8ntruck 7,254 #12576 Posted August 24, 2021 (edited) Poked around on the new Black Hood arrival a bit today. Replaced the air filter, added a little Marvel Mystery Oil to the gas. It runs and drives, but is not ready to go to work. The to do list on it is getting longer. Since it smokes a little on start up, I was thinking maybe the rings might be struck - especially since it has not run for almost two decades. I pulled the plugs and put a little MMO in each cylinder, then rolled the engine over a few times. I'll let that set over night. I went to add some MMO to the oil, but found the oil level to be over filled per the dip stick. I drained about a cup and a half out to bring it to the full mark. Put about an ounce of MMO in the crankcase. This makes me wonder if the fuel pump is adding gas to the oil... The plan tomorrow is to chase around the electrical system to get it closer to working as it should. Will probably check the fuel pump, too. Got the laptop back today. I'll load pictures and start a new thread on this beast. Anybody out there build a new wire harness for their Horse? I'be found a source for wire, and maybe connectors - assuming Wheel Horse used Packard connectors. Oh, for our records, here is the model and serial number for the new to me horse: Model 01-19KE01 - 24003, serial 2091. Edited August 24, 2021 by 8ntruck 5 1 Share this post Link to post Share on other sites
ebinmaine 69,683 #12577 Posted August 24, 2021 6 hours ago, 8ntruck said: Anybody out there build a new wire harness for their Horse? I've rewired at least a half dozen of ours. I use full copper wire that I bought as a 50 foot roll of 7 conductor trailer wiring 14 guage. I just recently picked up a few proper connectors. Until now I've been using standard 1/4" blade type. I Always put a piece of heat shrink tubing at the ends. 1 Share this post Link to post Share on other sites
Gregor 4,847 #12578 Posted August 24, 2021 (edited) 6 hours ago, 8ntruck said: Anybody out there build a new wire harness for their Horse? I make new wiring harnesses for all my tractors. 14 ga. wire, at a minimum. I recently found these on Amazon, allowing me to reuse the plastic plugs. They fit perfectly. They do require an open barrel style wire crimper. I forgot to mention in line fuses. I am a BIG fan of lots of fuses. Edited August 24, 2021 by Gregor 3 2 Share this post Link to post Share on other sites
Andy N. 2,234 #12579 Posted August 24, 2021 9 hours ago, 953 nut said: Oh I have a few others, they just weren't ready to mow and the grass was out of control. Tire change seemed like a quicker option. I this is my 42" SD deck. I have a 48" that needs some repair. I think the ags will work with the 48" deck. And I really like the look of them too. 2 Share this post Link to post Share on other sites
JoeM 7,883 #12580 Posted August 24, 2021 Fabbed up a deflector / coupler protector on the FEL. Made it a tight hinge so it would stay up when coupling the plow hoses. Has a peg leg for support and just clears the tilt frame. All this so it will now not snow and all the work for not! The neighbor stopped by and ask what I am working on.......now picture this......it is 90 out plus humid, told him snow plow mounting, he kind of looked outside then back at me with the big eyes! 2 2 Share this post Link to post Share on other sites
peter lena 8,968 #12581 Posted August 24, 2021 @Tuneup nice looking deck shell there, just an idea, if you are going to rebuild those spindles , use a hi temp , polyurea ,anti sling grease with a 560 deg , flash point , lucas xtra , heavy duty , walmart $ 5 , big tube. done that on all my decks , no noisy, whining bearings , no failures , also did the matching bearings in the pto mule drive. thinking if you are that deep in the deck , why not upgrade the repair and make it last ? just my own experience , do what ever you want to do . also rustproof my decks . pete 1 Share this post Link to post Share on other sites
WheelHorse520H 708 #12582 Posted August 24, 2021 8 hours ago, 8ntruck said: found the oil level to be over filled per the dip stick. I drained about a cup and a half out to bring it to the full mark. Well, that sure would explain the smoky start up. Hope you get it all worked out soon. 2 Share this post Link to post Share on other sites
953 nut 56,715 #12583 Posted August 24, 2021 9 hours ago, 8ntruck said: found the oil level to be over filled per the dip stick. I drained about a cup and a half out to bring it to the full mark. Could be a bad fuel pump leaking into the oil, check it out as this could dilute your oil. 9 hours ago, 8ntruck said: Anybody out there build a new wire harness for their Horse? I'be found a source for wire, and maybe connectors - assuming Wheel Horse used Packard connectors The connectors @Gregor showed are Delphi Packard 56 series connectors and can be bought at any good auto parts store. 4 Share this post Link to post Share on other sites
D_Mac 8,942 #12584 Posted August 24, 2021 I took all my running and driving tractors out for a little drive today. I got some bad news on my yearly cancer check last week that may or may not put me back in the hospitol again. I need some more test until I know for sure. Beautiful day for a ride !! The more I think about my Horses the less I think about cancer. 18 2 Share this post Link to post Share on other sites
19richie66 17,542 #12585 Posted August 24, 2021 Sorry to hear that @D_Mac. Tractors are good therapy. Wish you the best my friend. 1 1 Share this post Link to post Share on other sites
pfrederi 18,157 #12586 Posted August 24, 2021 2 hours ago, 19richie66 said: Sorry to hear that @D_Mac. Tractors are good therapy. Wish you the best my friend. Good Luck!!! 1 1 Share this post Link to post Share on other sites
Jennifer 1,877 #12587 Posted August 24, 2021 5 hours ago, D_Mac said: I took all my running and driving tractors out for a little drive today. I got some bad news on my yearly cancer check last week that may or may not put me back in the hospitol again. I need some more test until I know for sure. Beautiful day for a ride !! The more I think about my Horses the less I think about cancer. Will be praying for you! 1 3 Share this post Link to post Share on other sites
SylvanLakeWH 26,556 #12588 Posted August 24, 2021 Thoughts and prayers @D_Mac… 1 1 Share this post Link to post Share on other sites
953 nut 56,715 #12589 Posted August 24, 2021 7 hours ago, D_Mac said: need some more test until I know for sure. I pray that your test results will be good and you can remain in good health, 1 1 Share this post Link to post Share on other sites
WheelHorse520H 708 #12590 Posted August 24, 2021 @D_Mac, I am very sorry to read that, I hope the results show that you are healthy. Best wishes, Andrew 1 1 Share this post Link to post Share on other sites
TonyToro 1,085 #12591 Posted August 25, 2021 (edited) 8 hours ago, D_Mac said: I took all my running and driving tractors out for a little drive today. I got some bad news on my yearly cancer check last week that may or may not put me back in the hospitol again. I need some more test until I know for sure. Beautiful day for a ride !! The more I think about my Horses the less I think about cancer. @D_MacNope I don’t like the news. Positive thinking and keep the tires rolling. Edited August 25, 2021 by TonyToro 1 1 Share this post Link to post Share on other sites
Tuneup 1,433 #12592 Posted August 25, 2021 14 hours ago, peter lena said: @Tuneup nice looking deck shell there, just an idea, if you are going to rebuild those spindles , use a hi temp , polyurea ,anti sling grease with a 560 deg , flash point , lucas xtra , heavy duty , walmart $ 5 , big tube. done that on all my decks , no noisy, whining bearings , no failures , also did the matching bearings in the pto mule drive. thinking if you are that deep in the deck , why not upgrade the repair and make it last ? just my own experience , do what ever you want to do . also rustproof my decks . pete Pete - way ahead of you and putting your recommendation to the test. They're full o fthat green snot. Strangest consistency of a grease I've ever seen. This assembly may stall if the bushing area needs the bronze. Never done that so it will be a learning experience - just normal tools. We'll see when Jacks gets them to me. Thanks! 1 1 Share this post Link to post Share on other sites
Pullstart 63,503 #12593 Posted August 25, 2021 @slufoot733 nice work on the project! I wonder why you couldn’t get fire with the spray, but eventually with fuel? I prefer to use the palm of my hand to completely cover a carb opening to pull an extreme amount of vacuum on the fuel system instead of spraying juice. 2 2 Share this post Link to post Share on other sites
Pullstart 63,503 #12594 Posted August 25, 2021 Morning coffee in the stable… 7 5 Share this post Link to post Share on other sites
Oldskool 6,660 #12595 Posted August 26, 2021 I traded a $50 item for this guy today. Runs and mows and has a rear hitch. So I have a new friend for the other horses to play with. 4 7 Share this post Link to post Share on other sites
ebinmaine 69,683 #12596 Posted August 26, 2021 5 minutes ago, Oldskool said: a new friend for the other horses to play with Appropriate inexpensive herd expansion is always a positive. 1 Share this post Link to post Share on other sites
adsm08 2,376 #12597 Posted August 26, 2021 Not me, and not a Horse, but a co-worker recently acquired a Ford LGT-14H. Has the 14 HP Kohler Magnum twin cylinder. He pulled the engine out to clean and paint, and him and his brother got it fired up on the bench last night. Engine ran, vibrated, walked, brother has a broken wrist. 1 1 Share this post Link to post Share on other sites
OutdoorEnvy 1,693 #12598 Posted August 26, 2021 23 minutes ago, adsm08 said: Not me, and not a Horse, but a co-worker recently acquired a Ford LGT-14H. Has the 14 HP Kohler Magnum twin cylinder. He pulled the engine out to clean and paint, and him and his brother got it fired up on the bench last night. Engine ran, vibrated, walked, brother has a broken wrist. That's too bad...hopefully they learn from it and he heals up well...the great philosopher Forrest Gump had a saying that applied to these kind of events... Share this post Link to post Share on other sites
balconio 606 #12599 Posted August 26, 2021 I tried out my new-to-me 42" SD deck today and it worked great. I found this deck on FB marketplace and picked it up from a nice gentleman an hour away from me, turned out to be @squonk lol. Until now I've only had a 42" RD and to be honest I like the SD better... I like how it throws the clippings instead of just letting them lay on the ground. The resulting cut looks cleaner and there's something satisfying about watching the clippings blasting out the side of the deck. She's going to be getting new blades and spindle bearings. Having 2 tractors and 2 decks now, if my wife and I mow together we should be able to cut the whole property in 1.5hrs including trails. 4 8 Share this post Link to post Share on other sites
8ntruck 7,254 #12600 Posted August 26, 2021 intestering comment on the SD vs RD deck. I've got one of each and agree that the SD gives a better cut, but the RD really works well with a tow behind sweeper. I like the RD deck because it does not seem to throw objects as far as the SD deck. The RD deck is narrower too. Gets into smaller places and cuts closely on both sides. 4 2 Share this post Link to post Share on other sites
