Ed Kennell 38,170 #10376 Posted April 11, 2021 3 minutes ago, Gregor said: They may be OK. But....If they are correct, I think your tractor may be bassackwards. I think, anyway. Maybe not. May be for a rear facing passanger seat. 6 Share this post Link to post Share on other sites
OldWorkHorse 3,045 #10377 Posted April 11, 2021 (edited) Lol don't know things about 30 years older then me and that's how they were installed when I got her. Guess worse come worse I unbolt them and turn them around? I bought it off @ebinmaine that could have somthing to do with it Edited April 11, 2021 by OldWorkHorse 3 Share this post Link to post Share on other sites
Gregor 4,846 #10378 Posted April 11, 2021 Doesn't look like that tractor originally had seat springs. Maybe they work better that way. IDK. 2 Share this post Link to post Share on other sites
rjg854 11,361 #10379 Posted April 11, 2021 You just never know why those PO's do what they do. You'll get more spring out of them by changing them around. 1 1 Share this post Link to post Share on other sites
OldWorkHorse 3,045 #10380 Posted April 11, 2021 Just now, rjg854 said: You just never know why those PO's do what they do. You'll get more spring out of them by changing them around. I'll give that a shot next time back in the shop. 1 Share this post Link to post Share on other sites
OldWorkHorse 3,045 #10381 Posted April 11, 2021 2 minutes ago, Gregor said: Doesn't look like that tractor originally had seat springs. Maybe they work better that way. IDK. Must be the luxury model 1 Share this post Link to post Share on other sites
Gregor 4,846 #10382 Posted April 11, 2021 1 minute ago, OldWorkHorse said: Must be the luxury model Did you pay extra for the comfort package? 4 Share this post Link to post Share on other sites
Ed Kennell 38,170 #10383 Posted April 11, 2021 10 minutes ago, OldWorkHorse said: I bought it off @ebinmaine that could have somthing to do with it What are you sayin..the Bear needed more support at the rear end? 7 Share this post Link to post Share on other sites
OldWorkHorse 3,045 #10384 Posted April 11, 2021 13 minutes ago, Ed Kennell said: What are you sayin..the Bear needed more support at the rear end? Bahahaha no! Easy on easy off! 1 Share this post Link to post Share on other sites
squonk 41,103 #10385 Posted April 11, 2021 Yup. Springs on backwards! 1 Share this post Link to post Share on other sites
Gregor 4,846 #10386 Posted April 11, 2021 32 minutes ago, OldWorkHorse said: I bought it off @ebinmaine THAT would explain it! Springs are fine, tractor is backwards. 4 Share this post Link to post Share on other sites
Gregor 4,846 #10387 Posted April 12, 2021 Got a little more done on the 876 today. For once in my life, I was correct, unfortunately. My brake/belt tensioner linkage worked fine, until I went to put on the belt guard. Then it didn't work so fine. After a couple more hours of re-work, and a couple trips to the hardware store, I think I got something that will work. May not be "BY THE BOOK" but it works. I find it odd that the bracket that holds the fan guard in place, only has a bolt in the bottom. Maybe it's suppose to be this way. IDK I didn't like the way the rubber bumpers were rubbing on the sides of the tractor. It doesn't show up well in the pic, buy I put a strip of self adhesive, clear, decal paper on each side. The dash, and dash plate are still at the media blaster, so I may be in a holding pattern for now. I got a call from the machine shop on my motor, and I have ordered the rebuild kit. So far I have not encountered a problem with the plate being welded on the back side of the frame. The 10 gauge I used is .102" thick. (depending on what chart you look at), so if you see an 876 with a wheel base .102" longer than normal, it's mine. 4 3 Share this post Link to post Share on other sites
OldWorkHorse 3,045 #10388 Posted April 12, 2021 38 minutes ago, Gregor said: Maybe I'm new to this buy why does this tractor have 2 fuel tanks? Did I miss somthing? 2 Share this post Link to post Share on other sites
Roger R 447 #10389 Posted April 12, 2021 22 hours ago, Jeff-C175 said: I checked that out Roger. What I found is that they didn't seem to have any that were longer than 2" and I would need 4" . Maybe I was looking at the wrong thing? Check under "Alloy Steel Shoulder Screws" McMaster-Carr 2 Share this post Link to post Share on other sites
Oldskool 6,644 #10390 Posted April 12, 2021 4 minutes ago, OldWorkHorse said: Maybe I'm new to this buy why does this tractor have 2 fuel tanks? Did I miss somthing? That must be a reserve tank. Nothing worse then running out of gas waaaaay over there somewhere. 2 2 Share this post Link to post Share on other sites
OldWorkHorse 3,045 #10391 Posted April 12, 2021 (edited) 16 minutes ago, Oldskool said: That must be a reserve tank. Nothing worse then running out of gas waaaaay over there somewhere. Was guessing that or a hydraulic tank but never seen thst b4 nifty idea. I just ordered a 2.5 gallon keg tank to cram under the hood. Just have to wait till may 4th to make it work haha. Guess I dnt have to worrie about my tank getting to close to the engine Edited April 12, 2021 by OldWorkHorse 1 Share this post Link to post Share on other sites
Horse Newbie 7,069 #10392 Posted April 12, 2021 12 minutes ago, OldWorkHorse said: Maybe I'm new to this buy why does this tractor have 2 fuel tanks? Did I miss somthing? Maybe it's a long way to the mailbox... 3 Share this post Link to post Share on other sites
OldWorkHorse 3,045 #10393 Posted April 12, 2021 (edited) 1 minute ago, Horse Newbie said: Maybe it's a long way to the mailbox... It's probly for E85... lol Edited April 12, 2021 by OldWorkHorse 1 Share this post Link to post Share on other sites
Gregor 4,846 #10394 Posted April 12, 2021 LOL The 7 HP Kohler is mounted temporarily until I get the K 181 rebuilt. , 2 1 1 Share this post Link to post Share on other sites
Horse Newbie 7,069 #10395 Posted April 12, 2021 Put the 520H hood, belt guard, console side covers, and seat pan back on after painting them Rustoleum Regal Red...I guess the paint job turned out alright... Wish I had some pics of when I first got it... Then I couldn't wait to get my new decals from @Vinylguy put on... What do you horsemen think...and does that Onan sound okay ? I know it's probably hard to tell from a video... Took her out and let her run a bit...had to inspect the curbs and gutters in the neighborhood... 20210411_165354.mp4 7 4 Share this post Link to post Share on other sites
OldWorkHorse 3,045 #10396 Posted April 12, 2021 (edited) 8 minutes ago, Gregor said: LOL The 7 HP Kohler is mounted temporarily until I get the K 181 rebuilt. , That makes more sense. Edited April 12, 2021 by OldWorkHorse 1 Share this post Link to post Share on other sites
OldWorkHorse 3,045 #10397 Posted April 12, 2021 (edited) On 4/11/2021 at 9:08 PM, Horse Newbie said: Edited April 14, 2021 by OldWorkHorse 3 1 Share this post Link to post Share on other sites
ebinmaine 67,483 #10398 Posted April 12, 2021 3 hours ago, Ed Kennell said: What are you sayin..the Bear needed more support at the rear end? This is true. They were on that way when I got it. I don't use any seat springs on any tractors. Notice Patriot doesn't have then or Cinnamon Horse. I've seen others mount roundrobin bassackwareds like that in the past. Seems they're less likely to dump the driver backwards...? Dunno. I don't like seat springs. 3 Share this post Link to post Share on other sites
OldWorkHorse 3,045 #10399 Posted April 12, 2021 3 minutes ago, ebinmaine said: This is true. They were on that way when I got it. I don't use any seat springs on any tractors. Notice Patriot doesn't have then or Cinnamon Horse. I've seen others mount roundrobin bassackwareds like that in the past. Seems they're less likely to dump the driver backwards...? Dunno. I don't like seat springs. I was thinking that backwards things too I fig if imma be bombin though the woods might wanna b pushed forward not backwards she's already a bit tall. 1 Share this post Link to post Share on other sites
Shynon 7,459 #10400 Posted April 12, 2021 Pulled one out of storage today and put awsy snowblower. 4 5 Share this post Link to post Share on other sites
