Ed Kennell
What have you done to your Wheel Horse today?
Ed Kennell
3 minutes ago, Gregor said:
They may be OK. But....If they are correct, I think your tractor may be bassackwards. I think, :confusion-confused:anyway. Maybe not.:dunno:
May be for a rear facing passanger seat.
  • Haha 6
OldWorkHorse
Lol don't know things about 30 years older then me and that's how they were installed when I got her. Guess worse come worse I unbolt them and turn them around? I bought it off @ebinmaine that could have somthing to do with it :hide:
Edited by OldWorkHorse
  • Haha 3
Gregor
Doesn't look like that tractor originally had seat springs. Maybe they work better that way. IDK. :dunno:1030355611_Screenshot_2021-04-11Fullpagefaxprint-310pdf.png.e57285bcfa65814c722c06d9d0cb6e52.png
rjg854
You just never know why those PO's do what they do. You'll get more spring out of them by changing them around.
OldWorkHorse
I'll give that a shot next time back in the shop.
OldWorkHorse
Must be the luxury model
Gregor
Did you pay extra for the comfort package? :D
  • Haha 4
Ed Kennell
What are you sayin..the Bear needed more support at the rear end?
  • Haha 7
OldWorkHorse
Bahahaha no! Easy on easy off!
  • Haha 1
squonk
Yup. Springs on backwards!
Gregor
THAT would explain it!  Springs are fine, tractor is backwards. :ROTF:
  • Haha 4
Gregor
Got a little more done on the 876 today. For once in my life, I was correct, unfortunately. My brake/belt tensioner linkage worked fine, until I went to put on the belt guard. Then it didn't work so fine. After a couple more hours of re-work, and a couple trips to the hardware store, I think I got something that will work. May not be "BY THE BOOK" but it works. 20210411_182118.jpg.2ce7bfb83ffaf687835fd5b43bc7e16e.jpg20210411_182130.jpg.15004caad457e307852d763038d0aa4e.jpg20210411_182145.jpg.469a090059fd78bae89cf91c5d6a6cf7.jpg20210411_164736.jpg.46ba20c4fb68faf9da28ba2510d1c48b.jpgI find it odd that the bracket that holds the fan guard in place, only has a bolt in the bottom.
Maybe it's suppose to be this way. IDK
20210411_182955.jpg.bbc4332e1d5ebfccd38fbf26ce4de5e9.jpgI didn't like the way the rubber bumpers were rubbing on the sides of the tractor. It doesn't show up well in the pic, buy I put a strip of self adhesive, clear, decal paper on each side.
The dash, and dash plate are still at the media blaster, so I may be in a holding pattern for now. I got a call from the machine shop on my motor, and I have ordered the rebuild kit.
So far I have not encountered a problem with the plate being welded on the back side of the frame. The 10 gauge I used is .102" thick. (depending on what chart you look at), so if you see an 876 with a wheel base .102" longer than normal, it's mine. :D
  • Like 4
  • Excellent 3
OldWorkHorse
Maybe I'm new to this buy why does this tractor have 2 fuel tanks? Did I miss somthing?
Roger R
22 hours ago, Jeff-C175 said:
I checked that out Roger.  What I found is that they didn't seem to have any that were longer than 2" and I would need 4" .  Maybe I was looking at the wrong thing?
Check under "Alloy Steel Shoulder Screws"  McMaster-Carr
Oldskool
That must be a reserve tank. Nothing worse then running out of gas waaaaay over there somewhere.
  • Haha 2
OldWorkHorse
Was guessing that or a hydraulic tank but never seen thst b4 nifty idea. I just ordered a 2.5 gallon keg tank to cram under the hood. Just have to wait till may 4th to make it work haha. Guess I dnt have to worrie about my tank getting to close to the engine :laughing-rofl:
Horse Newbie
Maybe it's a long way to the mailbox...:lol:
  • Haha 3
OldWorkHorse
It's probly for E85... lol
Gregor
LOL  The 7 HP Kohler is mounted temporarily until I get the K 181 rebuilt. ,
OldWorkHorse
That makes more sense.
OldWorkHorse
ebinmaine
This is true.
They were on that way when I got it.
I don't use any seat springs on any tractors.
Notice Patriot doesn't have then or Cinnamon Horse.
I've seen others mount roundrobin bassackwareds like that in the past.
Seems they're less likely to dump the driver backwards...?
Dunno.
I don't like seat springs.
OldWorkHorse
3 minutes ago, ebinmaine said:
This is true.
Dunno.
I was thinking that backwards things too I fig if imma be bombin though the woods might wanna b pushed forward not backwards she's already a bit tall.
Shynon
Pulled one out of storage today and put awsy snowblower.
  • Like 4
  • Excellent 5
