Ed Kennell
What have you done to your Wheel Horse today?
TonyToro
2 hours ago, KrazeyOlDave said:
I bought a new set for my wife’s JD, I had to cut out 2 rows, insane
I wish you were closer, I would have taken your extra chain! Lol
  • Haha 1
Jhook
This morning took a drive to ct and picked up this 1960s vertical mower. Havent found any info or pics of one like it. Came with a complete 1962 briggs model 14 which i will be taking off and selling for a predator. May paint it wheel horse colors as well. Its a west point products model vc-6. Cool little vintage machine thats 100 percent complete.
  • Sad 1
WHNJ701
I wouldn't put a predator on it?? , the briggs 14 is a great engine
Jhook
It is a great engine, just not for this application. Rather than spending time wreching on this one which doesn't even have a starter/recoil, i can spend 99 dollars and 5 mins bolting on a bramd new modern engine and have a working piece of machinery. Its not a collectable machine im not worried about keeping it era correct, and someone else can pay me 100 bucks or so for the complete 14 and finish a restoration with it. Win-win in my book.
Tractorhead
today‘s testrun on the Engine with the changed Charging Coil give me a great Result.
After a Oilservice ( had before 5W30 in it and change it to 10W30) it runns now smoothly and nice nearly without blue Smoke.
A little oilsmell can be sniffed, but far from the ammount before.
but however a hone and new Pistonrings are still on the Plan.
  • Like 7
KrazeyOlDave
Got to use my Pony in a rescue run this morning.
Nothing runs like a Deere 😂😂😂😂
  • Haha 6
sparkie333
14 hours ago, Horse Newbie said:
Anybody ever removed the Wheel Horse emblem on the hood of a 520 H ?...
gonna order some new decals and it will be in the way.
I have never---but there is some 520 H owners with red paint in there veins so I'm sure you will get a answer soon. good luck.
sparkie333
9 hours ago, KrazeyOlDave said:
It’s snowing!!! :greetings-clappingyellow: I’m ready!!:dance:
Nice rigs there. but you can have the snow---sun is out here in Arkansas.
sparkie333
21 hours ago, pullstart said:
Took a stroll on the Senior today...
I never knew that they built that tractor What is the year and numbers on it. Nice rig.
sparkie333
19 hours ago, RandyLittrell said:
Randy
You talk Wheel Horse and Guns you can see how happy Randy gets.-----Me to.
sparkie333
On 1/1/2021 at 10:47 PM, Horse Newbie said:
I looked at the parts diagram for an 1988 518-H and did not see any bulbs or bulb sockets on there.
You do see those gauge  light holders on each gauge on there from the back side of the dash. Have a good day.
sparkie333
On 1/2/2021 at 12:26 PM, Rob R said:
Bout tore my arm off the first time I gave it a yank
I been there done that--makes me laugh now.
sparkie333
1 hour ago, KrazeyOlDave said:
Looks like you got that deer ready  to go.
KrazeyOlDave
Had is the word...all new stuff on order, piece of poop.
Horse Newbie
Thanks...I'm getting ready to tag. @WVHillbilly520H and @lynnmor
Horse Newbie
I do want to put it back on after installing decal.
I am asking for help if any of you have any tips.
Thanks,
Tim
WVHillbilly520H
1 minute ago, Horse Newbie said:
I have not removed the emblems or decals, but I would recommend a cheap heat gun like from HF to help soften the adhesive to aid in removal.https://www.harborfreight.com/1500-watt-dual-temperature-heat-gun-56434.html
Horse Newbie
@WVHillbilly520H   I was at HF yesterday and started to grab a heat gun...I have been using an old hair dryer as a heat gun for heat shrink tube and such...
Do you think a hair dryer would heat it up enough ?...prolly not huh ?
Tractorhead
Better than nothing,
heatgun can cause a melting surface if too long on the same spot.
when it‘s hot enough for a heat shrink tube, it‘s definitely hot enough for your needs.
953 nut
Probably will do the trick and have less likelihood of paint damage.
19richie66
Should work. Heat right behind the logo on the inside of the hood and it should pop off.
  • Excellent 2
Horse Newbie
Thanks for the input. @WVHillbilly520H
The decals...at least the only one I've removed so far (rear seat pan) came off pretty easy by pulling it back on itself at a hard angle, until you get to a tear...then a razor blade gets it started again.
lynnmor
1 hour ago, Horse Newbie said:
I removed the decals with a hair dryer.  Just take your time and try to heat the metal as you go.  The emblem will come loose by carefully prying it up while the hair dryer keeps the back side warm.
RandyLittrell
Thanks,
Tim
I did a lot of this in the body shop, I like to use a sharp flexible putty knife with the sharp part toward the emblem. If not wanting to scratch paint, I put tape around the emblem, spray foaming glass cleaner on the emblem, tape and blade. Then just push it right under and it will the cut the two sided tape right off the emblem. Used this method on 80,000 dollar new suburbans to put blackout emblems on. Then use heat to get the tape off. Highly recomend 3M two sided tape to reinstall.
Randy
  • Like 4
