WheelHorse520H 708 #12126 Posted July 7, 2021 10 hours ago, tom2p said: it's a war out there I am working on the Onan and could not believe the little cracks and crevices the grass gets into! Places so small a pencil could not fit but of course grass can. 2 Share this post Link to post Share on other sites
ebinmaine 67,457 #12127 Posted July 7, 2021 15 hours ago, AMC RULES said: Young kid behind the counter, so professional, had to take that abuse. Terrible behavior from a guy obviously old enough to know better. I told the kid what a great job he was doing, ignore that a hole, and how much I appreciate my postal service Well done Craig. Thank you. 1 Share this post Link to post Share on other sites
ebinmaine 67,457 #12128 Posted July 7, 2021 (edited) 15 hours ago, AMC RULES said: Edited July 7, 2021 by ebinmaine Delete duplicate Share this post Link to post Share on other sites
WheelPuke 77 #12129 Posted July 8, 2021 Just mowed these last few weeks with the 414-8 Horse. I had Triumph costs take away from the Wheel Horse maintenance fund. I should be able to get back on the maintenance for Horses in a few weeks. I’ll need to do a 25 hour service at that point too. 4 Share this post Link to post Share on other sites
lynnmor 7,305 #12130 Posted July 8, 2021 3 hours ago, WheelPuke said: Just mowed these last few weeks with the 414-8 Horse. I had Triumph costs take away from the Wheel Horse maintenance fund. I should be able to get back on the maintenance for Horses in a few weeks. I’ll need to do a 25 hour service at that point too. You better not wait, it appears that the horse is having serious intestinal problems judging by the green and yellow droppings. 1 10 1 1 Share this post Link to post Share on other sites
8ntruck 6,998 #12131 Posted July 9, 2021 The new Spirol pins I ordered came in and got picked up today. I knocked out the friction pin I had installed in the PTO clutch hoop to get me going and replaced it with the proper Spirol pin. Found out that the pin I ordered from the Toro dealer is 1 1/8" long, which is just long enough to support the stub shaft bracket. A pin 1 1/4" long would make installation a little more forgiving. Mowed the lawns once I buttoned it back up. I think I'm going to need a new drive belt for the deck soon. This one turned inside out on the PTO pulley 3 times while I was mowing. 3 Share this post Link to post Share on other sites
Renrag 69 #12132 Posted July 9, 2021 I had to build a starter for my horse, the magnet shattered in the original, so I took it and the old starter off my 93 craftsman 12h that spun the gear and shaft on top, and put together one that works fine after having to make the lock in clip on top of cone. 8 love my horse, but I think it might be time to sell and find another, I've rebuilt, wired, and painted everything but the motor, other then few carb dilemma's it's ran fine it's a 82 bp05 with every part and bolt I've taken off of it since day one except original fenders, didn't have any at purchase, so I fabricated a set to fit 2 1 Share this post Link to post Share on other sites
Ed Kennell 38,160 #12133 Posted July 9, 2021 6 hours ago, Renrag said: it's a 82 bp05 What is this? Got any pictures? Share this post Link to post Share on other sites
peter lena 8,620 #12134 Posted July 9, 2021 @horsenewbee, local hardware store should have a small pull out drawer section , with a wide selection of those bushings , also a good spot to find related linkage clips , springs , etc look around , pete 1 Share this post Link to post Share on other sites
peter lena 8,620 #12135 Posted July 9, 2021 @8ntruck on that belt deck belt issue , while you are there check out the belt idler tension , set up , sounds like the slide washer bushing under the flat spring bar area could be worn out and preventing , spring tension follow on the pulleys. also do a deck scrape ( if you want to ) spray the under side with aerosol lubricant , to stop rust , small flat file to touch up blades , lubricate wheels , and related lift frame linkages, for easier use. the above is just something I regularly do . dip stick check your rear end oil . pete Share this post Link to post Share on other sites
19richie66 17,500 #12136 Posted July 9, 2021 (edited) Test fit 2.0 Edited July 9, 2021 by 19richie66 2 4 Share this post Link to post Share on other sites
ebinmaine 67,457 #12137 Posted July 9, 2021 20 minutes ago, 19richie66 said: Test fit IT'S PERFECT!!! Share this post Link to post Share on other sites
Pullstart 62,842 #12138 Posted July 9, 2021 It’s a KEEPER! 2 1 1 Share this post Link to post Share on other sites
19richie66 17,500 #12139 Posted July 9, 2021 Figured no one bought it at the show, may as well use it. 1 Share this post Link to post Share on other sites
OldWorkHorse 3,045 #12140 Posted July 9, 2021 (edited) @19richie66What engine is that? Looks dieselish. Edited July 9, 2021 by OldWorkHorse 1 Share this post Link to post Share on other sites
ebinmaine 67,457 #12141 Posted July 9, 2021 3 minutes ago, OldWorkHorse said: dieselish Is that like relish? I like relish. 1 2 Share this post Link to post Share on other sites
pfrederi 17,734 #12142 Posted July 9, 2021 Trying out a safety item for my GT14. Several times the front edge of fenders have caught my leg getting on and off. Ripped some pants and drew a bit of blood when I was in shorts. 5 7 1 Share this post Link to post Share on other sites
ebinmaine 67,457 #12143 Posted July 9, 2021 1 minute ago, pfrederi said: my GT14 I like that, Paul. Appreciate how it's literally a safety item but also it does add a nice finished look to the end of that panel. I bought a roll of that edge covering material to use on a few different things. Thinking this weekend I might be able to put some on. 1 Share this post Link to post Share on other sites
19richie66 17,500 #12144 Posted July 9, 2021 26 minutes ago, OldWorkHorse said: @19richie66What engine is that? Looks dieselish. Yanmar 2 cylinder diesel. TK270M made for Thermoking tripac units. 2 2 Share this post Link to post Share on other sites
ebinmaine 67,457 #12145 Posted July 9, 2021 Should move a garden tractor okay 2 Share this post Link to post Share on other sites
Graham Hawkridge 0 #12146 Posted July 9, 2021 Need to speak with some one who has adjusted their speed control lever etc, under the rear seat of 518-H tractor? It is slowing down rapidly when cutting grass on lawn. Grass not too high either, so it needs adjusting a little. Have no idea how to do this. Any info would be greatly appreciated.thanks. graham Share this post Link to post Share on other sites
Jeff-C175 7,201 #12147 Posted July 9, 2021 40 minutes ago, Graham Hawkridge said: Need to speak with some one who has adjusted their speed control lever etc, under the rear seat of 518-H tractor? It is slowing down rapidly when cutting grass on lawn. Grass not too high either, so it needs adjusting a little. Have no idea how to do this. Any info would be greatly appreciated.thanks. graham Is this what you're looking for Graham? Share this post Link to post Share on other sites
D_Mac 8,610 #12148 Posted July 9, 2021 So I had to put a different set of tires and wheels on the 500 so I can get it on my truck and transport it more easily. After Squonk put his Tecumseh Curse on it I am going to have to take it to a friend's to work on it. Seat is also temporary but at least it is dry and no moss and plants are growing out of it. 1 Share this post Link to post Share on other sites
Handy Don 12,216 #12149 Posted July 9, 2021 If it is the motion lever that is slipping, then.... 2 1 Share this post Link to post Share on other sites
8ntruck 6,998 #12150 Posted July 10, 2021 12 hours ago, peter lena said: @8ntruck on that belt deck belt issue , while you are there check out the belt idler tension , set up , sounds like the slide washer bushing under the flat spring bar area could be worn out and preventing , spring tension follow on the pulleys. also do a deck scrape ( if you want to ) spray the under side with aerosol lubricant , to stop rust , small flat file to touch up blades , lubricate wheels , and related lift frame linkages, for easier use. the above is just something I regularly do . dip stick check your rear end oil . pete Yup. I should get that done soon. The belt I was having problems with was the one that connects the deck to the PTO. Share this post Link to post Share on other sites
