SylvanLakeWH 25,577 #7076 Posted October 14, 2020 8 minutes ago, AMC RULES said: Sometimes I'd rather just not know. Meh... As Monty Python would say: Just a flesh wound...” 2 3 3 Share this post Link to post Share on other sites
AMC RULES 37,130 #7077 Posted October 14, 2020 Feeling like it's been maimed for life! 1 1 Share this post Link to post Share on other sites
Pullstart 62,902 #7078 Posted October 14, 2020 5 minutes ago, AMC RULES said: Feeling like it's been maimed for life! Good luck finding a 50-60 year old person with no scars like that... I feel like it’s just a story to tell 4 4 Share this post Link to post Share on other sites
71_Bronco 1,072 #7079 Posted October 14, 2020 31 minutes ago, AMC RULES said: Man, I'd love to have a cabinet like that. 2 Share this post Link to post Share on other sites
pfrederi 17,741 #7080 Posted October 14, 2020 Like my Father used to say .."A little putty and paint, make a job what it ain't" 1 2 1 3 Share this post Link to post Share on other sites
Tractorhead 9,064 #7081 Posted October 14, 2020 a bit welding and grinding for view, and after a Paintjob it look‘s like as new 4 1 1 Share this post Link to post Share on other sites
AMC RULES 37,130 #7082 Posted October 14, 2020 Relaxing after a dip in the chem bath spa. 5 2 Share this post Link to post Share on other sites
AMC RULES 37,130 #7083 Posted October 14, 2020 For those inquiring minds, I hereby present... ...the essentials. 4 2 Share this post Link to post Share on other sites
AMC RULES 37,130 #7084 Posted October 14, 2020 Made some forward progress today! 5 4 1 Share this post Link to post Share on other sites
Bostman67 54 #7085 Posted October 14, 2020 2 hours ago, AMC RULES said: For those inquiring minds, I hereby present... ...the essentials. Thank you! 2 Share this post Link to post Share on other sites
johnnymag3 2,520 #7086 Posted October 14, 2020 POR 15 is the best !!!!!! Share this post Link to post Share on other sites
squonk 41,121 #7087 Posted October 14, 2020 3 hours ago, AMC RULES said: For those inquiring minds, I hereby present... ...the essentials. OK Cragie, DX330 went obsolete 3 years ago. How old is that freakin can anyway? Share this post Link to post Share on other sites
Bostman67 54 #7088 Posted October 14, 2020 (edited) Back story. I purchased this recently. It hadn’t run in two years. Mice moved in and things looked bad. So at the advice of you guys I started with electrical and trying to get it started. Today I added a new battery and new ignition switch. I put a in-line 30 amp fuse and more... Edited October 14, 2020 by Bostman67 Added pictures 2 2 Share this post Link to post Share on other sites
Bostman67 54 #7089 Posted October 14, 2020 ...I also did more cleaning and exploring. I discovered what appears to be the K301S bolted only on the left side of chassis. Is this the right engine for this chassis? It’s suppose to a 1277 WH from 1967. Can anyone explain? I’m not that concerned at this point, but curious. Share this post Link to post Share on other sites
rjg854 11,368 #7090 Posted October 14, 2020 2 bolts come up through the frame 3 Share this post Link to post Share on other sites
Bostman67 54 #7091 Posted October 14, 2020 I also attempted to drain oil from K301S engine. I added about a quart of oil as a precaution. I was never able to find a drain plug. Is this drain plug? It didn’t make sense. How does this work? Should I remove the entire stem? Share this post Link to post Share on other sites
Bostman67 54 #7092 Posted October 14, 2020 (edited) 8 minutes ago, rjg854 said: 2 bolts come up through the frame Really? No way! Thanx! I appreciate that. Edited October 14, 2020 by Bostman67 1 Share this post Link to post Share on other sites
Jhook 849 #7093 Posted October 14, 2020 (edited) Installed the (now loaded) rear tires back on the tractor. And threw on one of the hubcaps i recently got in the mail, probably the best shape out of the 4. I like it now just have to decide on a repaint color or what im going to do to them. Towing all day m-f and 3 overnights a week doesnt leave me any daylight to wrench on this thing. Also gotta do shift boot and change trans fluid asap as it now looks milky when it didnt a few weeks ago. And you can see the cab still sitting on my trailer waiting for 2 more windows to be sewn in. Slowly but surely. Edited October 14, 2020 by Jhook 4 Share this post Link to post Share on other sites
Bostman67 54 #7094 Posted October 14, 2020 DID THE ENGINE START? No... but it tried to turn over. I was mainly concerned about whether I wired everything back correctly. Thanx to wheelhorseforum.com and ISAVETRACTORS.com I hope this week it will run. This time with gas and a new spark plug. FYI...I’m not an engine mechanic! Since this K301 sat for many years fuel appears to be dried up. What is the proper way to refuel and start up. I may replace carb after it’s running. 2 Share this post Link to post Share on other sites
ebinmaine 67,535 #7095 Posted October 14, 2020 25 minutes ago, Bostman67 said: I also attempted to drain oil from K301S engine. I added about a quart of oil as a precaution. I was never able to find a drain plug. Is this drain plug? It didn’t make sense. How does this work? Should I remove the entire stem? That is the drain plug. It should point DOWN. It's possible it's that way to keep the pipe threads from leaking. 3 Share this post Link to post Share on other sites
ebinmaine 67,535 #7096 Posted October 14, 2020 1 minute ago, Bostman67 said: replace carb Please don't. Rebuild it. Couple cans of brake clean and a gasket kit. Super easy. New after market carbs are not your friend. 3 Share this post Link to post Share on other sites
AMC RULES 37,130 #7097 Posted October 14, 2020 1 hour ago, squonk said: OK Cragie, DX330 went obsolete 3 years ago. How old is that freakin can anyway? Easily have been using that can for 10 years... worthwile investment I'd say...and how! Finally killed it today though. 2 Share this post Link to post Share on other sites
Bostman67 54 #7098 Posted October 14, 2020 (edited) 8 minutes ago, ebinmaine said: That is the drain plug. It should point DOWN. It's possible it's that way to keep the pipe threads from leaking. That makes sense! I will fix this. Thanx for your help! How can I keep ‘me from leaking. Some type thread sealer? Edited October 14, 2020 by Bostman67 Share this post Link to post Share on other sites
Bostman67 54 #7099 Posted October 14, 2020 5 minutes ago, ebinmaine said: Please don't. Rebuild it. Couple cans of brake clean and a gasket kit. Super easy. New after market carbs are not your friend. I’m not sure I have the technical skill. I will have to research it later on. Share this post Link to post Share on other sites
Jhook 849 #7100 Posted October 15, 2020 17 minutes ago, Bostman67 said: I’m not sure I have the technical skill. I will have to research it later on. If you have the skill to swap out a battery and an ignition switch you are capable of rebuild a carb. Only need a couple screwdrivers, look at a diagram and take your time. Very simple especially a single carb. 5 Share this post Link to post Share on other sites
