Ed Kennell
What have you done to your Wheel Horse today?
Gregor
3 minutes ago, Tractorhead said:
I Plowed today but with a bad final.was not able to use the Tiller for now.
It ends up as an - Engine Swap Day
Somehow that doesn't sound good at all.
Tractorhead
The half the Bet is done allready.
Engineswap
Tuneup
Greased the 516. Forced all that old black junk out of there. Poor thing doesn't have a zerk for the front pivot, odd. No hole with missing zerk - no place for it. That PO jerry-rigged the left tie rod joint with a bolt and nut - surprised I didn't see that before. OK for now. Pulled the 42SD off the 125. Greased the arbors. Found that the tension assembly would not move so had to pull and clean that up. Sharpened the blades with a cutting wheel. Mounted it. The 516 just screams - ready for mowing. Starts cleaner now so the rings are sealing. Now, I kicked the fuel filter getting on it and it cracked at the seam so she stalled, sucking air. A little tightly stretched electrical tape got me home - a true red neck repair. I'll have to move a new filter up top...
ohiofarmer
I used the C-160 to move a Chevy Impala. I traded the roller/junker for an Ahrends snowblower that is very lightly used to say the least. more like spotless. . The guy who picked up the car might get a car that starts with a GM 3.8 but that needs some electrical work, so a good trade for us both,
 He was very impressed that the C at idle just squatted in and grunted that car right into position with me walking along the side.We could not get the engine to go because the fuel line was rusted and puking fuel, but she still caught a bit.
   He was remarking about "grandma gear" when I actually had the tractor in high range or fourth gear. Then I showed him first gear and his jaw just dropped.. We did use a Blazer to pull it up the ramps.so i told him to find me anything with a small engine and wheels and i would love to tinker with it He was gonna scrap the snowblower that has 99 percent original paint inside the chute.. un belivable that the dealer waned that machine scrapped until you think about it. They want to sell the new ones that are not built nearly as heavy as this machine which is by comparison a 65 mustang that might hurt sales of the new models. I had it firing in 5 minutes and running with a dirty carb in ten
  • Like 5
haydendavid380
Took a couple minutes to swap the dozer blade out for the plow. Flipped around my lift cable which I had installed backwards, and adjusted the clutch rod back a little. She's buzzing around better than ever.
  • Like 5
  • Excellent 3
Pullstart
Just keep in mind, Kohler idle speed has very little ability for slinging the oil around.  When there’s a load especially, at least 1/2 throttle is required for adequate lubrication.
  • Excellent 2
Pullstart
@Tractorhead I love that broom attachment!
Oldskool
I unloaded my WH "tractor kit" this morning. All the while trying to put aside the parts being used in the next build.
  • Excellent 2
ebinmaine
Niiiiiiiiiiice
Herder
So, you may remember this 310-8, paid $50 for it and was going to part it out.  But Eva seemed to be rather fond of it. IMG_1650.JPG.a7b4c75f8f76a74cb12b727c06390727.JPG
After a little bit of work, it turned out to be a good running unit, so I decided to keep it.  I still wasn't sure how much I like it.  IMG_1662.JPG.49173d55a970a624bfd66d39fb5ee987.JPG
After I changed out the spindles, added 8 inch front wheels and some ag's it started to look more like a WH.  Starting to like it but she needs a job.  Mower (?) not so much.
That's better, now we are on to something.  I've had this 36" tiller sitting around for about five years, it was for a C-series but it lines up just fine.  Eva likes it too.  Just need
to get a rear lift assembly.  I hope to order that this week.
IMG_1682.JPG.571df5296c13db9e96712661920c24ba.JPGIMG_1681.JPG.19442b569499ba1691b0362859858a2a.JPG
On to some other needed items.IMG_1686.JPG.9c43ad9b2de84c5e4caa1acd1eab8660.JPG
Not sure how much they weigh but remember them being quite so heavy!!  IMG_1685.JPG.e8f7b5a67cbf30d0e233e0ad1d023f5f.JPG
Each tire took about 2 gallons.IMG_1688.JPG.f4737e18f7464e6cd78caf322d2b0897.JPG
The rears tires will get filled too, just not today.  The right rear needs to be tubed first.  I finished out the day with a fluid change on the transaxle.
  • Excellent 6
Oldskool
Looks like you have a great tilling rig right there.
Herder
Thank you. it will be a bit overkill for the small garden plot.
WVHillbilly520H
This is what I used last year for the 2 small plots here on our property, a 315-8,  then what I am going to use this year eMax22... So no not over kill.
Edited by WVHillbilly520H
  • Like 5
Oldskool
Sure beats wrestling a walk behind tiller
  • Like 4
Oldskool
I'm still a newb to putting these together but here is another horse being brought back from the dead.
  • Excellent 7
Oldskool
I've been trying on differant shoes. Maybe the 7.00x16 on the back? What's everyone's thoughts. Not sold one the front ones yet.
  • Excellent 3
OldWorkHorse
Can you get thos fenders over these tires? That would look real nice I do believe. :twocents-twocents:
ebinmaine
I'm with @OldWorkHorse if ya can get the fenders over the big tires.
front.... Tri ribs??
Oldskool
I would just have to split them and add a 2in strip
Oldskool
I would love to have the tri ribs but I cant find them tall enough. When I do they are 4 rib. The fronts are now 18x6.50x8
OldWorkHorse
Think thos wheels with them fenders definitely be a cool unique look!
OldWorkHorse
9 minutes ago, ebinmaine said:
Got a super cool (early 60s??) Kohler generator from @Oldskool yesterday.
I'll start a thread about that sometime...
Today I took a sawzall and turned a VERY rugged pallet into a stone boat.
Used the Cinnamon Horse to drag the genny to a better place in the drive until I can wash it up and get it down to the outdoor workshop.
Wow that really works well as a drag mat! Need to get me 1 of these for my driveway!
  • Like 4
ebinmaine
PLENTY of weight there!!
  • Haha 1
