ebinmaine 67,515 #7351 Posted October 28, 2020 15 minutes ago, OldWorkHorse said: retrieved the rear end plug from the bottom of old engine, old gear oil, and who knows what Should've found some neighborhood kid and paid 'em to fetch it. Share this post Link to post Share on other sites
peter lena 8,629 #7353 Posted October 28, 2020 J HOOK , this is the bearing type ,https://www.vxb.com/3-4-UCFL204-12-2-Bolts-Flanged-Housing-Mounted-p/Kit7334.htm?gclid=Cj0KCQjwreT8BRDTARIsAJLI0KK_Gk0gzeJ-91hB9TG19SBWIq7o_UX-OnUHm0RCJiVyfQWTiYCy-RgaAm3nEALw_wcB , with a tractor like you have , and the opportunity of it being in pieces , you can upgrade as you go along ( if you want to ) during assembly and possibly improve a more secure steering column , just an idea , good luck , pete Share this post Link to post Share on other sites
Tractorhead 9,064 #7354 Posted October 28, 2020 Get today a delivery of some Steel i wait for. like to built a Frame myself from Scratch.. firstly find the needed lenght, i like to have. i ended up from rearaxle to Tip with 1,60 meter. than i cutted the lenght and use the Bandsaw and later the Grinder to cut angles in. i cut the Angles a bit wider, because i will reinforce the welding sections later. so i be able to bend it in the Vice to my destination angle i need. Short verification after bending. doesn‘t look too bad. when i lay it on the floor in correct dimensions, i check, if my Plan will work. It seems i can go further forward with my Project.. 7 10 Share this post Link to post Share on other sites
OldWorkHorse 3,045 #7355 Posted October 28, 2020 14 minutes ago, ebinmaine said: Should've found some neighborhood kid and paid 'em to fetch it. That is a awesome idea haha I dont know why I didnt think of that ... oh well I'm sure there will be a next time in this old shop! 1 Share this post Link to post Share on other sites
ebinmaine 67,515 #7356 Posted October 28, 2020 Just now, OldWorkHorse said: That is a awesome idea haha I dont know why I didnt think of that ... oh well I'm sure there will be a next time in this old shop! Hang around us for a bit and you'll learn all kinds of neat tricks. 1 Share this post Link to post Share on other sites
Jhook 849 #7357 Posted October 28, 2020 1 hour ago, peter lena said: J HOOK , this is the bearing type ,https://www.vxb.com/3-4-UCFL204-12-2-Bolts-Flanged-Housing-Mounted-p/Kit7334.htm?gclid=Cj0KCQjwreT8BRDTARIsAJLI0KK_Gk0gzeJ-91hB9TG19SBWIq7o_UX-OnUHm0RCJiVyfQWTiYCy-RgaAm3nEALw_wcB , with a tractor like you have , and the opportunity of it being in pieces , you can upgrade as you go along ( if you want to ) during assembly and possibly improve a more secure steering column , just an idea , good luck , pete Great i order that today. Just remove the steering wheel and slide it over the shaft? 1 Share this post Link to post Share on other sites
OldWorkHorse 3,045 #7358 Posted October 28, 2020 2 hours ago, AMC RULES said: Me gusta shinny!! very nice. 2 Share this post Link to post Share on other sites
echris 1,425 #7359 Posted October 28, 2020 (edited) The only thing I did to my WH today was look at it. But at least I got to look at it. Maybe I'll go check the oil again and see if it changed sitting since yesterday. Edited October 28, 2020 by echris 3 1 2 Share this post Link to post Share on other sites
peter lena 8,629 #7360 Posted October 28, 2020 J HOOK , this is the bearing type ,https://www.vxb.com/3-4-UCFL204-12-2-Bolts-Flanged-Housing-Mounted-p/Kit7334.htm?gclid=Cj0KCQjwreT8BRDTARIsAJLI0KK_Gk0gzeJ-91hB9TG19SBWIq7o_UX-OnUHm0RCJiVyfQWTiYCy-RgaAm3nEALw_wcB , with a tractor like you have , and the opportunity of it being in pieces , you can upgrade as you go along ( if you want to ) during assembly and possibly improve a more secure steering column , just an idea , good luck , pete Share this post Link to post Share on other sites
peter lena 8,629 #7361 Posted October 28, 2020 JHOOK, typically steering wheel removal is tough, but if you do that , then you can slide the bearing over the shaft , cleaned and lubricated , for a possible mounting spot , if its a matter of beefing up a mounting spot , you measure your spot and make it stronger , for a 2 bolt hold down . this bearing is much stronger than the original set up , yet serves the same function. as you recover your dash area , the mounting modification will come into view , with new steel. pete 1 Share this post Link to post Share on other sites
WHX?? 48,816 #7362 Posted October 28, 2020 You sure have been haulin the mail on projects lately Madge.... you tell W P to stick it in their ear or just burning the midnight oil? In the lower 50's here today so I said to heck with it & closed the shop & played hookie. Cleaned up the plow mules and their implements of carnage and greased them up for their winter home. Cleaned up four more, pulled batteries and stuffed them in the horse hauler winter home. See ya in spring girls. Blew out the pressure washer and then the sprinkler system/water supply to the warehouse... I hate winter! 7 1 1 Share this post Link to post Share on other sites
Achto 27,577 #7363 Posted October 29, 2020 I was able to play with my new grader blade after work today. A friend of mine had some gravel delivered & I offered to smooth it out for him. The challenge. My C141 with a grader blade in action. After several side passes to knock the piles down things are getting close. The finished product. Playing with my grader blade was sooo much fun. I can't wait to find more material to push around with it. 7 7 Share this post Link to post Share on other sites
Lee1977 6,662 #7365 Posted October 29, 2020 I put the new receiver hitch I built on the 520. Still have to add the bracing down to the hitch. Also installed the Gator blades on the C-120/180 and the vacuum attachment to receiver hitch on it. 10 1 Share this post Link to post Share on other sites
ohiofarmer 3,276 #7366 Posted October 29, 2020 (edited) I finally got the torn up seat framing fixed up strong on the c-145. Now that i have patterns made, i will cut reinforcing pieces for all my later model tractors. To see more , go to "Repairing a seat mount frame" under Wheel horse tractors for more details Edited October 29, 2020 by ohiofarmer 6 3 Share this post Link to post Share on other sites
ohiofarmer 3,276 #7367 Posted October 29, 2020 Another project of many on the c-145/c-141 recent purchases were the Goodyear ags. They were just horrible with ground in dirt and scarring. A combination of wintergreen oil and Marvel gets them pretty close. Wintergreen oil is used for go kart tires to keep them soft for the track. 5 1 Share this post Link to post Share on other sites
Lane Ranger 10,968 #7368 Posted October 29, 2020 11 hours ago, Achto said: I was able to play with my new grader blade after work today. A friend of mine had some gravel delivered & I offered to smooth it out for him. The challenge. My C141 with a grader blade in action. After several side passes to knock the piles down things are getting close. The finished product. Playing with my grader blade was sooo much fun. I can't wait to find more material to push around with it. Those grader blades are a lot of fun to work with and do a great job Dan! Yes you did a great job with that attachment- one of the best Wheel Horse made. 2 1 1 Share this post Link to post Share on other sites
TonyToro 1,049 #7369 Posted October 29, 2020 12 hours ago, Achto said: I was able to play with my new grader blade after work today. A friend of mine had some gravel delivered & I offered to smooth it out for him. The challenge. My C141 with a grader blade in action. After several side passes to knock the piles down things are getting close. The finished product. Playing with my grader blade was sooo much fun. I can't wait to find more material to push around with it. Is that some sort of motivation sitting on the A/C unit? nice work!! 1 7 Share this post Link to post Share on other sites
WHX?? 48,816 #7370 Posted October 29, 2020 Knowing Dan....yep! Agree with with Lane ... best attachment offered! 1 1 Share this post Link to post Share on other sites
Robert K 37 #7371 Posted October 29, 2020 Couple weeks ago I made my own tillering handle for the blade angle and added the linear actuator to raise and lower the blade. Actuator is only a 4" throw. Could use a 6". Its set up to go down 3/4" below grade. Needs to go higher though. That's where the 6" actuator will come in. lever was a pain. I didn't have anything to go off of other than pictures. So it looks quite wonky LOL. . With it all said and done it works really good. 7 5 Share this post Link to post Share on other sites
oliver2-44 9,756 #7372 Posted October 29, 2020 40 minutes ago, Robert K said: Couple weeks ago I made my own tillering handle for the blade angle and added the linear actuator to raise and lower the blade. Actuator is only a 4" throw. Could use a 6". Its set up to go down 3/4" below grade. Needs to go higher though. That's where the 6" actuator will come in. lever was a pain. I didn't have anything to go off of other than pictures. So it looks quite wonky LOL. . With it all said and done it works really good. Nice lift setup. @Robert KIs the actuator heavy enough for you to apply down pressure? 2 Share this post Link to post Share on other sites
Achto 27,577 #7373 Posted October 29, 2020 55 minutes ago, TonyToro said: Is that some sort of motivation sitting on the A/C unit? Running a grader blade without hydraulics is thirsty work! 3 5 Share this post Link to post Share on other sites
John37027 2 #7374 Posted October 29, 2020 '87 414-8 model with 42" deck- adjusted trunion bolt for raised deck bumper contact with footpads, leveled deck, installed gator blades, adjusted the PTO and replaced idle pulley/drive belt. Went with a kevlar drive belt. Will swap the deck spindles, and swap the deck and PTO belts over to kevlar this winter. 2 Share this post Link to post Share on other sites
Robert K 37 #7375 Posted October 29, 2020 2 hours ago, oliver2-44 said: Nice lift setup. @Robert KIs the actuator heavy enough for you to apply down pressure? Will lift the front off the ground. 4 Share this post Link to post Share on other sites
