Ed Kennell
What have you done to your Wheel Horse today?
ohiofarmer
2 hours ago, ebinmaine said:
Like a lot of us I've had more than one instance over the years of near complete befuddlement at the modifications that previous owners have made.
One of my very interesting electrical bird's nests was in a tractor where the PO had replaced the five prong blade type switch with a four prong post type automotive switch and I don't think they ever had it running after that .
Between the switch and the terminals they spent well over twice what they would have for the new correct switch....
Keep us posted on your repairs.
   Thanks, Eric.  New correct switches are not that difficult. at least there is the remnants of the harness plug remaining on the tractor side. I have to trace down the charging circuit wire, but with my new double digit tractor status, there are plenty of references that have factory wiring, and i also have a decent understanding of what needs to be there.  And of course all the advice of you all.
ebinmaine
@AMC RULES
That looks shahp!!!
19richie66
Very shawp 👍
Jhook
Well even though i missed out on the gt14 loader i had great luck and after months of searching for one in my price range i have sealed the deal on a loader tractor. Trying not to get my hopes up too high til its on my flatbed,  but it isnt listed for sale and the guy gave me his word. I spoke to him 3 months ago and he wasnt ready to sell it, well now he is. Im excited. Pics for you guys once i own the machine! Also the 1962 predator tractor is selling tomorrow. Good week for me👍
  • Excellent 4
ebinmaine
Good luck!!!
Keep us posted.
AMC RULES
  • Excellent 5
  • Heart 2
ohiofarmer
 Well, guys, I did finally find the ID plate for the sweet sixteen. they painted it heavily, so I used some 1200 grit and water to reveal the numbers. 16K802  17383  6108
Some other things I did was to clear out the garage so I could get the trucks serviced--5 wheel horses in there are too many. Of course the wood shop has to be re-arranged as well to hold three more. The lift table will lift up to 42" off the floor, so they roll right in to the shop. The last pic is taken from the lift table with the c-160 ready to roll to the lift.
  For now, I have the heavy connectors from the battery and the starter /solenoid lugs all cleaned up. i took some old copper pennies and turned them into washers to make better connection to the lugs. I found out that the solenoid does not work. it clicks, however, so I will try drilling a tiny hole in the cap and putting penetrating oil in there. That has worked before, and i figure the OEM is still better than anything new from china.  While everything is pretty much down, I removed the voltage regulator to clean the connections and try to figure out why the electrons are not moving through the switch wiring correctly. one of the wires is just a stub coming out of the rear of the switch, so I need a diagram for that five wire plug/switch with only four wires left.
 I might just have to do a hasty wire engine tester to hear this tractor run
19richie66
16 hours ago, AMC RULES said:
If a tractor could be sexy.......:handgestures-thumbupright:
  • Like 4
  • Haha 1
Jhook
My new horse with loader is on the tow truck headed back to mass from ct!!!
  • Excellent 4
Jhook
Ok guys heres the pics. Any info on the tractor itself would be great. Looks like engine has been swapped. It runs(bad due to stuck float) and drives amd bucket works great. I paid 1,000 dollars for it as you see it. Im excited what do you guys think? Also anyone know what the loader is? Kwik way maybe EDIT: I think it says johnson on the blue sticker
Edited by Jhook
  • Excellent 7
ebinmaine
@Jhook
AWESOME.
At $1K you bout stole it.
Tractorhead
Even you must exchange few parts ( Seals) on hydraulics,
it seems definitely worth the Price.
Hydraulic support is a big help on working on heavier things
953 nut
:woohoo:                      you done gooooood!               :text-coolphotos:
It is a Johnson Workhorse loader, mine is the same model. The subframe on yours may not be correct, if should span from the front of the frame back to the rear axle. If the loader is just attached to one point near the center of the frame it could twist the whole frame.
  • Like 5
Jhook
Thank you! Im going to add a full length 3/16 inch subframe that bolts underneath the rear end. This tractor will be permanent loader machine
Pullstart
@Jhook as in you drive wrecker?  Well that’s convenient for wrangling!
Nice score!  It looks like everything is wet.  Hopefully it’s just rain and not everything leaking?
Jhook
Theres definitely some leaks. Especially the trans. And yes im lucky enough to have a company ram 5500 4x4 that is my daily driver, comes home every day. I take it everywhere locally, Not supposed to be used to travel far and buy things, but the boss doesnt mind once in a while 👍
Jhook
She slept on the truck last night cant wait to get it unloaded and fix the float issue and drive it
Jhook
Can anyone tell me what model it is by the pics? Will search for an id tag soon
Jhook
Update its a 1968 charger 12. Cool. You know its got some leaks when theres a wrench and funnel under the seat. And somehow managed to pop the front tire unloading it
squonk
Last leaf mulching job and time to take the recycler deck off. Crap sure gets behind the insert but the deck itself stays pretty pristine. Didn't scrape a thing. Then it's time to put the blower and loaded ag's on.
IMG_0013.JPG.b066f0f3669e7f87e7b0dc9769098874.JPG  IMG_0014.JPG.513c9c86c8c09c887ea4ca9620000fa6.JPG  IMG_0016.JPG.2325cb764e860d11526ae3796d5c3b0b.JPG  IMG_0021.JPG.a626743fd8a2bd4132ff7b4f7f8a710c.JPG  IMG_0022.JPG.5c2ced9f9eac445e4cd380b86fca7ff0.JPG
  • Excellent 3
peter lena
squonk , deck looks clean , that leaf mulching helped that , good opportunity to aerosol penetrating oil it down over winter , soak into the metal and kill of the grunge , leave it upside down , to trap and hold it there . over winter  ,the black surface look will be enhanced , all my decks are oil stained black , and zero rust , pete
AMC RULES
19richie66
Craig, you’re on a roll!
