SylvanLakeWH 25,557 #9976 Posted March 26, 2021 Did they duck? 4 Share this post Link to post Share on other sites
ebinmaine 67,486 #9977 Posted March 26, 2021 2 minutes ago, SylvanLakeWH said: Did they duck? 400!!!! You nailed it. And yes they did. 2 1 Share this post Link to post Share on other sites
SylvanLakeWH 25,557 #9978 Posted March 26, 2021 Page 400 heh...? So... Trophy...? Free tractor...? Lifetime RS Membership...? Or, meh... 1 2 Share this post Link to post Share on other sites
Oldskool 6,644 #9979 Posted March 26, 2021 Just now, SylvanLakeWH said: Page 400 heh...? So... Trophy...? Free tractor...? Lifetime RS Membership...? Or, meh... How bout a........... 2 Share this post Link to post Share on other sites
Ed Kennell 38,170 #9980 Posted March 26, 2021 On 1/15/2018 at 10:28 AM, Ed Kennell said: Ok, maybe this will get us back on topic. Today I made a safety light and pole for the 312 plow tractor . Page 1 post 1 3 1 Share this post Link to post Share on other sites
balconio 606 #9981 Posted March 26, 2021 On 3/24/2021 at 6:09 PM, squonk said: Took the blower off the C-160 today. It will snow for sure! I had this exact same thought last Sunday when I decided to remove my blower... 2 Share this post Link to post Share on other sites
balconio 606 #9982 Posted March 26, 2021 15 hours ago, Gregor said: I have read, and heard differing opinions about running a str8 pipe. Some claim it's hard on a small engine. It needs a muffler. Others say it's no problem. Opinions? I like the sound of yours, and no more than my tractors run, the noise would not be a problem. My experience on N/A bikes, cars, and small engines has been that straight thru exhaust kills your low/mid range torque but can slightly increase hp at the top end of the rev range IF you have a modified valvetrain/cam and can increase the redline. On a stock engine all you're doing is generating a ton of noise and ruining driveability. That said I loved how my stock Yamaha XS650 sounded with straight through 1.5" pipes cut real long... Shorter pipes caused it to pop and backfire too much even after jetting the carb but the longer pipes took care of all that. Now on a turbocharged vehicle, yes straight through is always better across the powerband than running a muffler but there are much different dynamics at play when boosting. 5 Share this post Link to post Share on other sites
Tractorhead 9,064 #9983 Posted March 26, 2021 (edited) 5 hours ago, 953 nut said: The output from the R/R on a Kohler or other engine is pulsating DC. The meter doesn't know the difference. If there is a single diode like some of the later engines use the reading may not be as accurate. you be right Richard, it allway‘s depending on what you like to measure. Our Trainer some moons ago allway‘s told us The one who measure fails. That‘s my also my reason why a DC measurement make no sense especially with a analog meter what is too slow to register short impulses. so just the collection of much impulses on higher RPM are more usable to estimate little closer. So in consequences of that the AC current measurement is more Accurate on charging, to check the consumption the DC current measure make more sense. Depending allway‘s what is to measure, if a Regulator is in Charging system a DC current give you an response if it work. The pulsating systems are without integration hard to measure. For bit more exact Values a Memory scope and a AC/DC Ammeter Clamp is a good way to start, but fully over the top for our use on the Tractas just to see if you charge or not. a clamp ammeter ac/ dc is a cheap and good Way to estimate if you on a good way Edited March 26, 2021 by Tractorhead Share this post Link to post Share on other sites
Herder 2,354 #9984 Posted March 26, 2021 9 hours ago, TonyToro said: Awesome! That’s what my son wants us to do this weekend. Does that lift arm stay in after the tiller is removed? The tractor we are using also is a snowblower. Yes, the rear lift arm will stay in. The install took about 30 minutes, now that it's complete the tiller can be removed or put back on rather quickly. The rear lift wont effect the functions of the mid lift, you may have to disconnect the cable in order to install the flag shaft for the snowthrower. 1 Share this post Link to post Share on other sites
jamessparks 55 #9985 Posted March 26, 2021 Well even though it was blowing and windy got to finally see some warm weather to paint my wagon 11 1 Share this post Link to post Share on other sites
johnnymag3 2,520 #9986 Posted March 26, 2021 Paint your wagon....excellent movie !!!!! looks Good............. 1 1 Share this post Link to post Share on other sites
OldWorkHorse 3,045 #9987 Posted March 26, 2021 Finished the under side of the 1257Heavy paint on frame and then tried out a paint on the rims... said copper.... I don't know... 🤔 5 2 1 Share this post Link to post Share on other sites
ebinmaine 67,486 #9988 Posted March 26, 2021 8 minutes ago, OldWorkHorse said: 1257Heavy paint Frame looks great!! Copper.... Looks more like clay?? What's the paint ?? 1 Share this post Link to post Share on other sites
OldWorkHorse 3,045 #9989 Posted March 26, 2021 13 minutes ago, ebinmaine said: Copper.... Looks more like clay?? What's the paint ?? 1 Share this post Link to post Share on other sites
Pullstart 62,858 #9990 Posted March 26, 2021 Mrs. P has a couple girlfriends over. Kids have one friend over. Shop night! 9 1 1 Share this post Link to post Share on other sites
SylvanLakeWH 25,557 #9991 Posted March 27, 2021 NICE popcorn holder! 1 1 Share this post Link to post Share on other sites
Pullstart 62,858 #9992 Posted March 27, 2021 @SylvanLakeWH these would hold even more! 3 1 2 1 Share this post Link to post Share on other sites
8ntruck 7,003 #9993 Posted March 27, 2021 Only a popcorn holder? I was hoping that you came up with a popcorn popper attachment. Run the exhaust through a heat exchanger to make the popper pan hot, and an 8 gazillion to one reduction off of the PTO to run the stirring mechanism....... Would probably be a big hit at shows. 1 1 3 Share this post Link to post Share on other sites
MikMacMike 479 #9994 Posted March 27, 2021 On 3/24/2021 at 12:52 PM, cschannuth said: I hooked one of them up to the lawn roller and tried to smooth things out a bit before it starts to get too hard out. IMG_7847.MOV 14.34 MB · 0 downloads When you can tune with your ear its not hard to recognize the sounds, but if theres no pic you cheated us........hehehehehh Just me being a funny guy after 6 beers sitting in the ol shop after a days beating on the old bones. Mike. 1 Share this post Link to post Share on other sites
Pullstart 62,858 #9995 Posted March 27, 2021 6 hours ago, 8ntruck said: Only a popcorn holder? I was hoping that you came up with a popcorn popper attachment. Run the exhaust through a heat exchanger to make the popper pan hot, and an 8 gazillion to one reduction off of the PTO to run the stirring mechanism....... Would probably be a big hit at shows. Like s’mores, I’m not much a popcorn fan either. Great idea though! Bill you come down and explore the shop, it’s much cleaner than your previous visits! Build away, buddy! 1 Share this post Link to post Share on other sites
953 nut 55,224 #9996 Posted March 27, 2021 7 hours ago, 8ntruck said: Only a popcorn holder? I was hoping that you came up with a popcorn popper attachment. Run the exhaust through a heat exchanger to make the popper pan hot, and an 8 gazillion to one reduction off of the PTO to run the stirring mechanism....... Would probably be a big hit at shows. Good idea. Glad you volunteered. If you get to work on it you will have the popper ready for the Big Show! 1 1 Share this post Link to post Share on other sites
Pullstart 62,858 #9997 Posted March 27, 2021 1 hour ago, 953 nut said: Good idea. Glad you volunteered. If you get to work on it you will have the popper ready for the Big Show! ! I’ll stand and tend the gas tank... or pull cord if it’s a Tecky! 1 Share this post Link to post Share on other sites
Pullstart 62,858 #9998 Posted March 27, 2021 400 pages and nearly 10,000 posts! Share this post Link to post Share on other sites
Ed Kennell 38,170 #9999 Posted March 27, 2021 10,000 posts. Thank you all for your contributions. 1 5 Share this post Link to post Share on other sites
Pullstart 62,858 #10000 Posted March 27, 2021 Unreal! 3 1 Share this post Link to post Share on other sites
