A with the front and rear ball hitch will be used for moving trailers but no mowing till 2022 spring. 4 2 Share this post Link to post Share on other sites
Ifixoldjunk 778 #12924 Posted September 26, 2021 2 hours ago, Andy N. said: Has anyone used Por 15 on the underside of decks and spindles? I know it's a little pricey, but it went on great and I didn't use very much of the quart can for 2 coats. Just wondering on the durability from slinging grass. I’ve used por15 on the undersides of my Jeeps. It handles that abuse just fine. A deck should last for a while. 1 Share this post Link to post Share on other sites
Ifixoldjunk 778 #12925 Posted September 26, 2021 I replaced the raggedy old seat on the Dixie horse 310-8. It’s called a “black talon high back” on amazon. It’s plenty comfortable and has good back support. Direct bolt on too. No modifications. For the price you can’t beat that. It’s made of some kind of synthetic material, so it should be plenty durable. 3 1 Share this post Link to post Share on other sites
