McGrew 460 #3451 Posted November 6, 2019 Achto, Sure thing! I’m pretty someone on this website posted a pic of a similar, if not identical voltmeter on their tractor, but the link to the one I bought is here: https://www.ebay.com/itm/US-Ship-DC-12V-LED-Panel-Digital-Voltage-Meter-Display-Voltmeter-Car-Motorcycle/122085414438?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 I was wrong about the price... It was $7.99... I’ve mentioned before, I’m cheap! The cotter pin through the throttle knob was a necessity... Before I modified the linkage, the throttle was so hard to pull the knob started spinning on the shaft when I tried to lock it. The cotter pi solved that. At least for now. Will have to see how long it lasts! Thanks! Danny 1 2 Share this post Link to post Share on other sites
Tractorhead 9,064 #3452 Posted November 6, 2019 (edited) have the same Voltmeter installed. allway‘s a good feeling, to see the Voltage is in proper range found mine at *bay, price one piece about 8€, 10 pieces each 2€. so i simply ordered 10 pieces, to have spare for some other purposes. Edited November 6, 2019 by Tractorhead 4 1 Share this post Link to post Share on other sites
JoeliusZ28 77 #3453 Posted November 6, 2019 (edited) This fall i installed tri-rib front tires to make steering easier with the snowblower (cant believe how much easier it steers now), and also did a trans flush. Then i used it to turn the garden over. Looking for a tiller attachment before next spring, the furrow plow just doesn’t break everything up no matter how many passes you make. Edited November 6, 2019 by JoeliusZ28 3 7 Share this post Link to post Share on other sites
Herder 2,354 #3454 Posted November 6, 2019 17 minutes ago, JoeliusZ28 said: This fall i installed tri-rib front tires to make steering easier with the snowblower (cant believe how much easier it steers now), and also did a trans flush. Then i used it to turn the garden over. Looking for a tiller attachment before next spring, the furrow plow just doesn’t break everything up no matter how many passes you make. The tri-ribs look nice. Are they the firestone 16/6.5-8? 1 Share this post Link to post Share on other sites
cleat 5,934 #3455 Posted November 6, 2019 A plow is only designed to turn the soil not break it up. You need either a tiller or a disk harrow to break it up more. 3 Share this post Link to post Share on other sites
953 nut 55,197 #3456 Posted November 7, 2019 23 hours ago, pullstart said: Hot Wheels has the same volt meter, maybe @953 nut knows the source too? $ 4.23 shipped from the orient (China). https://www.ebay.com/itm/Mini-Round-DC-12V-24V-LED-Car-Boat-Digital-Display-Voltmeter-Meter-4Colors/272705984613?var=571839844235 3 Share this post Link to post Share on other sites
Pullstart 62,839 #3457 Posted November 7, 2019 19 hours ago, JoeliusZ28 said: This fall i installed tri-rib front tires to make steering easier with the snowblower (cant believe how much easier it steers now), and also did a trans flush. Then i used it to turn the garden over. Looking for a tiller attachment before next spring, the furrow plow just doesn’t break everything up no matter how many passes you make. That soil looks like it might benefit from just a disc, after you’ve plowed it. Looks great! 1 Share this post Link to post Share on other sites
DevonianHorse 271 #3458 Posted November 9, 2019 Earlier in the year, the Horse was not happy and then eventually stopped running completely, it had a replacement ignition switch (the old one had loose terminals) and a carb service and it is good as new Just did some odd jobs around the garden, can't say how good it is to have the Horse up and running again It has quite an easy life but beats pushing a wheelbarrow around all day 2 6 Share this post Link to post Share on other sites
rjg854 11,361 #3459 Posted November 9, 2019 Had a slow leak on a rear tire that's been a real PITA. Broke the tire down cleaned up the bead on the rim and made sure the tire was nice and clean. I think I may have got a good seal on it now. It's an original tire , but it's still in pretty decent shape. 4 2 Share this post Link to post Share on other sites
DBlackston 298 #3460 Posted November 10, 2019 Put the head back on the K181 on the 854. Finished putting the HY-3 pump back together and got it and the cylinder mounted. Test fit the hood stand fittings for my HY-3 rockshaft build. 6 4 Share this post Link to post Share on other sites
Bear G 690 #3461 Posted November 10, 2019 Stretch Modifications I removed the old bumper (1st pic) and installed new brush guard. Also moved the air tank to where the battery used to be. Added air pressure gauge. Installed another set of horns on the right side to better match left side. New aluminum wheels & tires. Hope Karl Storhy will approve. 4 6 2 Share this post Link to post Share on other sites
Super-C 4 me 612 #3462 Posted November 10, 2019 Getting ready for winter had make a make shift shed for 6 tractors. Also got the Xi ready, new aluminum bumper, aluminum grill, and got the plow mounted 12 1 Share this post Link to post Share on other sites
Pullstart 62,839 #3463 Posted November 10, 2019 @Bear G good to see you on here! I bet @Shynon ... can’t wait to hear the (horn) changes comin’ comin’ ‘round the horse stalls, he ain’t heard the horns since last July in Portage WI that was a poor rendition of a good country song I know! I bet Stretch sounds as good blowing steam as it does revving up! 1 6 Share this post Link to post Share on other sites
Shynon 7,459 #3464 Posted November 10, 2019 37 minutes ago, pullstart said: can’t wait to hear the (horn) changes comin’ sure can, not even counting the days 4 Share this post Link to post Share on other sites
Bear G 690 #3465 Posted November 11, 2019 1 hour ago, Shynon said: sure can, not even counting the days Betting I know where you prefer I mount the new horns. I’d be able to blow them if I ate enough beans. 6 Share this post Link to post Share on other sites
pfrederi 17,734 #3466 Posted November 11, 2019 Something that doesn't happen much around here...shipping out a WH. Loaded up a Charger 12 that I have fixed up for my older brother to use. He has a Ford 8N for the driveway but up around the house and paths for the dog he was wrestling with an old walk behind blower. This will be easier for him. In addition to the wheel weights I have 70 lbs of weights to go on the 2" receiver hitch. 5 8 Share this post Link to post Share on other sites
WHX?? 48,815 #3467 Posted November 11, 2019 Gotta like the loading ramp Paul! 7 Share this post Link to post Share on other sites
pfrederi 17,734 #3468 Posted November 11, 2019 Woke up the snow horses and got them out of the storage shed and up to the shop. I swear they put a poison pill in the batteries these days so they crater right after their 3rd Birthday. 5 12 Share this post Link to post Share on other sites
Tractorhead 9,064 #3469 Posted November 11, 2019 I still guess, there was no poison at all in the game, the horses are simply offended... that‘s the revenge of them, they simply empty the batteries to annoy you. 😂 2 Share this post Link to post Share on other sites
Sparky-(Admin) 21,315 #3470 Posted November 14, 2019 Winter prep oil change (10w/30) 8 2 Share this post Link to post Share on other sites
Andy N. 2,147 #3471 Posted November 15, 2019 (edited) Got the herd officially ready for winter. Plus for anyone that wants to see the difference between LED and original Halogen headlights. Edited November 15, 2019 by Andy N. 7 1 1 Share this post Link to post Share on other sites
12Horse Paladin 1,038 #3472 Posted November 16, 2019 On 11/14/2019 at 3:24 PM, Sparky said: Winter prep oil change (10w/30) WORK HORSE! I sure hope to find one of those, someday, just because!!!😊❤ 👍👍 4 1 1 Share this post Link to post Share on other sites
DBlackston 298 #3473 Posted November 16, 2019 Took the wife for a ride while the weather was nice. First time Ive gotten to ride a wheel horse around. I have 3 but this is the first one to run and move under its own power. So excited to use it in the garden! 3 7 4 Share this post Link to post Share on other sites
ebinmaine 67,452 #3474 Posted November 17, 2019 51 minutes ago, DBlackston said: the wife When does she get her own? Share this post Link to post Share on other sites
WHX?? 48,815 #3475 Posted November 17, 2019 (edited) Ain't nothin like nice tub ride to get them in the mood @DBlackston You know we all got a problem when we all sport lumber when @Sparky changes his oil! on those lights & horses @Andy N. I ain't gonna start a thread just for this so I'll use this catch all thread for this but the Missus had this made at a Walgreens the other day. Dan @Achto took this at a recent show and our favorite....... Dan Actually did work on a horse today ...since @WVHillbilly520H wasn't gonna come finnish this for me and someone said it's winter coming on figured might as well pick up where I procrastinated last winter... mod to a deuce. Thank you also @Kurt-NEPA The bolts are loose since the parts are a tacky red yet .... yah .....I love watching paint dry! Edited November 17, 2019 by WHX24 6 7 Share this post Link to post Share on other sites
