953 nut 56,692 #10151 Posted April 3, 2021 10 hours ago, Horse Newbie said: How much do these go for in NC ? Oh, about five or ten bucks! You did very well, I payed $ 100 for one twenty years ago. 1 Share this post Link to post Share on other sites
Lee1977 6,910 #10152 Posted April 3, 2021 6 hours ago, Damien Walker said: Threaded adapter pinned onto the shaft as normal and the wheel secured with a nut? My 518H was very bad, but this was the donor fir the power steering conversion I did, so I lost the wheel. Yours looks like a very good solution. That pot metal they used in the wheel fault us all the way, can't drill a round hole in it. We turned more off the shaft, filed and sanded both hole and shaft it just would not go all the way on. The pot metal would stick and gauld. I took it home and worked on it some more same thing. I got it about 2/3 on made sure it was lined up and drove it on, Put the flat and lock washer on tighten it down 2 Share this post Link to post Share on other sites
Damien Walker 246 #10153 Posted April 3, 2021 Can't beat a steel bush! When I was considering doing mine, I thought about using a lathe...but it would be one mighty big lathe. Pressed on and clamped between steel washer and bush as you have done should be much better now....pity they used cheese for the original! Share this post Link to post Share on other sites
Stormin 9,982 #10154 Posted April 3, 2021 After giving the Black Horse a run yesterday, I thought to be fair, I'd treat the Command 800 C-81 just so it didn't feel neglected. It's not been run for 6 months though the battery has been kept charged up. Now after standing unused for a while, it takes a bit of winding up. No primer bulb on it like it's stable mates. That's on the to do list. Turned over fine but didn't fire. So off with the air filter and out with the petrol spray bottle. It's a good job I've long legs and arms. Right hand to operate the key, left to work the spray and left foot on the clutch pedal due to safety switch. Took about a minute for fuel to pump through. before the engine would run without the petrol spray. Didn't take it down the bridleway as it has the finger/sickle bar fitted and the track is rather rough in places. Took it up the lane a little instead. 6 Share this post Link to post Share on other sites
ranger 1,769 #10155 Posted April 3, 2021 On 4/1/2021 at 10:40 PM, Jeff-C175 said: I got to thinking about the tubes in case I need to go that route. What about the valve stem offset? Is that pretty much standard? How can I tell? Is the tube from TSC any good (Traveler) ? Does it have the correct offset for the 7" rear rim ? Be careful when you fit a tube to any wheel/ tire, make sure the valve stem is pointing towards the side of the rim the hole is in, (offset), and never inflate the tube for the first time with the valve in. If you get it wrong, and the valve is installed, the valve stem can disappear inside the tyre, you won’t be able to get the tire off the rim without puncturing the tube to let the air out! Don’t ask me how I know!! 3 Share this post Link to post Share on other sites
ebinmaine 69,664 #10156 Posted April 3, 2021 1 hour ago, ranger said: Be careful when you fit a tube to any wheel/ tire, make sure the valve stem is pointing towards the side of the rim the hole is in, (offset), and never inflate the tube for the first time with the valve in. If you get it wrong, and the valve is installed, the valve stem can disappear inside the tyre, you won’t be able to get the tire off the rim without puncturing the tube to let the air out! Don’t ask me how I know!! I use a pair of locking pliers when airing up the first time. Tire shops have the locking air chuck. Those are worth every penny when you need one. 6 Share this post Link to post Share on other sites
D_Mac 8,942 #10157 Posted April 3, 2021 So today I took the deck back off the 875. I also cleaned the rear tires and wheels. Taking it to friends house next week to get it running. Fingers crossed it won't need much. 4 2 Share this post Link to post Share on other sites
Tractorhead 9,065 #10158 Posted April 3, 2021 (edited) Playing a little on the Engine setup and with the Muffler setup to change the Predators Sound. I measured before on driverseat 96dbA what is not too loud but sounds a little like a church pipe in deep tone. So i calculated the last day’s a little arround with frequencies and frequency ranges and with Airflow pulsation and played today a little on the lathe for get a little more experiences for results in Soundchecks and even some db Reduction. The third change i calculated was the best from the Sound and even it drops the db ratio down to 79-80dbA on driverseat. The Basics exhaust setup was a selfmade flange with maximum outlet of the Engine (1/2“) followed by a 3/4“ 90* Fitting and a welded3/4“ pipe with 5cm. after that comes a 1“ 90* Fitting upwards to the Stack. the stack itself was made of of the fragments of the old Muffler where i built into a rectangle housing of 5cm by 5cm pipe with 4mm thickness and a lenght of 13,3 cm. In the stack itself have 2 chambers, they seperate the Airflow thru the drilled sheetmetal. the upper Pipe with the slope cut was 1“ and measures 21,5 cm from the stack to the highest point on the exhaust pipe. That gives a cool sound deep but it reminds me a little to a church pipe on full throttle. Because of the free flow internal it get this charakeristic Sound. With the today‘s changes - i built a 4,5 cm long 3/4“ insertion pipe, that will be mounted in to 8,5cm from top into the end pipe - it changes the sound to a much more flat Sound. The sound changes from deep pipe sound now to a more deep flat pressure Sound. it sounds like it beeing more Volume but it have not so much db‘s in idle. Curious how this sounds on higher rpm and even on Full throttle. Soundcheck comes soon. Edited April 4, 2021 by Tractorhead Added Picts 2 2 Share this post Link to post Share on other sites
Horse Newbie 7,168 #10159 Posted April 3, 2021 13 hours ago, pullstart said: It LOOKS like an 8”, but pictures can be deceiving. With it laying on the ground that way, measure up to the point In red. That’ll tell you the size. I don’t believe the coulter Wheel size matters, it just puts a slice in the ground before turning it over. Many times (most all times) I run without one. Thanks @pullstart and @Lee1977 I appreciate the response guys ! 1 Share this post Link to post Share on other sites
Horse Newbie 7,168 #10160 Posted April 3, 2021 14 hours ago, pullstart said: Many times (most all times) I run without one. I have a lot of rocks in the ground...coulter wheel would probably just ride up and over them... Share this post Link to post Share on other sites
Horse Newbie 7,168 #10161 Posted April 3, 2021 1 hour ago, D_Mac said: So today I took the deck back off the 875. I also cleaned the rear tires and wheels. Taking it to friends house next week to get it running. Fingers crossed it won't need much. Save that tractor !!! Don't part it out !!! 1 Share this post Link to post Share on other sites
balconio 606 #10162 Posted April 3, 2021 (edited) Harbor freight trailers are completely out of stock in my area so I bought this 300lb capacity atv rack instead. It's awesome! On it I have a pair of 18 gallon Rubbermaid totes, a 5 gallon gas can, and my Milwaukee M18 chainsaw. I also provisioned it to pull my gorilla cart which will work until I can get the 4x8' trailer I want. This setup was amazing for running around the property today and getting a bunch of branches chipped up. Oh yeah and I really want to find a way to carry a fire extinguisher onboard... It's like they left the perfect sized area in the engine bay to carry one, I just have to find a way to mount it securely. Edited April 3, 2021 by balconio 8 8 Share this post Link to post Share on other sites
953 nut 56,692 #10163 Posted April 3, 2021 8 minutes ago, balconio said: I really want to find a way to carry a fire extinguisher onboard... It's like they left the perfect sized area in the engine bay to carry one, I just have to find a way to mount it securely. Never mount a fire extinguisher at the most likely source of a fire. If an engine fire occurred you wouldn't be able to get at it. 4 Share this post Link to post Share on other sites
D_Mac 8,942 #10164 Posted April 4, 2021 47 minutes ago, Horse Newbie said: Save that tractor !!! Don't part it out !!! I'm trying !! Like I said, I was told it needs a rebuild. Previous owner didn't give me much information. I'm hoping it run and drives. I could be surprised.... who knows. 4 Share this post Link to post Share on other sites
Jeff-C175 7,203 #10165 Posted April 4, 2021 3 hours ago, ebinmaine said: I use a pair of locking pliers when airing up the first time. Tire shops have the locking air chuck. Those are worth every penny when you need one. I think the tool for installing tubeless valve stems would work well also. I have a locking chuck but it doesn't hold tight enough that I would trust it for that. It pops off fairly easily. 2 Share this post Link to post Share on other sites
Oldskool 6,660 #10166 Posted April 4, 2021 I find if you have to struggle that much to hold onto it to fill it, it's a good chance you will lose it inside the rim. 3 Share this post Link to post Share on other sites
8ntruck 7,249 #10167 Posted April 4, 2021 1 hour ago, balconio said: Harbor freight trailers are completely out of stock in my area so I bought this 300lb capacity atv rack instead. It's awesome! On it I have a pair of 18 gallon Rubbermaid totes, a 5 gallon gas can, and my Milwaukee M18 chainsaw. I also provisioned it to pull my gorilla cart which will work until I can get the 4x8' trailer I want. This setup was amazing for running around the property today and getting a bunch of branches chipped up. Oh yeah and I really want to find a way to carry a fire extinguisher onboard... It's like they left the perfect sized area in the engine bay to carry one, I just have to find a way to mount it securely. Hey @pullstart, you ever have similar thoughts? 1 1 Share this post Link to post Share on other sites
8ntruck 7,249 #10168 Posted April 4, 2021 Started out today blowing the winter's accumulation of oak leads away from the base of the chain link fence. Blew the leaves out of the adjacent flower beds as well. Then planted 60 or 70 surprise lily bulbs along the bottom of the fence. Next up was wakeing the Horse up to run the sweeper around to pick up the leads the blower dislodged. Open the shed and the right rear tire is flat. OK, add air. Roll it out and check the oil. Reads at add on the dip stick, so add oil. Grab the gas can. It is empty, so off for a gas run for nob-ethanol fuel. Add Sea Foam. Remembered to open the gas shutoff valve (!). Normal amount of cranking, and it fires right up. Cruse around the yard at 3/4 throttle and 3rd gear for about 20 minutes,, no issues. I did notice some gear oil on the floor under the right axle, maybe an ounce or two. Must have leaked past the seal when the tractor was leaning that way due to the flat tire. Guess I'm going to have to put hub removal and axle seals on the work list. 4 Share this post Link to post Share on other sites
76c12091520h 3,720 #10169 Posted April 4, 2021 Got the C120 out for the first time this year, pulled the thatcher behind it first while mowing, then went over the whole yard with my Parker sweeper ( that came in a Toro/Wheel Horse box). 7 4 Share this post Link to post Share on other sites
ebinmaine 69,664 #10170 Posted April 4, 2021 6 hours ago, 8ntruck said: hub removal Take a minute to remove the hub set screw(s). Put some penetrating oil in. Reapply after a few hours. Repeat for a few days. 2 Share this post Link to post Share on other sites
pfrederi 18,147 #10171 Posted April 4, 2021 (edited) 12 hours ago, balconio said: Harbor freight trailers are completely out of stock in my area so I bought this 300lb capacity atv rack instead. It's awesome! On it I have a pair of 18 gallon Rubbermaid totes, a 5 gallon gas can, and my Milwaukee M18 chainsaw. I also provisioned it to pull my gorilla cart which will work until I can get the 4x8' trailer I want. This setup was amazing for running around the property today and getting a bunch of branches chipped up. Oh yeah and I really want to find a way to carry a fire extinguisher onboard... It's like they left the perfect sized area in the engine bay to carry one, I just have to find a way to mount it securely. Are you able to run the chipper in the wagon or do you have to lift it out... Edited April 4, 2021 by pfrederi 1 Share this post Link to post Share on other sites
Oldskool 6,660 #10172 Posted April 4, 2021 Sometimes it's the little things. I needed a cig lighter/12v port for the new tractor. I just couldnt stand the little plastic knob so I turned out a stainless one for it. Uch better. It's close enough to an original. 6 4 Share this post Link to post Share on other sites
ebinmaine 69,664 #10173 Posted April 4, 2021 39 minutes ago, Oldskool said: Sometimes it's the little things. I needed a cig lighter/12v port for the new tractor. I just couldnt stand the little plastic knob so I turned out a stainless one for it. Uch better. It's close enough to an original. Niiiiiiiiiiice Share this post Link to post Share on other sites
Tractorhead 9,065 #10174 Posted April 4, 2021 Here the promised Soundcheck. 2 3 Share this post Link to post Share on other sites
Jeff-C175 7,203 #10175 Posted April 4, 2021 Treasurer OK'd a cheap welder! Picked up th HF Titanium 125 Flux unit. Mower deck is apart for rehab and the rear mount points had the typical cracks so decided to start with those. Worked GREAT! Hope they don't crack again... Scraped and wire brushed the underside and coat of 'Rust Reformer'. Applied a coat of Regal Red to the topside. Pics later... 2 1 Share this post Link to post Share on other sites
