DBlackston 298 #3401 Posted October 27, 2019 On 10/5/2019 at 8:16 PM, DBlackston said: Doesn't look like much yet but I went and bought material for the HY-2 Rock Shaft I need to build. Picked up the material for a set of dual wheel adapters at the same time!! Getting closer on th HY-3. Made some hood stand fittings today and got alot of the other material cut to size. 5 Share this post Link to post Share on other sites
76c12091520h 3,620 #3402 Posted October 27, 2019 Put a freshly redone hood on my C120. Something fell on it about 10 yrs ago and I finally redid one of my spare hoods so I could just swap it out. Cleaned and detailed the headlight assembly, added a new headlight lens , LED bulbs , fresh wire clips , new decals (thanks Terry). First time in 23 yrs that it's had the right decals on it , maybe now I can relax...….. 6 12 Share this post Link to post Share on other sites
WHX?? 48,821 #3403 Posted October 27, 2019 Wow that is one sharp tractor 76c ....... not sure about the trailer wiring clips tho. I have this thing about sliding sharp objects on fresh paint. I use the stick on kind. 3 Share this post Link to post Share on other sites
R Scheer 502 #3404 Posted October 27, 2019 That's a really good looking tractor! Share this post Link to post Share on other sites
The Tuul Crib 7,336 #3405 Posted October 27, 2019 Cleaned up the front yard just before dark ! Dang l hate dark ! I need more light dang! Need more light! 1 7 Share this post Link to post Share on other sites
adsm08 2,064 #3406 Posted October 27, 2019 9 minutes ago, The Tool Crib said: Cleaned up the front yard just before dark ! Dang l hate dark ! I need more light dang! Need more light! http://www.myhellalights.com/ 1 1 Share this post Link to post Share on other sites
WHX?? 48,821 #3407 Posted October 28, 2019 (edited) Worked on this new to me C-145 abit this weekend. Gave her a bath & the usual fluids & filters. PO had all the safety switches removed & bypassed and even had the audacity to put one in place of the key switch for a start button! Luckily the original key switch plug was not hacked up so a new $10 Indak and all was good again. Traced down a intermittent charge issue to the stator plug which was corroded. Got the connectors looking almost brand new but still gets warm when running. Going to ditch the ammeter for a voltage guage and add an hour meter. Swapped out the busted up fender pan for one off a parts 520 & new seat. Real happy with how the motor runs tho. Very strong and no smoke but can't figure why only a 36 in deck on it. This tractor is going to go to the cabin for mowing duty to replace a pos Murray. Need to add a hitch yet but baffles me how someone did this! Edited October 28, 2019 by WHX24 6 4 Share this post Link to post Share on other sites
The Tuul Crib 7,336 #3408 Posted October 28, 2019 8 hours ago, WHX24 said: Worked on this new to me C-145 abit this weekend. Gave her a bath & the usual fluids & filters. PO had all the safety switches removed & bypassed and even had the audacity to put one in place of the key switch for a start button! Luckily the original key switch plug was not hacked up so a new $10 Indak and all was good again. Traced down a intermittent charge issue to the stator plug which was corroded. Got the connectors looking almost brand new but still gets warm when running. Going to ditch the ammeter for a voltage guage and add an hour meter. Swapped out the busted up fender pan for one off a parts 520 & new seat. Real happy with how the motor runs tho. Very strong and no smoke but can't figure why only a 36 in deck on it. This tractor is going to go to the cabin for mowing duty to replace a pos Murray. Need to add a hitch yet but baffles me how someone did this! Looks like possibly a weld job? Or replace that half of the trans shell. Other than that great lookin machine ! 1 1 Share this post Link to post Share on other sites
953 nut 55,260 #3409 Posted October 28, 2019 52 minutes ago, The Tool Crib said: Need to add a hitch yet but baffles me how someone did this Looks like they sawed the pin half way through and finished it off with a BFH tool. Sad! You could weld up a 2" hitch receiver that attaches to your axle, or buy one from Lowell. 1 Share this post Link to post Share on other sites
Pullstart 62,902 #3410 Posted October 28, 2019 Hardly looks like the same tractor with a fender and seat swap! Do you think your standard drawbar hitch would still work with whatever mayhem was unleashed onto the trans? I noticed when we were unloading, the deck looks like it’s not in the mid mount quite right, I think the little saddles aren’t vertical like they should be. I’m glad you’re happy with the way it runs. You’ve got all kinds of power for that 36” deck! With all the wiring hacks fixed up, do the lights work now? Share this post Link to post Share on other sites
LengerichKA88 1,883 #3411 Posted October 28, 2019 I haven’t been on much lately in the last couple months. For this that don’t know, I started a new job (after being a stay at home dad fo four years) at the end of August. I am working in a distribution center for a major retailer that sports the same colors as our tractors. Because of that, along with everything else life normally throws at me, I’ve been just too dang exhausted to do much at a time. But, the Charger looks a little different than the last time any of you guys saw it. I hooked up with @pullstart a couple weeks ago and got a fender pan for it to cut up the way I wanted to. I’m slowly but surely cleaning it up. Haven’t decided if I’m going to pull the Techumseh off yet, but I am going to rewire it at the very least. Hope everyone’s doing well, I do miss being around the forum and chatting with you guys, but the babies gotta eat 🤷🏻♂️ 8 1 1 Share this post Link to post Share on other sites
Pullstart 62,902 #3412 Posted October 28, 2019 Looks sweet Kyle! It’ll be awesome to see it all finished up next to your toy tractor! 1 Share this post Link to post Share on other sites
WHX?? 48,821 #3413 Posted October 28, 2019 Looks like somebody hooked on to it Cribs and took off at warp speed. I haven't tried a new pin and draw bar yet Kev but think it will be ok for light duty tub pulling. Yup all lights work even got the rears wired. The seat pan and even seat mount off the 520 bolted right up. 43 minutes ago, pullstart said: I noticed when we were unloading, the deck looks like it’s not in the mid mount quite right, I think the little saddles aren’t vertical like they should be. Haven't tied into the deck yet that's next. Usually the first thing I do on a new to me is pull the deck and inspect but was too eager to get at all the other little stuff. Deck sounds quiet tho 46 minutes ago, pullstart said: I’m glad you’re happy with the way it runs. A carb cleaning and fresh gas starts and runs great! Those solid mounts are the real answer tho! 3 Share this post Link to post Share on other sites
Lee1977 6,662 #3414 Posted October 28, 2019 On 10/27/2019 at 12:54 AM, WHX24 said: Wow that is one sharp tractor 76c ....... not sure about the trailer wiring clips tho. I have this thing about sliding sharp objects on fresh paint. I use the stick on kind. That is the way Wheel Horse did it back then. My 1977 C-120 had them when I bought it new back in 1977. 1 Share this post Link to post Share on other sites
LengerichKA88 1,883 #3415 Posted October 28, 2019 20 minutes ago, pullstart said: Looks sweet Kyle! It’ll be awesome to see it all finished up next to your toy tractor! Probably be spring, (fingers crossed) but it’ll get there! 1 Share this post Link to post Share on other sites
Tractorhead 9,064 #3416 Posted October 28, 2019 Curious how it will look then. 👍 Share this post Link to post Share on other sites
Blackhood Bill 721 #3417 Posted October 28, 2019 Well today got the 145 ready for the white stuff. Put on snowblower, put on cab, added a cargo carrier with 300 lbs. of solar salt for weight. Put caps over the shortened bolts. Check all fluids. Went over the blower with usuall begining of season maintenance. 7 2 Share this post Link to post Share on other sites
Shynon 7,459 #3418 Posted October 28, 2019 Put the 701 down for a long winter nap. In the new to me wagon. 1 8 2 Share this post Link to post Share on other sites
ZXT 2,401 #3419 Posted October 28, 2019 9 hours ago, Lee1977 said: That is the way Wheel Horse did it back then. My 1977 C-120 had them when I bought it new back in 1977. Yep, at least one of my C series still has them - possibly both. Didn't they have some sort of rubber covering on them though? Share this post Link to post Share on other sites
tom2p 2,394 #3420 Posted October 28, 2019 On 10/27/2019 at 6:52 PM, The Tool Crib said: Cleaned up the front yard just before dark ! Dang l hate dark ! I need more light dang! Need more light! sweet looking place ! 1 Share this post Link to post Share on other sites
WHX?? 48,821 #3421 Posted October 29, 2019 You were right Kev... deck is not on right, didn't do much about it yet tho. Feeling too crappy from a nasty cold I caught from Cindy. Only reason I want a four wheel cart Tom, lord knows I got more tubs than Carter's got pills, you can stick a small frame in them for easy storage! Put a small slit in that weight Bill @Blackhood Bill and you and move snow and salt ice at the same time! 3 Share this post Link to post Share on other sites
TonyToro 1,049 #3422 Posted October 29, 2019 23 hours ago, WHX24 said: Worked on this new to me C-145 abit this weekend. Gave her a bath & the usual fluids & filters. PO had all the safety switches removed & bypassed and even had the audacity to put one in place of the key switch for a start button! Luckily the original key switch plug was not hacked up so a new $10 Indak and all was good again. Traced down a intermittent charge issue to the stator plug which was corroded. Got the connectors looking almost brand new but still gets warm when running. Going to ditch the ammeter for a voltage guage and add an hour meter. Swapped out the busted up fender pan for one off a parts 520 & new seat. Real happy with how the motor runs tho. Very strong and no smoke but can't figure why only a 36 in deck on it. This tractor is going to go to the cabin for mowing duty to replace a pos Murray. Need to add a hitch yet but baffles me how someone did this! I was planning on switching the rear fender on mine also. Great looking tractor! Thats the first hitch area I’ve seen cracked. Must have given the tractor a running start before pulling something! 🤷♂️ 2 1 Share this post Link to post Share on other sites
WHX?? 48,821 #3423 Posted October 29, 2019 Not that I don't like the looks of the orginal fender pans Tony but if they would have been made from sheet steel now that's repairable. Guessing they did'nt figure these tractors would be around this long! The whole corner was gone on this one but if it's any consolation the decal was was in good shape so I cut it out and placed it on the shelf of honor in the shop. 2 1 Share this post Link to post Share on other sites
Blackhood Bill 721 #3424 Posted October 29, 2019 @WHX24 I can only think no slipping going on here 1 1 Share this post Link to post Share on other sites
76c12091520h 3,620 #3425 Posted October 29, 2019 13 hours ago, Lee1977 said: That is the way Wheel Horse did it back then. My 1977 C-120 had them when I bought it new back in 1977. Yep, they are original WH clips.... Share this post Link to post Share on other sites
