Thor27 767 #12401 Posted August 1, 2021 12 hours ago, johnnymag3 said: Trying to figure out it is all possible to convert Terrible column shift idea for the 312-H to any other form of lever...or pedal. The darn handle is under the steering wheel and you have to push the silly thing down to go to reverse !!! Also getting the C-120 ready for sale.....Original EVERYTHING !!!!! except hoses, filters, oils, nice and cool out here today, so time to take care of Regular maintenance on 7 of the Horses !!! I had to laugh, my 312 just sits for that very reason. A pedal makes a big difference. Share this post Link to post Share on other sites
WheelHorse520H 708 #12402 Posted August 1, 2021 12 hours ago, johnnymag3 said: Trying to figure out it is all possible to convert Terrible column shift idea for the 312-H to any other form of lever...or pedal. The darn handle is under the steering wheel and you have to push the silly thing down to go to reverse !!! Also getting the C-120 ready for sale.....Original EVERYTHING !!!!! except hoses, filters, oils, nice and cool out here today, so time to take care of Regular maintenance on 7 of the Horses !!! Isavetractors has a video on how he did that to his Cub Cadet with a front end loader and a backhoe. Video Andrew 1 Share this post Link to post Share on other sites
kpinnc 12,017 #12403 Posted August 1, 2021 Should be pretty simple to swap to the lower mount motion control lever. Or you can remove the cam thing that makes you push down to reverse on the column. 3 Share this post Link to post Share on other sites
kpinnc 12,017 #12404 Posted August 1, 2021 Working on a custom one right now myself. 5 Share this post Link to post Share on other sites
johnnymag3 2,520 #12405 Posted August 1, 2021 6 hours ago, kpinnc said: Should be pretty simple to swap to the lower mount motion control lever. Or you can remove the cam thing that makes you push down to reverse on the column. How hard to remove the Reverse stop Cam? Share this post Link to post Share on other sites
lynnmor 7,305 #12406 Posted August 1, 2021 3 hours ago, johnnymag3 said: How hard to remove the Reverse stop Cam? Take off the vertical console plate by removing 4 screws. The cam is held in place with 2 bolts. The problem is that the neutral start switch is mounted on it. My suggestion is to put some lubricant on the cam and pin so it slides easily. I remove the console plates annually, then clean everything followed by lubricating all moving joints. I have used the steering column motion control lever for thousands of hours and don't understand the fuss. 2 1 1 Share this post Link to post Share on other sites
Horse Newbie 7,069 #12407 Posted August 1, 2021 44 minutes ago, lynnmor said: I have used the steering column motion control lever for thousands of hours and don't understand the fuss. I thought about looking at converting my 1994 520H to foot control motion lever, but for now at least, I am going to leave it as it is(steering column lever). I saw the price of the parts to do it, plus the trouble of converting, and final adjustments, and decided that I can use the tractor as it is... Share this post Link to post Share on other sites
Goldnboy 910 #12408 Posted August 1, 2021 Got the plow I found cleaned up so I can find a plow day 2 3 2 Share this post Link to post Share on other sites
cleat 5,935 #12409 Posted August 1, 2021 2 hours ago, Horse Newbie said: I thought about looking at converting my 1994 520H to foot control motion lever, but for now at least, I am going to leave it as it is(steering column lever). I saw the price of the parts to do it, plus the trouble of converting, and final adjustments, and decided that I can use the tractor as it is... I have converted five 520's and one 312H to Matt's foot control and although there is a cost involved, the outcome is well worth it. Makes doing virtually all tasks with the wheel Horses much more enjoyable and faster. 3 Share this post Link to post Share on other sites
Wheelhorse#1 1,657 #12410 Posted August 1, 2021 On 7/29/2021 at 7:56 AM, 953 nut said: He just couldn't find a fire hydrant! I swear,when I let him out to do his business he looks to see where the horse is sitting…dam dog 😄 3 Share this post Link to post Share on other sites
Andy N. 2,153 #12411 Posted August 1, 2021 Great weather in my outdoor paint booth this weekend to clean up and paint some wheels. They'll be silver when done. Tires are on order. Carlisle Tru Power 23x10.5-8 Ags for the rear, and V61 5 Rib 16x6.5-8 for the front. This will be my set for garden plowing and snow removal on the 520-H or 418-A. 8 Share this post Link to post Share on other sites
cschannuth 3,816 #12412 Posted August 1, 2021 9 hours ago, lynnmor said: I have used the steering column motion control lever for thousands of hours and don't understand the fuss. As far as hydros go I cut my teeth on a 520 so I guess I’m biased. I prefer the manuals l grew up on and that I have now. But, I prefer the 520 column lever to the Charger 12 location. I think it’s just what you get used to. 2 Share this post Link to post Share on other sites
D_Mac 8,612 #12413 Posted August 2, 2021 Decided to cobble the 2 plows I have into one. All I did was swap out the blades. After I finished doing that I had to see how it looked mounted on a tractor. So I rolled out the 500 Special and hooked it up. Amazing how easy it is isn't it? 3 2 Share this post Link to post Share on other sites
AMC RULES 37,130 #12414 Posted August 2, 2021 Got my C-175 plow mule back up, running right today. After sitting the past few months, I couldn't help notice how bad it was running when I wanted to move it the other day. Today I decided to pull and flush the carb and discovered a good amount of sediments growing like mini stalagmites there in the bottom of the bowl. Seems crazy how the additives they put in fuel these days actually put down roots and attach themselves to the bowl, leaving the aluminum all pitted up in the process. 3 1 4 Share this post Link to post Share on other sites
ebinmaine 67,464 #12415 Posted August 2, 2021 18 minutes ago, AMC RULES said: aluminum That's my greatest concern with the nasty "E-word" gas. The newer rubber compounds have become more resistant. 2 Share this post Link to post Share on other sites
TonyToro 1,049 #12416 Posted August 2, 2021 Me and my pulling tractor driver went through the fleet today. We finished the last tractor with a go through and shine up. 6 3 Share this post Link to post Share on other sites
ebinmaine 67,464 #12417 Posted August 3, 2021 BBT and her Mama split some more firewood. I used Cinnamon Horse C160 to haul out (2) 17 cu ft loads for future stacking. 2 Share this post Link to post Share on other sites
D_Mac 8,612 #12418 Posted August 3, 2021 3 minutes ago, ebinmaine said: BBT and her Mama split some more firewood. I used Cinnamon Horse C160 to haul out (2) 17 cu ft loads for future stacking. It didn't happen if there isn't any photos. Share this post Link to post Share on other sites
ebinmaine 67,464 #12419 Posted August 3, 2021 10 minutes ago, D_Mac said: It didn't happen if there isn't any photos. 🐻 🚜 Best I can do..... 4 Share this post Link to post Share on other sites
ebinmaine 67,464 #12420 Posted August 3, 2021 Oh here's a pile.. 1 Share this post Link to post Share on other sites
SylvanLakeWH 25,553 #12421 Posted August 3, 2021 15 minutes ago, ebinmaine said: Oh here's a pile.. Next time you gonna need to hold up a local newspaper with the date clearly shown in the photo… now we believe the ladies’ cuttin’ splitten’ part… just that hauling guy’s alleged involvement is shall we say under discussion and further debate as to validity and veracity… 5 Share this post Link to post Share on other sites
ebinmaine 67,464 #12422 Posted August 3, 2021 (edited) @SylvanLakeWH Well played Sir. BBT says: I shall commence to creating staged photos of said "hauler" in the future. Edited August 3, 2021 by ebinmaine Added material pertinent to situation 1 1 Share this post Link to post Share on other sites
Lee1977 6,658 #12423 Posted August 3, 2021 10 hours ago, ebinmaine said: @SylvanLakeWH Well played Sir. BBT says: I shall commence to creating staged photos of said "hauler" in the future. We already have the picture,"You just hauled and dumped." 1 Share this post Link to post Share on other sites
rjg854 11,361 #12424 Posted August 3, 2021 It's a dirty job, but someone had to do it 1 Share this post Link to post Share on other sites
ebinmaine 67,464 #12425 Posted August 3, 2021 9 minutes ago, Lee1977 said: We already have the picture,"You just hauled and dumped." 7 minutes ago, rjg854 said: It's a dirty job, but someone had to do it If it makes you guys feel any better I don't have this trailer set up for dumping wood yet so I actually had to hand load completely.. and hand offload it about halfway. Terrible, this manual labor and burning calories. 3 Share this post Link to post Share on other sites
