AMC RULES 37,130 #6551 Posted September 12, 2020 @Roger R What is the hole you're filling in there? 1 Share this post Link to post Share on other sites
ebinmaine 67,552 #6552 Posted September 12, 2020 2 hours ago, AMC RULES said: @Roger R What is the hole you're filling in there? Maybe we don't wanna know..... 1 Share this post Link to post Share on other sites
Tuneup 1,433 #6553 Posted September 12, 2020 Put the P216 on the bench and went to pull the flywheel. Was not a problem the last time - guess the PO never torqued it to spec. The usual Briggs method of a light turn on a puller and light hammer taps to "pop!" didn't work. Applied more, and more, and more. No luck. Whipped out the impact wrench and 120 psi. Broke the puller. Flywheel still staring at me. Out for some better bolts and an easy out. I'll win - I always do. No Onan will make a fool of me. Happy weekend! 4 Share this post Link to post Share on other sites
Roger R 448 #6554 Posted September 12, 2020 2 hours ago, ebinmaine said: Maybe we don't wanna know..... Actually it's a low spot in the trail that gets impassable in the spring. It doesn't show up but I have a tile under that dirt, so water will flow through. Sort of an earth bridge. There's more than one on this trail. 2 1 Share this post Link to post Share on other sites
lynnmor 7,307 #6555 Posted September 12, 2020 3 hours ago, Tuneup said: Put the P216 on the bench and went to pull the flywheel. Was not a problem the last time - guess the PO never torqued it to spec. The usual Briggs method of a light turn on a puller and light hammer taps to "pop!" didn't work. Applied more, and more, and more. No luck. Whipped out the impact wrench and 120 psi. Broke the puller. Flywheel still staring at me. Out for some better bolts and an easy out. I'll win - I always do. No Onan will make a fool of me. Happy weekend! Read this thread. You need a 4 bolt puller, it is amazing that you didn't break the flywheel if you used a 2 bolt. What is the purpose of the easy out? Share this post Link to post Share on other sites
Tuneup 1,433 #6556 Posted September 12, 2020 Hi Lynnmor, Didn't need anything that robust in the last pull so went and did what formerly worked. Impact drivers torque and it was an HF puller so... the bolt sheared. I'll make this a winter project. Thanks for the thread. Share this post Link to post Share on other sites
johnnymag3 2,520 #6557 Posted September 12, 2020 9 hours ago, Tuneup said: Put the P216 on the bench and went to pull the flywheel. Was not a problem the last time - guess the PO never torqued it to spec. The usual Briggs method of a light turn on a puller and light hammer taps to "pop!" didn't work. Applied more, and more, and more. No luck. Whipped out the impact wrench and 120 psi. Broke the puller. Flywheel still staring at me. Out for some better bolts and an easy out. I'll win - I always do. No Onan will make a fool of me. Happy weekend! 6 letters will make that all better. KOHLER 1 Share this post Link to post Share on other sites
johnnymag3 2,520 #6558 Posted September 12, 2020 Started to winterize the Horses......time is running short. I did have time to run all of the Horses and put sweet juice in the fuel and the oil. There will be 5 Horses that stay in the underhouse stable, and 2 that will be in a colder climate. The shed is 40 degrees, and the underhouse barn is 65 degrees. Both places have heat, but one is warmer thann the other. I will be posting the B100, one owner Horse, with its 42" Deck in the classified, so if thats a Horse you may want to add, let me know. Its a one owner, all original, unmolested , unpainted gem. I have a Name and a plate for it already..... PATINA,,,,,,, is her name.runs perfect, mows perfect and has been gone through front to back, top to bottom.....fuel....electric.....drivetrain. I did everything. Turnkey example of an original Horse as back in the day. ... Pictures will be there on the Classified arena. I want to mention that in case you may not have figured it out already, im an OCD freak. EVERYTING MUST BE PROPER.... Correct bolts, washers, color, etc....hate to admit it, but the first step is admitting it.... HAPPY SATURDAY GENTLEMAN...I need to find an adult vessel of liquid now.......been at this since 5 AM with the Horses. 1 Share this post Link to post Share on other sites
Tuneup 1,433 #6559 Posted September 12, 2020 Yeah, I've gone through two K301s now. Love working on them. I had to have an Onan, even if it was a 516 that had it. I'll take the winter and will go through it properly. She's been an oil burner since we met. Share this post Link to post Share on other sites
Lagersolut 661 #6560 Posted September 13, 2020 (edited) Going to clean up these connections on the 416-8 and replace the grade 5 with stainless carriage bolts and flange nuts on the hood mounts . Do this to all the tractors I restore/refresh on the hood stand steps etc. Found a seller ( bolt depot ) on the bay I can get the 3/4 and 1" lengths. Like getting the old rusty stuff off shiny new stuff on . Edited September 13, 2020 by Lagersolut 4 Share this post Link to post Share on other sites
Lagersolut 661 #6561 Posted September 13, 2020 While was working on new fasteners on the hood Fed Ex dropped off my new seat 7 1 1 Share this post Link to post Share on other sites
Pullstart 62,905 #6562 Posted September 13, 2020 On 9/11/2020 at 5:58 PM, AMC RULES said: Sitting here now...thinking about an upgrade to NOS... and a new set of the "wide trac's" Nothing wrong with a little extra on the bottom... 7 1 Share this post Link to post Share on other sites
Pullstart 62,905 #6563 Posted September 13, 2020 On 9/12/2020 at 4:20 PM, johnnymag3 said: Started to winterize the Horses......time is running short. I did have time to run all of the Horses and put sweet juice in the fuel and the oil. There will be 5 Horses that stay in the underhouse stable, and 2 that will be in a colder climate. The shed is 40 degrees, and the underhouse barn is 65 degrees. Both places have heat, but one is warmer thann the other. I will be posting the B100, one owner Horse, with its 42" Deck in the classified, so if thats a Horse you may want to add, let me know. Its a one owner, all original, unmolested , unpainted gem. I have a Name and a plate for it already..... PATINA,,,,,,, is her name.runs perfect, mows perfect and has been gone through front to back, top to bottom.....fuel....electric.....drivetrain. I did everything. Turnkey example of an original Horse as back in the day. ... Pictures will be there on the Classified arena. I want to mention that in case you may not have figured it out already, im an OCD freak. EVERYTING MUST BE PROPER.... Correct bolts, washers, color, etc....hate to admit it, but the first step is admitting it.... HAPPY SATURDAY GENTLEMAN...I need to find an adult vessel of liquid now.......been at this since 5 AM with the Horses. No! Not winterizing time! 4 Share this post Link to post Share on other sites
WHNJ701 4,165 #6564 Posted September 13, 2020 5 minutes ago, pullstart said: No! Not winterizing time! I love this fall time of year, I am just getting started! 1 Share this post Link to post Share on other sites
JCM 9,172 #6565 Posted September 14, 2020 Time for the 420-LSE to be put to work. Hauling some freshly split wood to the log rack in the living room, nights are getting cool and I like that. 4 4 4 Share this post Link to post Share on other sites
ohiofarmer 3,276 #6566 Posted September 14, 2020 Got the new 121 to start and run. It does OK if you shoot some carb spray to get it started, so I decided to go with fuel issues first. It came equipped with an electric fuel pump, so the first test was to see if it would pump through the manual fuel pump. Check. then I tested the needle and seat . check. Then I pulled the emulsifier tube main jet and idle jet ant they wee oK. Finally i found some yellow gas residue in the bowl and some other dirt . if that was still thee after an hour of mowing, i am pretty sure that the bowl had some water in the bottom. So there we are ,starts and runs every time now. I only had this tractor for a week, and two more showed up. Two black hood 14HP automatics. One extra set ag tires in good shape. Front mount blade and chains. All for $200. Seems like he was tired with dealing with ppl trying to lower the price and he just wanted them gone. They were previously advertised for $500 which till was not bad. i do not really feel bad, because i gave him what he asked. He said to save his phone number as he might want to buy one back once it runs... I gotta stop looking at marketplace 11 is enough.. 3 5 1 Share this post Link to post Share on other sites
Tractorhead 9,064 #6567 Posted September 14, 2020 2 hours ago, ohiofarmer said: I gotta stop looking at marketplace 11 is enough.. Ya know, that would be the biggest challenge... 1 Share this post Link to post Share on other sites
ebinmaine 67,552 #6568 Posted September 14, 2020 7 hours ago, JCM said: Time for the 420-LSE to be put to work Well done sir. 1 Share this post Link to post Share on other sites
Pullstart 62,905 #6569 Posted September 14, 2020 Used mighty 6 horsepower Jane to resurface the temporary driveway after this weekend’s wedding. It rained all night but the tent worked out fine and all was well! The flaming arrow stunt did not work out so great, our pre-practice arrows stayed lit but the wedding night arrows did not. I am right handed, but shoot long guns and bow lefty. 5 4 Share this post Link to post Share on other sites
953 nut 55,280 #6570 Posted September 14, 2020 9 hours ago, ohiofarmer said: It came equipped with an electric fuel pump, so the first test was to see if it would pump through the manual fuel pump. You should bypass the mechanical fuel pump. If the diaphragm in the mechanical pump develops a hole you will be pumping gas into the crankcase of your engine. 2 Share this post Link to post Share on other sites
Greentored 3,214 #6571 Posted September 14, 2020 It was a weekend of Wheel Horse! "lawn duty" got decarbon'd, a valve adjustment, a new muffler, cut the lawn and food plot for fall planting, Hoss got a secondary idler for more belt wrap (it dont slip now!), yanked the plow around the garden, and both got put on a 93 octane diet from here on out. 6 Share this post Link to post Share on other sites
Pullstart 62,905 #6572 Posted September 14, 2020 Scott, does the belt stop without the guard? I assume you’ve got fingers in place for friction? Share this post Link to post Share on other sites
Greentored 3,214 #6573 Posted September 14, 2020 1 hour ago, pullstart said: Used mighty 6 horsepower Jane to resurface the temporary driveway after this weekend’s wedding. It rained all night but the tent worked out fine and all was well! The flaming arrow stunt did not work out so great, our pre-practice arrows stayed lit but the wedding night arrows did not. I am right handed, but shoot long guns and bow lefty. Hey hey, another bow hunter! Funny- Im a lefty, shoot a gun left handed, but shoot a bow right handed 2 1 Share this post Link to post Share on other sites
Pullstart 62,905 #6574 Posted September 14, 2020 Just now, Greentored said: Hey hey, another bow hunter! Funny- Im a lefty, shoot a gun left handed, but shoot a bow right handed This Bow-Tech my buddy found against a stump in his back yard near state land. We guess a hunter was trees pa and nearly got caught. I messed with the sight to adjust for the jeans on the end of the aluminum arrows, but came to liking it over my Bear! It has the best of many features and ironically the same pin shot about 20 yards with or without the jeans tied on 1 Share this post Link to post Share on other sites
ohiofarmer 3,276 #6575 Posted September 14, 2020 1 hour ago, 953 nut said: You should bypass the mechanical fuel pump. If the diaphragm in the mechanical pump develops a hole you will be pumping gas into the crankcase of your engine. I will do that. Perfect place for a fuel filter, i think 1 Share this post Link to post Share on other sites
