OldWorkHorse 3,045 #11776 Posted June 6, 2021 @ebinmaine hey thanks again for the helping hand! Once muffler is fixed and paint touched up,, I can add a horse to the completed list and hunt for my next project.... always have to have 2 going at a time! 4 2 Share this post Link to post Share on other sites
OldWorkHorse 3,045 #11777 Posted June 6, 2021 Started with going down to see @ebinmaine Eric, to fix some leaking rear seals and finished off with re painting the B-80s muffler since VHT yellow 1200° header paint don't like doing its job went with the old faithful rustoleum high temp grill paint. See how this holds up! 2 7 Share this post Link to post Share on other sites
Wheel Horse 3D 3,795 #11778 Posted June 6, 2021 2 hours ago, Maxwell-8 said: Like the special shape hole in the bench! You'd think EB has pulled a hub or 2! I'm savin that little trick! 3 Share this post Link to post Share on other sites
8ntruck 7,011 #11779 Posted June 6, 2021 I sharpened the blades on my 42" SD deck today. Scraped the grass out and shot some grease in the spindles while it was off of the tractor, too. Last time I mowed, I was unimpressed with the quality of the cut. Sharp blades made a world of difference! They still had a little trouble with the tall, thick grass over the drain field. Almost seemed like I was loosing blade speed under the heavier load. The blades are the double D style, 13 1/2 inches long. They don't seem to overlap when the center and side blades are parallel when width wise in the deck. That does not seem right? The cutting edges of these blades have been sharpened back close to 1/4 inch. I need to start shopping for a new set. 2 Share this post Link to post Share on other sites
ebinmaine 67,544 #11780 Posted June 6, 2021 2 hours ago, Wheel Horse 3D said: You'd think EB has pulled a hub or 2! I'm savin that little trick! Normally I pull the hubs using the puller while the transmission is laying on the ground flat. Certainly can be done while they are on the tractor as well. Given that scenario I will often use a jack stand as a stabilizer. Certainly was a heck of a lot easier with @OldWorkHorse Steve helping to use his ballast and muscle combined with my own. 2 1 1 Share this post Link to post Share on other sites
Wheel Horse 3D 3,795 #11781 Posted June 7, 2021 1 hour ago, ebinmaine said: Normally I pull the hubs using the puller while the transmission is laying on the ground flat. This old Army back likes stuff up off the floor! Lol 3 Share this post Link to post Share on other sites
Snoopy11 5,714 #11782 Posted June 7, 2021 I bought a billet rod for my Duromax engine from ARC Racing (Amundsen Research Corporation), should arrive by Wednesday. This engine should pull over 40 hp... when I finish it... I also bought 2 axle oil seals tagged 1232 for my L-157... as the ones I used originally are very poor quality (I bought them off of fleabay... so I didn't expect very much... and didn't GET very much...). I personally bought these here from vendor Wheel Horse Parts and More: https://wheelhorsepartsandmore.com/product/1323-1263-100863-oil-seal/ Please comment on these seals if you have used them before and if they work good on the L-157!!! At this time, I am just working on axle seals... I might buy a better seal for the input shaft later... (it isn't leaking now... but I don't really trust fleabay parts anymore so...). Thanks guys! Don 2 Share this post Link to post Share on other sites
johnnymag3 2,520 #11783 Posted June 7, 2021 Going to install an Auxiliary Tank and Frame on one of my Horses... Guy has an Original setup from Wheel Horse, needs soap and water, but complete, and all there. What do you think I should pay for said item ? Thanks, John 1 Share this post Link to post Share on other sites
ebinmaine 67,544 #11784 Posted June 7, 2021 24 minutes ago, johnnymag3 said: Auxiliary Tank Got any pics? 1 Share this post Link to post Share on other sites
Lee1977 6,663 #11785 Posted June 7, 2021 19 hours ago, OldWorkHorse said: @ebinmaine hey thanks again for the helping hand! Once muffler is fixed and paint touched up,, I can add a horse to the completed list and hunt for my next project.... always have to have 2 going at a time! What did you use to get Eric moving? Cattle Prod, food hanging of a stick just out of reach. Not being there nothing we have tried can get the old boy moving. 3 Share this post Link to post Share on other sites
johnnymag3 2,520 #11786 Posted June 7, 2021 1 hour ago, ebinmaine said: Got any pics? I only have the picture he posted in the CL Hudson Valley. I can try to get a picture of a picture later and post...Its complete. and tank is perfect also...Just very dusty. 3 Share this post Link to post Share on other sites
ebinmaine 67,544 #11787 Posted June 7, 2021 4 minutes ago, Lee1977 said: What did you use to get Eric moving? Cattle Prod, food hanging of a stick just out of reach. Not being there nothing we have tried can get the old boy moving. It was the food... 3 Share this post Link to post Share on other sites
OldWorkHorse 3,045 #11788 Posted June 7, 2021 1 hour ago, Lee1977 said: What did you use to get Eric moving? Cattle Prod, food hanging of a stick just out of reach. Not being there nothing we have tried can get the old boy moving. A swift kick in the rear seems to do the job! 3 Share this post Link to post Share on other sites
Orbie 11 #11789 Posted June 7, 2021 Change all oils in my 72 commando to day all oil was clear no water in the transmission 2 2 Share this post Link to post Share on other sites
Tractorhead 9,064 #11790 Posted June 7, 2021 (edited) I ordered last Week a Toy especially and primary for my beloved Wheelhorse. Because we had few sunny hours i mow the Area. To check if the new High load belt works better, i decided to mow in highes Gear with 2/3 throttle and leave a few small islands for the Bee’s al mostly. after the Mowing Session, the Horse looks like this. but with it‘s new Toy it looks like that a great Tool. What the Tool was? I have no Water on the Shed, so i look for something to cleanup the Horse after Mowing with less than 20 Litres of Water. Ok, 10 Litres in a Bucket and scrub it off can also do the Trick, but you get Wet after that and it takes lot of Time. So i ordered for a Makita Accu a wearable pressure washer. Boy, that thing is that Cool. with only 7 Litres of clean Water out of 2 canisters, the horse appears to be like new painted. 60$ is a real fair Price for that Tool. My horse and i love it.👍❤️ Edited June 7, 2021 by Tractorhead 2 9 Share this post Link to post Share on other sites
Ifixoldjunk 778 #11791 Posted June 7, 2021 22 hours ago, ebinmaine said: Had our friend @OldWorkHorse Steve around today so I could give him a hand changing the rear wheel seals on his Ariel's Flowah Powah tractor. He'd been pouring the Liquid Wrench spray to it for a couple weeks or more and the seals were pretty much not there so plenty of lube was getting in the hub. I was pleasantly surprised to have both hubs fly right off using my "spare hub as a puller" method I picked up from around here somewhere. Even better... He also gave me a hand pulling both hubs from a spare 8 speed that may end up in the C-160 Tecumseh engine tractor or as needed for whatever horse. Also from the 3 speed that I'll be rebuilding for Trina's Military Tribute Tractor. I'd been soaking the 8 speed for at least a year. Trina started spraying the 3 speed hubs a few weeks ago. All four came off!! Certainly took more effort than the ones on Steve's but it was great to see them slide out without serious issue. Here is the 8 speed on the bench, 3 speed on the floor, with the puller next to it. I’m actually surprised how nice a wheel horse looks purple! Nice job. 1 1 Share this post Link to post Share on other sites
ebinmaine 67,544 #11792 Posted June 7, 2021 7 minutes ago, Ifixoldjunk said: I’m actually surprised how nice a wheel horse looks purple! Nice job. @OldWorkHorse 's significant other is responsible for the color choices. 1 1 Share this post Link to post Share on other sites
Snoopy11 5,714 #11793 Posted June 7, 2021 Hey guys! Just wanted to update anyone interested on the 40 HP Duromax build. I just bought a belt for the engine. Installing is going to be fun, as you guys can imagine... and I have quite a bit of work ahead of me to even get this thing close to running on the tractor... BUT I think I have all the parts I need now! I have a long road ahead of me with this 40 hp engine. I have to completely tear it down, and rebuild. So... here is the game plan. Stainless steel push-rods, but keep the stock cam followers Grinding down exhaust lobe on cam (per ARC Racing's suggestion) [I also did this on my Tillotson stage 4 and it made a mighty difference in performance, but don't ask me the science behind it}. Custom fabricate an air filter adapter using 2-3 inch section of 2.5 inch exhaust pipe welded to the stock air filter metal flange (which I am going to cut and make round so it will look nice). Install a billet rod, hopefully without having to hone the wrist pin section of the rod with my dremel. (The fitment of the wristpin is up for debate whether it needs to be honed, most people saying that it fits just fine without honing). I bought a +.40 rod for this engine because my engine is +.70 in the hole. I haven't decided if I am going to grind down the piston yet... I am going to put a custom header on this engine. I am going to fabricate a top-plate for this engine so that it looks nice (no other purpose for the top plate than to be pretty for my application). I am going to be removing the balance shaft from this engine... as I don't need an extra piece of metal flying around in this engine. (ARC recommends this be done...). Don 8 Share this post Link to post Share on other sites
Ifixoldjunk 778 #11794 Posted June 8, 2021 I just got done giving the old horse a backup light. I figured it needs one for winter so I can see where I’m backing up while plowing 6 2 Share this post Link to post Share on other sites
Ed Kennell 38,189 #11795 Posted June 8, 2021 6 minutes ago, Ifixoldjunk said: so I can see where I’m backing up while plowing Lucky you....having one of those necks that still allows your head to turn to see behind the tractor. I have to rely on mirrors and the crunch when I back into something. 1 11 Share this post Link to post Share on other sites
Wheel Horse 3D 3,795 #11796 Posted June 8, 2021 (edited) Removed front tachmatic "swivel pin? Latch pin? Removed mid mount tachmatic. VERY muggy out tonight! Rollin sweat but relatively cool. I can hear a "drip, drip" from the rain gutters as the moist air condenses on the slightly cooler metal roofing. Heat lightning off in the distance. Edited June 8, 2021 by Wheel Horse 3D 4 Share this post Link to post Share on other sites
ebinmaine 67,544 #11797 Posted June 8, 2021 6 hours ago, Ed Kennell said: rely on mirrors and the crunch when I back into something I've had many people tell me "Just keep backin' up til it sounds expensive". 8 Share this post Link to post Share on other sites
Maxwell-8 4,276 #11798 Posted June 8, 2021 I just thought about this: Parking sensors, we added it to our Suzuki works good. Maybe food for thought. 6 Share this post Link to post Share on other sites
ebinmaine 67,544 #11799 Posted June 8, 2021 2 minutes ago, Maxwell-8 said: I just thought about this: Parking sensors, we added it to our Suzuki works good. Maybe food for thought. IMHO... anybody who's a commercial truck driver and needs to rely on a parking sensor should not be a commercial truck driver... But I have to admit they are pretty darn handy in my retail SUV!! 4 1 1 Share this post Link to post Share on other sites
Gregor 4,846 #11800 Posted June 8, 2021 49 minutes ago, ebinmaine said: IMHO... anybody who Your acronym of "IMHO" reminded me of something. I apologize, as this is a bit off topic, but kind of a fun read. I joined my first tractor forum several years ago. People were using acronyms all the time, assuming everyone else knew exactly what they meant. Being new to garden tractors, and forums, many times I didn't have a clue. A complete dialog was sometimes lost to me, simply because I didn't know the difference between FEL and FIL. There are still a few out there I am not sure of. After being on the forum a while, I was able to pick up on the meaning of most of the acronyms, and things started to make sense. I wrote and published this on the other forum several years ago. Thought I would post it here, just for fun. Keep in mind, it's just a made up story. Acronysim confusionism When I first joined this forum, I have to admit, I had a little trouble deciphering all the acronyms. At times it made for some confusing reading on my part. As time and experience wore on, I was able to get most of them figured out. It may be a service to new members if there was a post explaining some of them. I know it would have helped me. As an example. My FIL ran across an add on CL. He spotted a CUT for sale. He went to look at the CUT, but ended up buying an SCUT instead. He took the SCUT to my BIL's place with the intention of building an FEL, to install on the SCUT. My BIL told him that a GT or even a LT would probably have worked for my SIL's use. They continued with the FEL build anyway. My MIL of course told him he paid too much for the SCUT. My FIL assured her that the PO insisted it was a great machine, Although the PO stated that he had had some trouble with the TDM. He thought it was a bad RIO, but turned out to be the TDM. During the build of the FEL for the SCUT, my SIL ended up buying a CUT. My FIL exasperated, decided they could build an FEL for the CUT also. After a lot of cutting, welding and BFH work, my FIL declared the FEL build was complete. When they went to try it out for the first time, the SCUT would not start. Another problem. My BIL even tried to pull start the SCUT with his ATV to start it. The ATV couldn't quite get the job done so my FIL used his PU. Still would not start. My BIL looked at YT for a possible cure. He found a thread in a GT forum where the OP stated he had the same type of trouble. After a little reading he decided the problem was in the RIO. My FIL sent my MIL on a RT in her SUV to town to get a new RIO for the SCUT so they could test the new FEL. The SCUT was a bit old but the dealer happened to have a NOS RIO on hand. That fixed the problem. After fixing that though it appeared there another problem with the SCUT, the PTO would not always engage. IIRC correctly that was a pretty simple fix, just some lose linkage. When it was all said and done my SIL has an SCUT with a working FEL and PTO. My MIL, FIL, and BIL were happy with the build. To this day though My SIL prefers to use her GT rather than her SCUT. She has a mulching kit on her LT so she uses that quite often also. IMHO I would put a mower deck on the CUT and use it to mow. But that's JMO. Keep in mind this is just a story. None of these things actually happened. No SCUT, CUT, GT, LT or even a PM was harmed by my FIL, MIL, BIL, or SIL during the build of this FEL. I wasn't sure whether to post this in the GT forum, or O/T forum. P.S. IIRC the last of these acronyms I was able to figure out was IIRC. 10 2 Share this post Link to post Share on other sites
