ebinmaine 67,545 #11301 Posted May 15, 2021 13 minutes ago, Gregor said: Looks to me like it has an engine on it. Bad one. Share this post Link to post Share on other sites
Gregor 4,846 #11302 Posted May 15, 2021 22 minutes ago, ebinmaine said: Bad one. Not bad. Just misguided. 4 Share this post Link to post Share on other sites
cschannuth 3,816 #11303 Posted May 15, 2021 4 hours ago, The Tuul Crib said: g ! I can't stop looking at those wheels on that little ranger pick up. Those are getting hard to find We used to have Torino’s so I had the 15x7’s for the front and the 15x8’s for the rear. I put them on as sort of a joke, liked them on there, and never took them off. 2 Share this post Link to post Share on other sites
Horse Newbie 7,070 #11304 Posted May 15, 2021 4 hours ago, TonyToro said: Can you show a full picture of the bottom plow? Here's a pic...yes the nut on the right is the nut that "jams" against the barrel and holds the angle of the plow blade so that it either points down for a deeper cut, or more level so that it doesn't dig in so much. But I still don't see what the nut on the left does...it just jams against the shoulder on the threaded rod (adjustment handle), and spins with the handle. 20210515_113523.mp4 1 Share this post Link to post Share on other sites
Maxwell-8 4,276 #11305 Posted May 15, 2021 It keeps the treaded part from spinning in the left part 1 Share this post Link to post Share on other sites
Horse Newbie 7,070 #11306 Posted May 15, 2021 2 hours ago, Maxwell-8 said: It keeps the treaded part from spinning in the left part Thanks a million ! Still seems to me that the jam nut against the barrel would do it also...guess I'm weird wanting to know answers to things like this. A lot of people would say "Don't worry about it, and just use the darn thing". Which is what I plan to do ! It's there for a reason, so when I set the adjustment on the plow, I will tighten one nut against the left part and the right against the barrel section... 1 Share this post Link to post Share on other sites
The Tuul Crib 7,336 #11307 Posted May 15, 2021 3 hours ago, cschannuth said: We used to have Torino’s so I had the 15x7’s for the front and the 15x8’s for the rear. I put them on as sort of a joke, liked them on there, and never took them off. Best looking wheels Ford ever made in my opinion I had a Torino cobra it had the magnum 500 wheels. 2 Share this post Link to post Share on other sites
ranger 1,750 #11308 Posted May 15, 2021 (edited) 40 minutes ago, Horse Newbie said: Thanks a million ! Still seems to me that the jam nut against the barrel would do it also...guess I'm weird wanting to know answers to things like this. A lot of people would say "Don't worry about it, and just use the darn thing". Which is what I plan to do ! It's there for a reason, so when I set the adjustment on the plow, I will tighten one nut against the left part and the right against the barrel section... The nut to the right of the pivot pin the adjuster passes through is used to take up any free play, but still allow the handle to be operated without binding. If it wasn’t there, the plough bottom would tilt down and dig in as adjuster slid forwards when the point of the share engaged the ground. The nut to the right of the picture is the one used to lock the handle after adjustments are made. No need to tighten both solid, only the rearmost one Doug. Edited May 15, 2021 by ranger 1 Share this post Link to post Share on other sites
TonyToro 1,049 #11309 Posted May 15, 2021 5 hours ago, Horse Newbie said: Here's a pic...yes the nut on the right is the nut that "jams" against the barrel and holds the angle of the plow blade so that it either points down for a deeper cut, or more level so that it doesn't dig in so much. But I still don't see what the nut on the left does...it just jams against the shoulder on the threaded rod (adjustment handle), and spins with the handle. 20210515_113523.mp4 Looks to me that the washer need to be against the barrel and the two nuts are there to lock it down. Jam one nut into the other. 1 Share this post Link to post Share on other sites
Chestnut 315 #11310 Posted May 15, 2021 9 hours ago, Gregor said: Looks to me like it has an engine on it. 8 hours ago, ebinmaine said: Bad one. 8 hours ago, Gregor said: Not bad. Just misguided. There is no such thing as a bad engine. Just bad previous owners. 2 1 Share this post Link to post Share on other sites
D_Mac 8,619 #11311 Posted May 15, 2021 9 hours ago, Shed said: What size tires are on that 875? I'd like to put tall skinny r1s on a 416 h for use in the garden make it more farm tractorish. Has any one done this to a 416? Yes EB is right, those are 6-12's on the rear. 3 1 Share this post Link to post Share on other sites
ebinmaine 67,545 #11312 Posted May 15, 2021 6 minutes ago, D_Mac said: Yes EB is right, those are 6-12's on the rear. Hey what brand are they? 1 Share this post Link to post Share on other sites
D_Mac 8,619 #11313 Posted May 15, 2021 Those are Goodyears. I just got them last week. I bought them for the rims, tires are not in the best shape. They have some cracks in them but there are tubes in them so they hold air fine. I wanted to put a different set of tires on the rims but I guess just keep them the way they are. Glad I got the extra set for all this wheel painting I been doing. Heres a photo of after I painted the rims but before I cleaned the tires. You can see the cracking. Im happy, got the rims with the tires for 40 bucks. 2 1 Share this post Link to post Share on other sites
ebinmaine 67,545 #11314 Posted May 15, 2021 4 minutes ago, D_Mac said: Goodyears 40 bucks is a great deal for that set. The cracks should be fine unless you run heavy like my Cinnamon Horse. 1 Share this post Link to post Share on other sites
Shed 248 #11315 Posted May 15, 2021 Those are narrow then a 25 8.5 12? Would a 6 12 fit on a stock 416 rim? Or would they need to be changed out to a narrow rim as well? The front I'd like to put tri ribs. 1 Share this post Link to post Share on other sites
pfrederi 17,741 #11316 Posted May 15, 2021 3 minutes ago, Shed said: Those are narrow then a 25 8.5 12? Would a 6 12 fit on a stock 416 rim? Or would they need to be changed out to a narrow rim as well? The front I'd like to put tri ribs. 6 x 12 came on 5 inch wheel. 416 tractors had 7 inch. Rule of thumb wheel should be 1 or 2" narrower than the tire cross section. 2 Share this post Link to post Share on other sites
Oldskool 6,644 #11317 Posted May 16, 2021 I put the rake on the new Horse. Did pretty good. Needs a bit more tractor weight though. 5 3 Share this post Link to post Share on other sites
OutdoorEnvy 1,522 #11318 Posted May 16, 2021 29 minutes ago, Oldskool said: I put the rake on the new Horse. Did pretty good. Needs a bit more tractor weight though. That is a nice looking rake setup. Do you mind elaborating on the make/model and the hitch attachment it requires? 1 1 Share this post Link to post Share on other sites
ebinmaine 67,545 #11319 Posted May 16, 2021 32 minutes ago, Oldskool said: I put the rake on the new Horse. Did pretty good. Needs a bit more tractor weight though. 1 minute ago, OutdoorEnvy said: That is a nice looking rake setup. Do you mind elaborating on the make/model and the hitch attachment it requires? We could use one o them here in the yard. 1 1 Share this post Link to post Share on other sites
Horse Newbie 7,070 #11320 Posted May 16, 2021 5 hours ago, The Tuul Crib said: Best looking wheels Ford ever made in my opinion My neighbor sold a 1972 or so F-150 truck last year...I told him he should keep it...anyways it had a set of those wheels...darn good looking truck ! I don't think he knew what he had. You can't find pick ups down south unless you are ready to shuck the bucks ! Share this post Link to post Share on other sites
The Tuul Crib 7,336 #11321 Posted May 16, 2021 3 minutes ago, Horse Newbie said: My neighbor sold a 1972 or so F-150 truck last year...I told him he should keep it...anyways it had a set of those wheels...darn good looking truck ! I don't think he knew what he had. You can't find pick ups down south unless you are ready to shuck the bucks ! Same here in the mid south! A good truck here is gold!! 1 Share this post Link to post Share on other sites
8ntruck 7,011 #11322 Posted May 16, 2021 (edited) 6 hours ago, The Tuul Crib said: Best looking wheels Ford ever made in my opinion I had a Torino cobra it had the magnum 500 wheels. Actually, those Mag 500's were supplied to Ford by Motor Wheel. We made those at factories in Lansing, Michigan, Chatham, Ontario, and Mendota, Illinois. We also sold versions of them to AMC, GM, and Chrysler. I think there are a couple of companies making reproductions of them now. I've seen ads for steel versions and aluminum look a likes, some in the currently popular larger diameters. Originals only came in 14" and 15" diameters with a variety of rim widths and inset dimensions. Edited May 16, 2021 by 8ntruck 2 1 Share this post Link to post Share on other sites
The Tuul Crib 7,336 #11323 Posted May 16, 2021 Just now, 8ntruck said: Actually, those Mag 500's were supplied to Ford by Motor Wheel. We made those at factories in Lansing, Michigan, Chatham, Ontario, and Mendota, Illinois. We also sold versions of them to AMC, GM, and Chrysler. I do remember those real well! Pontiac had them as well and l can still see the PMD in the center cap 3 Share this post Link to post Share on other sites
Oldskool 6,644 #11324 Posted May 16, 2021 19 minutes ago, OutdoorEnvy said: That is a nice looking rake setup. Do you mind elaborating on the make/model and the hitch attachment it requires? It's a Tuffline 60in ATV rake. It has an adjustable height hitch and attaches with a 1-7/8 ball. I can reach the rake height adjusting handle from the seat. Very convenient, but I would like to make the adjustments hydraulic someday. 3 1 Share this post Link to post Share on other sites
8ntruck 7,011 #11325 Posted May 16, 2021 (edited) 19 minutes ago, The Tuul Crib said: I do remember those real well! Pontiac had them as well and l can still see the PMD in the center cap We had a unique wheel for Pontiac as well. That one looked more like an American Torque Thrust mag wheel than the Mag 500. Those mostly we're used on Firebirds, Tempests, and GTO's. We made a unique wheel for Oldsmobile, too, used mostly on the Cutlass and Delta 88. One of my first projects as a new engineer at Motor Wheel was to do a computer aided stress analysis of the 13" look alike Cutlass wheel for the then new front wheel drive X car, called the Omega when it went on sale. Edited May 16, 2021 by 8ntruck 3 1 Share this post Link to post Share on other sites
