Horse Newbie 7,008 #11151 Posted May 9, 2021 (edited) On 5/5/2021 at 9:23 PM, Gregor said: When they stop real fast, it hurts ! They stop...you don't...pain ! Edited May 9, 2021 by Horse Newbie Share this post Link to post Share on other sites
Horse Newbie 7,008 #11152 Posted May 9, 2021 After I washed my 1994 520H, I was gonna apply a few more decals I got from @Vinylguy...but I can't remember where this one goes. It looks like it may go on the deck, but I did not order any deck decals yet... Anybody have a 1994 520H that could post a pic showing if it goes on the tractor ? 3 Share this post Link to post Share on other sites
Thor27 759 #11153 Posted May 9, 2021 (edited) It goes on the right side of rear axle Edited May 9, 2021 by Thor27 1 Share this post Link to post Share on other sites
Tractorhead 9,059 #11154 Posted May 9, 2021 17 hours ago, 19richie66 said: Heck, how cool is that - That clears something - Wheelhorse allready invented the Autopilot back in these Day‘s. Sorry Mr. Musk your Autopilot in the Tesla is nothing new - here is the evidence.. 👍😎 2 6 Share this post Link to post Share on other sites
ranger 1,729 #11155 Posted May 9, 2021 (edited) If you intend grinding off the weld bead you have applied, especially on thin material, make sure you have full penetration or you run the risk of cracks returning. If you need a decent surface finish, consider welding the underside of the weld before sanding. You’ll have ‘Thicker’ material to work with and be able to lay a bead down. This ‘Cap’ weld will also help refine the grain of the previous weld. You can then sand down the visible outside weld without losing too much strength, or weld the inside first? Cracks generally radiate from highly stressed areas, so the last thing you want to do is add material to reinforce an already stressed and weakened area, then remove it, pin holes, craters, etc, in welds become ‘Stress raisers’ and the cycle continues! Mentioning excavator boom repairs, ones I’ve seen that have been properly repaired, have additional reinforcing plates added to span the repair and do not rely on the weld alone to hold together a previously failed highly stressed component. Also they don’t remove welds for appearance sake on such critical items. Doug Edited May 9, 2021 by ranger 2 1 Share this post Link to post Share on other sites
JCM 9,062 #11156 Posted May 9, 2021 Decided it was time to remove the Winter set up on the 417-8 and get ready for the Tine rake setup for the trail system etc. Going to let the 312-8 sit the mowing duties aside this year and let the 418-A take over this year. This is the first time in many years that I mowed with a Hydro and a RD deck. I can't believe how quick I finished and not going much faster than with the 8 speed. No shifting was welcomed for a change. I can relate to @Ed Kennell 's comments on how he prefers them for mowing and blowing. Also installed the OEM 520-H seat and NOS armrests on the 418-A along with new fuel lines , filter and NOS Horsehead square padded keys on both. 2 9 Share this post Link to post Share on other sites
Goldnboy 880 #11157 Posted May 9, 2021 Did some tilling yesterday with the B140-8. First time tilling since upgrading to 14Hp and adding hydraulic lift. The hydraulic lift makes this so much more fun. However installing the tiller is a bear. That right idler pulley has to to be positioned just right to latch in. Also I had much much better performance using the older L-shaped mid idler and had no belts flipping off the pulley 6 2 Share this post Link to post Share on other sites
ohiofarmer 3,249 #11158 Posted May 9, 2021 (edited) I replaced the gear oil in a commando [I think] 800. I put it from a 2 gallon container into a quart sized squeeze bottle and then through the toolbox mounting hole in the transmission. BTW, I think a rubber grommet from a Harbor freight box-o-grommets is a good thing to do in case the bolt threads do not exclude moisture. TSC 2 gallon container was much cheaper to buy than any other way at $28.I also need to purchase some gear shift boots.... Gonna do at least five more, so buying in bulk makes sense. Filling a tractor without a top check stick was a new experience, but as usual, plenty of help from you guys Thanks!!! Edited May 9, 2021 by ohiofarmer 5 Share this post Link to post Share on other sites
Horse Newbie 7,008 #11159 Posted May 9, 2021 14 hours ago, Horse Newbie said: Vinylguy...but I can't remember where this one goes. I found where it goes... back of differential housing... right side. Share this post Link to post Share on other sites
balconio 606 #11160 Posted May 9, 2021 Fleet maintenance 😁. Decarbonizing heads, replacing yet another mouse chewed ignition coil (the lousy rat bastards), and seeing if I can fix a degrading muffler that's developed an annoying squeak at certain RPM. 8 2 Share this post Link to post Share on other sites
Snoopy11 5,714 #11161 Posted May 9, 2021 (edited) 8 hours ago, ranger said: If you intend grinding off the weld bead you have applied, especially on thin material, make sure you have full penetration or you run the risk of cracks returning. If you need a decent surface finish, consider welding the underside of the weld before sanding. You’ll have ‘Thicker’ material to work with and be able to lay a bead down. This ‘Cap’ weld will also help refine the grain of the previous weld. You can then sand down the visible outside weld without losing too much strength, or weld the inside first? Cracks generally radiate from highly stressed areas, so the last thing you want to do is add material to reinforce an already stressed and weakened area, then remove it, pin holes, craters, etc, in welds become ‘Stress raisers’ and the cycle continues! Mentioning excavator boom repairs, ones I’ve seen that have been properly repaired, have additional reinforcing plates added to span the repair and do not rely on the weld alone to hold together a previously failed highly stressed component. Also they don’t remove welds for appearance sake on such critical items. Doug Could also put a piece of material (steel) on the underside and proceed welding from above...! Only works if the surface is a plane... perfectly flat that is... By the way, Doug, the place on the tractor that I mentioned could have been ground down without losing integrity. Someone was just being lazy in repairs, thus the tractor lost value. This is also true of hoods, body panels, and mowing decks!!! Now... major frames or other structural areas must remain with weld beads intact. On thin metal, Tuneup should be getting good enough penetration to grind them down, in my experience. I would love to see pictures of the underside of the welds that Tuneup is making though! Don Edited May 9, 2021 by Snoopy11 By the way... 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,237 #11162 Posted May 9, 2021 Spent 3 hours today tracing wiring on 312-8 that died last week. Finally found the broken wire and replaced it. It cranks by key now. Still no go , runs on starting fluid then dies. Removed fuel line from pump, plenty of flow. Pull line from carb , no gas. bad pump. Thanks to @pfrederi for the Facet part number. Now the waiting game begins unit it arrives. 3 Share this post Link to post Share on other sites
squonk 40,743 #11163 Posted May 9, 2021 12 minutes ago, elcamino/wheelhorse said: Spent 3 hours today tracing wiring on 312-8 that died last week. Finally found the broken wire and replaced it. It cranks by key now. Still no go , runs on starting fluid then dies. Removed fuel line from pump, plenty of flow. Pull line from carb , no gas. bad pump. Thanks to @pfrederi for the Facet part number. Now the waiting game begins unit it arrives. Napa 610-1051. Yes it costs more. But you get it most likely in a day and you help keep a local store open instead of the internet. You may have an emergency some day and the place is closed! 6 2 Share this post Link to post Share on other sites
Mike in NC 340 #11164 Posted May 9, 2021 I got my electronic fuel pump at Autozone. It is a Mr. Gasket brand. Up to 3 PSI. Installed it on my Bronco 14 a few years ago and works great. 1 Share this post Link to post Share on other sites
Oldskool 6,596 #11165 Posted May 9, 2021 I picked this up this morning. Checked the oil, the gear oil, the fuel bowl, blew out the tank. put a used fuel pump on, dropped a battery in it, blew up the tires. It fired rite up! I've been running the wheels off this thing. It's going to need a solenoid very soon though. 8 5 Share this post Link to post Share on other sites
ebinmaine 66,584 #11166 Posted May 9, 2021 35 minutes ago, Oldskool said: fired rite up! I've been running the wheels off this thing That'd be a great little yard buggy worker for you and the Mrs. 2 Share this post Link to post Share on other sites
Oldskool 6,596 #11167 Posted May 9, 2021 3 minutes ago, ebinmaine said: That'd be a great little yard buggy worker for you and the Mrs. I have a 48in rock rake I'm going to tow. Seems like a good one for that 2 Share this post Link to post Share on other sites
ebinmaine 66,584 #11168 Posted May 9, 2021 11 minutes ago, Oldskool said: I have a 48in rock rake I'm going to tow. Seems like a good one for that Yessir. 2 Share this post Link to post Share on other sites
AMC RULES 37,102 #11169 Posted May 9, 2021 Couple years since this old 16hp thumper has been in service here. After a fluids change today the old girl is ready to see some action. 9 4 Share this post Link to post Share on other sites
ebinmaine 66,584 #11170 Posted May 9, 2021 Trina and her mom spent some time splittin' firewood. 🔥 We've got a decent jump on next winter but still a ways to go. That's the Charger hydro pictured. I pulled a couple 2/3 loads (trailer back empty) from the forest. A little more experimenting with welding. Trina's 867 seat pan brace has been broken for many many moons. A week or two ago it bent so she decided it should get welded up. Pretty thin metal so I decided to go with 1/16" 6013 rod. I'm sure I didn't need to use a piece quite so wide but that's what I had handy so that's what went on. I did burn through in one place when I forgot to check the amperage and had it too high. Fixed that. Ground out some other places I wasn't fond of and filled them in. Leveled off the top and here it sits. To install the seat latch I put a notch in the added metal with a cutoff wheel. Then finished grinding with the Dremel. I've ordered some rubber baby buggy bumpers. Those will be popped in later. 10 4 1 Share this post Link to post Share on other sites
pfrederi 17,518 #11171 Posted May 9, 2021 3 minutes ago, ebinmaine said: Trina and her mom spent some time splittin' firewood. 🔥 We've got a decent jump on next winter but still a ways to go. That's the Charger hydro pictured. I pulled a couple 2/3 loads (trailer back empty) from the forest. I will call my coal guy this week he will bring me 4 tons take about 20 minutes to get it in to the coal bin and I will be set for next winter... 4 1 1 Share this post Link to post Share on other sites
ebinmaine 66,584 #11172 Posted May 9, 2021 4 minutes ago, pfrederi said: I will call my coal guy this week he will bring me 4 tons take about 20 minutes to get it in to the coal bin and I will be set for next winter... That's pretty awesome. We do enjoy processing firewood. Good exercise and fun with machinery. 4 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,237 #11173 Posted May 10, 2021 3 hours ago, squonk said: Napa 610-1051. Yes it costs more. But you get it most likely in a day and you help keep a local store open instead of the internet. You may have an emergency some day and the place is closed! Thanks Mikey I like the Facet pumps , have them on the 310-8 and 416-8 . Three plus years for each. I will have the pump on Wednesday and don't have to fool with a counter idiot . Share this post Link to post Share on other sites
squonk 40,743 #11174 Posted May 10, 2021 The Napa pump is a Facet. Keep the number handy Share this post Link to post Share on other sites
elcamino/wheelhorse 9,237 #11175 Posted May 10, 2021 @squonk yes dear. Been saying that most of day , might as well continue. 2 Share this post Link to post Share on other sites
