Ed Kennell
What have you done to your Wheel Horse today?
8ntruck
3 hours ago, D_Mac said:
@AMC RULES Would you mind if I set my tool box on top of it ?
Probably ought to keep it away from Pullstart.  He might use it as a work bench, maybe even a welding table.  :scared-eek::teasing-poke:
  • Haha 7
WHX??
16 hours ago, 953 nut said:
Not all conduit lock nuts are created equally.     The Big Box stores carry the cheap ones intended for EMT or NM fittings.   Go to a good electrical suppl house and buy lock nuts for rigid conduit, they are much heavier.
I'll second that. I have had the cheapys melt right off!
Mikey the Monkey
@AMC RULES...you are so talented. I can't stand it. Can't figure out if I want to steal that tractor, eat it, or just make out with it. Just beautiful. Hats off to you
  • Like 5
  • Haha 2
AMC RULES
:huh:  :rolleyes:  :blink:
  :wub:  :text-thankyoublue:
      :greetings-wavingyellow:
Edited by AMC RULES
WHNJ701
It really proves the point you can achieve a great paint finish with rattle cans if you properly prep and follow the steps
  • Like 4
echris
I'm about to start mowing "the back 40" today.
There's two swamp Maples back there with surface roots everywhere. Bouncy, bouncy, bouncy fun!
I drop the deck, move 10 feet and the deck makes this horrific noise.
Not like whittling a root, I have the deck adjusted to just skim the roots.
I shut off the deck, lift it up and back up.
There's a 12" long chunk of 1" diameter root laying on completely scalped grass.
Scalped the exact shape of a 42" SD. :text-lol:
The deck had dropped to the dirt and ate everything in sight. Other than the deck noise, the tractor didn't really care. LMAO.
The hitch pin on the deck height adjuster must've jettisoned off the tractor and at the same time the spring somehow disappeared. The spring can't fall off, so it must've disintegrated?!?
I always have a spare hitch clip on the tractor so I plugged it in and kept mowing. I could have just rested my right foot on the height adjuster lever if I didn't have a spare clip on the tractor.
:wh: Wheel Horse  - "There's Always A Field Fix."
  • Excellent 3
echris
I'll third that. My second job as a kid was at an electrical supply warehouse. We sold only Bridgeport fittings. I learned there that the cheapo stamped steel lock nuts are garbage.
Oh, that and Square D too!
ZXT
What's wrong with Square D? QO is just about the best you can get..
Maybe you're thinking Federal Pacific or Zinsco.
But yeah, the cheapo lock rings are garbage.
echris
 You got me all wrong. Square D is king.
Jhook
Can someone give me some info on this tractor and what its worth. Listed as "runs drives works, reverse is slow due to small transmission leak" ..... i dont know anything about hydros. I need to know the model, engine, is the trans easily fixable etc. Im very interested in jumping on it but don't wanna waste the money. You guys are the experts.
Edited by Jhook
johnnymag3
I saw this on Facebook this morning....I looked behind the Item for sale, and sort of got an Idea that this thing was a MUTT of all sorts of parts. It may be worth more in parts than its assembled condition. If you look in the background of the first picture....it sort of tells a story
John
Just my honest opinion
  • Haha 1
ebinmaine
@Jhook
Looks like a 1968 or 9.
if the loader works okay then it by itself is worth between $800 and $1,200 even if a little rough.
Others will answer about the tractor itself.
johnnymag3
I think he is asking too much........................
Ed Kennell
I'm guessing a 1970 Charger 12 .     With a Sundstrand 90-2046 hydro.
johnnymag3
the bucket seems to have alot of holes in it also upon close inspection..If the Reverse is slow, and the forward is fine...Im guessing its not a leak that is causing that situation...
pfrederi
Weak reverse is most likely bad neutral adjustment or acceleration valve issue not a leak.
If I read the spec number correctly 47651 it is a service engine (also blue paint) not original.
Edited by pfrederi
ebinmaine
7 minutes ago, Ed Kennell said:
1970 Charger
Tough to see on my phone but looks like the older square hood.
What's the asking price?
johnnymag3
1350.00
Jhook
7 minutes ago, johnnymag3 said:
1350.00
You local to ct/ma as well? Glad someone else was able to see the ad. I was going to offer him 1,000 cash for it
ebinmaine
8 minutes ago, johnnymag3 said:
1350.00
IIFF the loader works, doesn't leak much, and is solid... It's worth that.
WHNJ701
Too new and useful for my collection
  • Haha 7
johnnymag3
I am......1000.00 is a better price..
Keep in mind, thats if it actually performs its functions when you go to test it out
