Handy Don 12,232 #8451 Posted January 2, 2021 1 minute ago, Horse Newbie said: I reglued mine on my 520H by spraying adhesive on the back and resticking it on. I looked at that, but wasn't confident that it would stand the heat of the sun in summer. The tape is good to 150 degrees (at that temp, I wilt anyway). 1 2 Share this post Link to post Share on other sites
Horse Newbie 7,069 #8452 Posted January 2, 2021 Have you looked on the backside of your gauges for small bulb sockets...forgive me if these questions seem elementary...I'm definitely no expert.. 2 Share this post Link to post Share on other sites
Horse Newbie 7,069 #8453 Posted January 2, 2021 5 minutes ago, Handy Don said: I looked at that, but wasn't confident that it would stand the heat of the sun in summer. The tape is good to 150 degrees (at that temp, I wilt anyway). I hope my spray adhesive holds...it seemed to stick very well... 1 Share this post Link to post Share on other sites
Horse Newbie 7,069 #8454 Posted January 2, 2021 @Handy Don I looked at the parts diagram for an 1988 518-H and did not see any bulbs or bulb sockets on there. 1 1 Share this post Link to post Share on other sites
HorseFixer 2,012 #8455 Posted January 2, 2021 THE 520-SC <<< SC for Snow Chucker Wheel Horse only made a prototype when I got her. Well she don't eat rocks so good. So while I'm at it I'm replacing bearings. She used to be up front of garage but now has to set in back Cause the F-350 nudged it over. 6 Share this post Link to post Share on other sites
AMC RULES 37,130 #8456 Posted January 2, 2021 Hard to imagine a Senior burried in there! 2 Share this post Link to post Share on other sites
cleat 5,981 #8457 Posted January 2, 2021 9 hours ago, Horse Newbie said: Have you looked on the backside of your gauges for small bulb sockets...forgive me if these questions seem elementary...I'm definitely no expert.. The SW gauges in your 518H will have plugs in the holes in the backside of the gauges for lights to be inserted. The newer 520's came with lights installed so you might be able to source lights from a newer machine. I think there was only one or two years in the early 90's that had both lights and SW gauges. Don't know if the lights from the plastic toro gauges fit or not. However, even with a good light inserted into the hole there is no light passes through the face of the gauge like you might expect. Only a little halo of light around the outside of the gauge face so you won't notice a lot of difference. Might be cheaper and easier to wear a hat with a little light in the brim so when you look down at the gauges they are lit up ? 1 Share this post Link to post Share on other sites
HorseFixer 2,012 #8458 Posted January 2, 2021 (edited) AMC if you look closely in the picture behind the 520 and the XI you can see the seniors hood. Edited January 2, 2021 by HorseFixer 1 Share this post Link to post Share on other sites
AMC RULES 37,130 #8459 Posted January 2, 2021 (edited) I was thinking that may be it. Edited January 2, 2021 by AMC RULES 2 Share this post Link to post Share on other sites
HorseFixer 2,012 #8460 Posted January 2, 2021 I have it on Jackstands on a Hydraulic Lift Table. 3 Share this post Link to post Share on other sites
Jhook 849 #8461 Posted January 2, 2021 Got studs welded on to the loader subframe so my drum weights are now bolted down. I need to replace the drive belt hopefully this weekend, its brand new but i was lazy putting it on, and it shredded right away cause i had it on the wrong side of the belt guard. Been limping it around with my shredded belt for weeks now 😂 2 Share this post Link to post Share on other sites
Pullstart 62,883 #8462 Posted January 2, 2021 @AMC RULES What’s up with the 4” piece of rope... or am I missing something? 1 Share this post Link to post Share on other sites
Handy Don 12,232 #8464 Posted January 2, 2021 1 hour ago, cleat said: Might be cheaper and easier to wear a hat with a little light in the brim so when you look down at the gauges Agreed. I'll use my headlamp, if I need to do dark work. That would also show me where the levers and switches are in the dark! The gauges are not the kind with a bulb option and there is no wiring for bulbs. Definitely not worth replacing gauges just to get lights! 2 Share this post Link to post Share on other sites
HorseFixer 2,012 #8465 Posted January 2, 2021 @Handy DonAn Ole Pilots Trick is to use Red Lights it does not take away from seeing outside Sure Miss the Ole Gal November 4970 Lema. That was 31 years ago! 6 Share this post Link to post Share on other sites
Handy Don 12,232 #8466 Posted January 2, 2021 31 minutes ago, HorseFixer said: An Ole Pilots Trick is to use Red Lights it does not take away from seeing outside Sure Miss the Ole Gal November 4970 Lema. That was 31 years ago! Luckily, my headlamp has a red setting! Nice seeing the plane, I'm sure that was a lot of fun. In that era I was learning to fly a sailplane. Absolute blast, but in the end realized it was a hobby incompatible with having a young family so I gave it up. 1 Share this post Link to post Share on other sites
Pullstart 62,883 #8467 Posted January 2, 2021 1 hour ago, pullstart said: @AMC RULES What’s up with the 4” piece of rope... or am I missing something? 1 hour ago, AMC RULES said: ?? Oh that’s the old broken rope, huh? So the replacement wraps around a post or is clamped in place? 1 Share this post Link to post Share on other sites
Rob R 966 #8468 Posted January 2, 2021 On 1/1/2021 at 11:40 AM, squonk said: On a more serious note, I had a neighbor bring me his push mower he couldn't get started. Turned out his recoil rope kept breaking so he just tied the handle to what was left. Ended up with a cord about a foot and a half long. Bout tore my arm off the first time I gave it a yank! I'm thinking you have a busted flywheel key and she's out of time........... 1 1 Share this post Link to post Share on other sites
Tractorhead 9,064 #8469 Posted January 2, 2021 Because i don’t have my Rims until now, i decided today to give the Engine a closer inspection today. first i remove the Head to see what‘s happen. This is what i found. That Screams for a decarbon urgently. Ok, i will do that, the result looks so. than i checked the Head and align it. after that i install a new headgasket. I see while cranking the Engine, the Piston pumps some oil, seems i need new Pistonrings and a rehone the Cylindre. While thinkering i begin to rework The Enginecover a little. So let‘s grab few tools and let us begin. After cleaning and degrease a coat of Primer and after cure a new Color skin. While it needs little time to dry, i stop the work for today. Time to search for pistonrings... or maybe... 5 1 Share this post Link to post Share on other sites
sparkie333 265 #8470 Posted January 2, 2021 21 hours ago, ebinmaine said: Got the front lights wired up and working on Trina's Pig Pen 867. you got hi and low beams on that tractor? 2 1 Share this post Link to post Share on other sites
sparkie333 265 #8471 Posted January 2, 2021 1 hour ago, Tractorhead said: Yep you got to get rid of that carbon. Share this post Link to post Share on other sites
sparkie333 265 #8472 Posted January 2, 2021 1 hour ago, Tractorhead said: his is what i found. Yep needs fix and now you goy that engine top looking good. and good job. 1 1 Share this post Link to post Share on other sites
sparkie333 265 #8473 Posted January 2, 2021 I had notifications come up but when I clicked on them it didn't send me to them. I don't know what the problem is. sorry guys Maxwell 8 and ebinmaine 2 Share this post Link to post Share on other sites
Maxwell-8 4,275 #8474 Posted January 2, 2021 (edited) 5 minutes ago, sparkie333 said: I had notifications come up but when I clicked on them it didn't send me to them. I don't know what the problem is. sorry guys Maxwell 8 and ebinmaine no proplemo, try use @ and then type or name, so we get a notification Edited January 2, 2021 by Maxwell-8 3 Share this post Link to post Share on other sites
ebinmaine 67,502 #8475 Posted January 2, 2021 1 hour ago, sparkie333 said: you got hi and low beams on that tractor? No sir. Single speed headlights. 2 1 1 Share this post Link to post Share on other sites
