ebinmaine 70,717 #951 Posted July 28, 2018 8 hours ago, rjg854 said: Sweet looking tractor you got there @kto434... What he said. Share this post Link to post Share on other sites
Danedg 20 #952 Posted July 28, 2018 Today I was wondering about how to widen the rear wheel base to alleviate her nervousness about tippynes. Are there spacers or dually kits? Share this post Link to post Share on other sites
pfrederi 18,328 #953 Posted July 28, 2018 3 minutes ago, Danedg said: Today I was wondering about how to widen the rear wheel base to alleviate her nervousness about tippynes. Are there spacers or dually kits? What model are talking about. It would take a steep hill to roll a WH sideways and it would be pretty obvious you shouldn't be there. also the engines have designed limits for tilting (oil starvation) that are less than potential roll over. 1 1 Share this post Link to post Share on other sites
johnnymag3 2,559 #954 Posted July 29, 2018 He has my B-80- I never felt tippy with it, maybe Dan should not mow side hills with a 45 degree angle LOL Share this post Link to post Share on other sites
Danedg 20 #955 Posted July 29, 2018 (edited) 13 hours ago, johnnymag3 said: He has my B-80- I never felt tippy with it, maybe Dan should not mow side hills with a 45 degree angle LOL Edited July 29, 2018 by Danedg Share this post Link to post Share on other sites
pfrederi 18,328 #956 Posted July 29, 2018 You could go to wider rear tires 23 10.50 12 (I assume you have 8.50s on there now). Going to duals would be expensive and put a lot of stress on the 1" axles i believe you have. And make mowing around things awkward as the tires stick out way beyond the deck Dual adapters show up on ebay from time to time. If you have a 36" deck you could do up to a 42" With the deck sticking out beyond the wheels roll over would be difficult to achieve. 1 Share this post Link to post Share on other sites
wallfish 17,487 #957 Posted July 29, 2018 18 hours ago, Danedg said: Are there spacers or dually kits? This type doesn't allow dirt and mud to get between the rims. or at least not as much. Work very well and are easy on, easy off. No or very little air pressure in the outside tires! Mowing up and down the hill instead of sideways is better if possible. https://www.ebay.com/itm/Dual-Wheel-Kit-for-Lawn-Garden-Tractor-Tires-John-Deere-Cub-Cadet-Wheelhorse/350099069962?hash=item518387dc0a:g:VhAAAOSwEehbMOxr 3 Share this post Link to post Share on other sites
oneroadkingman 53 #958 Posted August 2, 2018 Well today put a fuel filter on my 520 new gas line Iran pull the gas tank out cleaned it put it back together changing the hydraulic oil put on axle seals in it 1 Share this post Link to post Share on other sites
rjg854 11,879 #959 Posted August 2, 2018 (edited) been trying since last week end to get the brake drum off so I can change the oil seal The hub came off without any issues. I've tried pb blaster, heat, wax, oil, carb cleaner. BFHs, crowbars, pullers, impact wrench and even a grinder to be sure the end of the shaft hasn't mushroomed. I haven't given up yet, but, it may come down to cutting the thing off. I've moved it in and out on the shaft from the snap clip to the end of the shaft a couple of times but it just won't go any further than that Edited August 2, 2018 by rjg854 More 1 Share this post Link to post Share on other sites
oneroadkingman 53 #960 Posted August 3, 2018 Well I didn't realize that putting hydraulic oil and was such a hard task it kept wanting to burp at me! Share this post Link to post Share on other sites
Russell Aretz 16 #961 Posted August 4, 2018 Today I went out to my shed and looked at my old tractor. And joined. She is a 1277 Runs and has all the goods. 1 2 Share this post Link to post Share on other sites
wallfish 17,487 #962 Posted August 4, 2018 12 minutes ago, Russell Aretz said: Today I went out to my shed and looked at my old tractor. And joined. She is a 1277 Runs and has all the goods. That's funny Russell Glad you're here. Please don't run her without the engine blower cover! It will over heat 1 Share this post Link to post Share on other sites
AMC RULES 37,145 #963 Posted August 5, 2018 Mowed the back yard... with the new REO skiff this afternoon. Not a bad cut, considering it rained all night, and today until noon. Then snatched up the high rise tub cart, just because it was there. 2 2 Share this post Link to post Share on other sites
Russell Aretz 16 #964 Posted August 5, 2018 I started to paint. I had er since1995. Done er over. Now its time to do it right. Please give me advise like give up or start over. Share this post Link to post Share on other sites
TonyToro 1,101 #965 Posted August 5, 2018 (edited) Me and my little driver are fixing the Raider 12 that broke at the tractor pull. Broken woodruff key and buggered hub. 😞 The hub also cracked after trying to pull it off. I'll search the classifieds after this post for a hub. Edited August 5, 2018 by TonyToro Share this post Link to post Share on other sites
Lane Ranger 11,125 #966 Posted August 5, 2018 (edited) 41 minutes ago, TonyToro said: Me and my little driver are fixing the Raider 12 that broke at the tractor pull. Broken woodruff key and buggered hub. 😞 The hub also cracked after trying to pull it off. I'll search the classifieds after this post for a hub. I have done that too! I did JB Weld the hub and It has held up for two years! But I was not tractor pulling! Edited August 5, 2018 by Lane Ranger 1 Share this post Link to post Share on other sites
rjg854 11,879 #967 Posted August 5, 2018 Well at least you still have all the lug holes. Unless the key way is messed up, you'll have a backup, or a hub to make a puller out of it. 1 Share this post Link to post Share on other sites
19richie66 17,576 #968 Posted August 5, 2018 Welded the 1054 “tower assembly” to the gt14 frame. Now the fun begins. 3 2 Share this post Link to post Share on other sites
Russell Aretz 16 #969 Posted August 6, 2018 I started to paint. I had er since1995. Done er over. Now its time to do it right. Please give me advise like give up or start over. 1 Share this post Link to post Share on other sites
thecoverworks 23 #970 Posted August 6, 2018 Took it to a classic tractor show and steam fair ! Spoiler 2 2 Share this post Link to post Share on other sites
Tach-a-matic 357 #971 Posted August 7, 2018 Mounted the blower and installed a new chain. 2 2 Share this post Link to post Share on other sites
19richie66 17,576 #972 Posted August 7, 2018 Clean machine there. 1 Share this post Link to post Share on other sites
rjg854 11,879 #973 Posted August 7, 2018 Looks like it ought to do the job. But at 90+ degrees here today, I don't think you're going to get much seat time with it 4 Share this post Link to post Share on other sites
dells68 7,498 #974 Posted August 7, 2018 I finally got the 8" front wheels on the 312. Maybe over the winter I can find tine to paint the 42" deck. Mowed with it tonight and it mows great. I still need to add a little toe in on the front since switching out the front. Here are a couple of before and after pics with the new wheels and deck. 4 5 Share this post Link to post Share on other sites
Dadlife520H 195 #975 Posted August 7, 2018 11 hours ago, dells68 said: I finally got the 8" front wheels on the 312. Maybe over the winter I can find tine to paint the 42" deck. Mowed with it tonight and it mows great. I still need to add a little toe in on the front since switching out the front. Here are a couple of before and after pics with the new wheels and deck. The 8" look so much better. Been wanting to do the same to both of mine.... 1 Share this post Link to post Share on other sites
