cafoose 3,355 #901 Posted July 15, 2018 I got the blade separated from the frame on the dozer setup I got last week! Must have been outside for a long time nothing moved on it. Everything was rusted tight. I had to knock the pivot bolt out with the air hammer and knock the angle locking pin loose with the air hammer and kroil! Getting it ready for the mad max front tiller! I also got the slot hitch off the C-161 8 speed getting ready for the rear tiller. It came off rather easily with the air hammer and kroil! 1 Share this post Link to post Share on other sites
Racinbob 11,077 #902 Posted July 15, 2018 Very cool! Be aware that you have the older style tiller (likely a 7-1211) and it uses two belts running through an idler setup just in front of the transmission. You have to move the right floor board out and use an additional guard. BUT.....by using a newer style idler on the mid mount hitch you can eliminate the idler in front of the tranny and the second guard and just use one belt like the newer style. Also, the style you have uses the slot hitch to lift it but there's no reason you can't connect the lift like the new style. I'll assume that you realize that your blade frame is for a short wheelbase. Using the Mad Max tiller clone on one of your shorties? Share this post Link to post Share on other sites
cafoose 3,355 #903 Posted July 15, 2018 8 minutes ago, Racinbob said: I'll assume that you realize that your blade frame is for a short wheelbase. Using the Mad Max tiller clone on one of your shorties? I'm thinking about using it on my Commando 8 if it can handle it Share this post Link to post Share on other sites
Racinbob 11,077 #904 Posted July 15, 2018 Yupper duppers. That will do just fine. Share this post Link to post Share on other sites
Racinbob 11,077 #905 Posted July 15, 2018 By the way, I used that style tiller set up like I mentioned on a 76 C series. I did used the slot hitch to lift it and I liked it better than the newer style tillers. Share this post Link to post Share on other sites
cafoose 3,355 #906 Posted July 15, 2018 (edited) 31 minutes ago, Racinbob said: Very cool! Be aware that you have the older style tiller (likely a 7-1211) and it uses two belts running through an idler setup just in front of the transmission. You have to move the right floor board out and use an additional guard. BUT.....by using a newer style idler on the mid mount hitch you can eliminate the idler in front of the tranny and the second guard and just use one belt like the newer style. Also, the style you have uses the slot hitch to lift it but there's no reason you can't connect the lift like the new style This is what I got and one I found mounted at the big show: Edited July 15, 2018 by cafoose 1 1 Share this post Link to post Share on other sites
Racinbob 11,077 #907 Posted July 15, 2018 The first 3 pictures are the idler that mounts just to the front of the tranny (p/n 7697). The other shots are of the newer style. There's a bracket on your tiller that isn't original and isn't needed. The kinda L shaped bracket with a series of holes. I'm thinking that was done for lifting purposes. Here's the manual for it that should help: That's how it was intended but I used an idler directly under the PTO and just one belt. Advantages: simpler installation, the slot hitch didn't have to be removed, the footrest didn't have to be moved, no second belt guard needed. Disadvantage: the axle bracket wouldn't work with a snowblade. That didn't bother me because I used the tiller on my blower tractor and a different one for the blade. Share this post Link to post Share on other sites
pfrederi 17,739 #908 Posted July 17, 2018 (edited) Worked on one of my FAVORITE WH projects. steering wheel removal. So far 2.5 hours invested and have only completed first half. I knew by the rust this would be a hard pull but this one is really testing me. Start tear down horse so you can remove steering column and Instrument panel as a unit. Pic 1 Clean paint off shaft below shaft collar. Then loosen set screw in collar...oops frozen and stripped....Left hand drill ...no joy. Drove in a square easy out and surprise it actually worked Get shaft braced in vice to drive out roll pin. No joy again. One end of the pin has something solid in it...Broken punch or drill bit maybe??? what ever it was it was hard!! Drill did nothing. wore down two dremel carbide cutter bits and got some of it out. Finally with a lot of pounding on the roll pin punch it came out. Now ready for phase two. Driving the steering wheel down the shaft then cleaning up the end of the shaft and hopefully it will slide right off. Got it clamped in the vice (last picture) have it soaking with more bug juice. Have step ladder so i can get a good swing with the BFH and an impact socket as a drive tool. Have some other thing to do now and an appt in the am. maybe tomorrow PM finish phase 2...I hope. Edited July 17, 2018 by pfrederi 1 Share this post Link to post Share on other sites
johnnymag3 2,520 #909 Posted July 17, 2018 I think you would be much better off using heat and cool technique......heat cool heat cool heat cool. do this 3-4 times and you would have that darn thing off. Heat quickly, then ice cold water several times hot/cold hot/cold hot/cold makes everything expand and contract wildly.....and loosens the rust quickly. then you have made room for the penetrant to get in and help out a little bit. If you do not make space for the juice to get in, it takes forever. Rust is a $!%@# Good Luck with your project, you will get it done Share this post Link to post Share on other sites
pfrederi 17,739 #910 Posted July 17, 2018 Heat is hard on the plastic steering wheel. Share this post Link to post Share on other sites
johnnymag3 2,520 #911 Posted July 17, 2018 I do realize that, ive done many of those buggers.......heat the shaft, not the wheel or collar, ,,,,,make the shaft swell, then shrink.....Just an option. Good luck, you will WIN !!!! john Share this post Link to post Share on other sites
johnnymag3 2,520 #912 Posted July 17, 2018 You can lead a Horse to the Steering Wheel, but you cant make it come off.. Patience.....and persevere 1 Share this post Link to post Share on other sites
pfrederi 17,739 #913 Posted July 17, 2018 Victory!!! 6 whacks with an 8lb sledge and it slid down. One last frustration the woodruff key was stuck. used Johnnymags method heated and quenched 3 times and the chisel got it out 3 2 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,297 #914 Posted July 17, 2018 BFH usually helps unstick stubborn items. Also good for making toothpicks out of 2x4's. 2 Share this post Link to post Share on other sites
johnnymag3 2,520 #915 Posted July 17, 2018 Good job !!!!!! looks great, and I know the happiness when things actually happen the way you want them to !!! SUCCESS Share this post Link to post Share on other sites
oneroadkingman 53 #916 Posted July 17, 2018 Well I hope you didn't use that bottle of lager to cool it down with LOL Share this post Link to post Share on other sites
johnnymag3 2,520 #917 Posted July 17, 2018 That would be a waste !!!! Share this post Link to post Share on other sites
oneroadkingman 53 #918 Posted July 17, 2018 Most definitely!!! Share this post Link to post Share on other sites
Sarge 3,463 #919 Posted July 18, 2018 (edited) Finally got fed up with this 48" SD deck throwing grass clippings forward into the K341's engine screen and plugging up it's cooling intake, took a day out of other projects and did this - Finished, deck height selector in the middle position/notch - Test run went very well at that height. I should have made the rubber sections taller and just notched the bolt/wheel locations so it could be adjusted for height. It was a bit too short for mowing on the 4th notch, but even with the grass utterly soaking wet, it mowed a lot better. Seemed to create a much better vacuum and better discharge air flow to help spread the clippings like it should. Even at the 4th height setting, nearly nothing got thrown towards the engine's intake screen - nice not to have to shut it down every 30 minutes and clean it off to prevent overheating the block on the hot-headed K341 series engines. I have one block that is junk from never having it's fins cleaned and seen far too many cracked from the intake being starved of fresh air. The thing still has one issue - no matter what, single blades or doubled, it wants to throw too much material directly at the height gauge wheel/axle and start plugging the discharge chute up. Depending upon how wet the grass is, or how much weeds determines how fast it plugs. I have yet to see in person one of the original stock discharge chutes that fits these decks, only seen them in pictures or on the drawings - does that chute actually prevent this, or create other problems? I've considered making up a baffle shaped like the originals to help prevent this, as well as another one for the left rear corner area where these decks always plug/rot out. I'd also like to take the time to tear it down and remove every single fastener head out of the interior where it can accumulate clippings - just welded studs like I did on the front skirt. If you look at modern deck designs - they avoid those things and the air flow is much better, not to mention their baffles are designed much tighter to the blade tips, making them much more efficient. Sarge Edited July 18, 2018 by Sarge forgot detail 1 Share this post Link to post Share on other sites
Racinbob 11,077 #920 Posted July 18, 2018 (edited) I'm able to get back to some light work so I decided to drain and flush the transmission on the 854 I picked up at the big show. This is from the initial drain: There wasn't a quarter cup in there! That's no way to treat a Wheel Horse. I dumped in a couple quarts of motor flush and ran it around a bit then drained it. I'm going to open it up and check things out. I know I need to take care of some in/out play on the input shaft in 3rd gear. Hopefully not much else. Edited July 18, 2018 by Racinbob Share this post Link to post Share on other sites
MarkS 122 #921 Posted July 19, 2018 Got the C-125 out today to do a little mowing. Also used my Lawn Ranger and the cart to move some old cabinets from the barn to the house! 1 1 Share this post Link to post Share on other sites
pfrederi 17,739 #922 Posted July 19, 2018 14 hours ago, MarkS said: Got the C-125 out today to do a little mowing. Also used my Lawn Ranger and the cart to move some old cabinets from the barn to the house! Lawn Rangers make great chore tractors...Much easier to get on and off than their bigger brothers 1 Share this post Link to post Share on other sites
dells68 7,498 #923 Posted July 19, 2018 (edited) We set up 12 of our horses at our local show today. Our show runs through Saturday in Abingdon,VA. Come on out if you get a chance. The more the merrier! A nice little CubCadet showed up for sale, but the price Is a little too high for me. Maybe I'm just stuck on our little horses! Edited July 19, 2018 by dells68 Added picture 1 9 Share this post Link to post Share on other sites
Lane Ranger 10,968 #924 Posted July 20, 2018 My brother David and I rebuilt a 42 inch side discharge mower deck for use ona C160 Wheel Horse. Took some time as old spindle hex bolt heads weee worn thin. Used bolt extractor on two spindle housings and had to cut and drill third one out! This deck is unique as we have three different type of 42 spindles with three different type of pillows .’, but they all match up fine with spindle deck belt. 3 Share this post Link to post Share on other sites
Lane Ranger 10,968 #925 Posted July 20, 2018 Bought a rough 312-8 from 1996 to cleanupand use as General tractor for $200 on Tuesday. Bought the front end end of a B 100 and 10 HP Kohler and helped my neighbor use the automatic transmission on the B 100 as a replacement for his tractor. Put out a new knob on the front of s Wheel Horse mule drive. 5 Share this post Link to post Share on other sites
