ebinmaine 67,271 #5376 Posted June 21, 2020 @Boat guy Looks like you've got a 1974 or 5 B80. Great tractors!! My first, Patriot horse, is a 74. The Kohler 8 is a great little engine! Have to admit these horses look ok in yellow. Have you tested the output of the stator off the engine? Should be 30 - 35 volts AC at full throttle. Also try putting the wires at the ammeter to the same terminal on the back of the meter. That bypasses the ammeter. Check for charge then. Keep us posted and good luck! 1 2 Share this post Link to post Share on other sites
953 nut 55,071 #5377 Posted June 21, 2020 6 hours ago, Boat guy said: Gotta get to the charging situation and get that fixed. I guess that yellow must make your 80 an industrial . This drawing should be helpful with the charging issue. The two outer wires on the Regulator/rectifier should have 35 volts AC +/- with the engine running and the center terminal needs to have battery voltage on it with the ignition key on. 3 1 Share this post Link to post Share on other sites
Boat guy 40 #5378 Posted June 21, 2020 2 hours ago, ebinmaine said: @Boat guy Looks like you've got a 1974 or 5 B80. Great tractors!! My first, Patriot horse, is a 74. The Kohler 8 is a great little engine! Have to admit these horses look ok in yellow. Have you tested the output of the stator off the engine? Should be 30 - 35 volts AC at full throttle. Also try putting the wires at the ammeter to the same terminal on the back of the meter. That bypasses the ammeter. Check for charge then. Keep us posted and good luck! You guys are great, thanks! Will keep you posted, and yet does look kind of good in yellow instead of red. P.O said he painted it the same color as state and government owned wheel horses? Don't know about that ... Share this post Link to post Share on other sites
ebinmaine 67,271 #5379 Posted June 21, 2020 1 minute ago, Boat guy said: same color as state and government owned wheel horses I've heard/read there were a few. Not sure of the colors or what states used them. 1 Share this post Link to post Share on other sites
SylvanLakeWH 25,490 #5380 Posted June 21, 2020 @Boat guy... Nice tractor / trailer! 1 Share this post Link to post Share on other sites
Stormin 9,981 #5381 Posted June 21, 2020 Solenoid packed up on the C-125 yesterday, just after I'd put the deck on ready to mow. Nice sunny and warm afternoon as well. This morning fitted a spare solenoid that came with some spares for the Sears/Roper. Not the same, but works. Now the weather can't make it's mind up. One minute sunshine. The next rain. No seat time today. 1 1 1 Share this post Link to post Share on other sites
Tractorhead 9,064 #5382 Posted June 21, 2020 1 hour ago, Stormin said: Now the weather can't make it's mind up. One minute sunshine. The next rain. No seat time today. Same Weather conditions, no senseful Work can be done. i think important is the function of the solenoid, not the Shape Norm. 1 Share this post Link to post Share on other sites
squonk 41,022 #5383 Posted June 21, 2020 I have a couple of engineer friends. 1 is very old. Everything in his basement you could imagine. Machine shop, piano and organ, Wurlitzer juke box, a military surplus gen set that can light the neighborhood ect. Last I knew he was building computers from scratch . He had an 85" monitor hooked up so his grandkids can play games. 2nd one lives next door. He's never satisfied with nothing. He over builds stuff so bad that if it takes a week to build it, it takes a month to remove it Back to Horses. Since I defeated Joseph Lucas on his home turf with the electrical system on the 1075, I rigged up a temporary seat and replaced the belt. Done for today. wore my leg out yesterday. Got more clean up and cosmetics to go. 6 1 1 Share this post Link to post Share on other sites
D_Mac 8,593 #5384 Posted June 21, 2020 Detailed the engine on the C-161. Its looking pretty good from where it started. 4 5 Share this post Link to post Share on other sites
Lee1977 6,642 #5385 Posted June 21, 2020 (edited) 5 hours ago, Boat guy said: You guys are great, thanks! Will keep you posted, and yet does look kind of good in yellow instead of red. P.O said he painted it the same color as state and government owned wheel horses? Don't know about that ... May be he works for the state and got the paint free. Edited June 21, 2020 by Lee1977 4 Share this post Link to post Share on other sites
squonk 41,022 #5386 Posted June 21, 2020 23 minutes ago, D_Mac said: Detailed the engine on the C-161. Its looking pretty good from where it started. Is it my imagination or does that cable to the solenoid look like it's too tight? 1 Share this post Link to post Share on other sites
D_Mac 8,593 #5387 Posted June 21, 2020 39 minutes ago, squonk said: Is it my imagination or does that cable to the solenoid look like it's too tight? Ill have to have someone who knows a little about wiring come have a look at it. Know anybody? 2 Share this post Link to post Share on other sites
johnnymag3 2,515 #5388 Posted June 21, 2020 40 minutes ago, Lee1977 said: May be he works for the state and got the paint free. Wheel Horses are RED!!!! I hope you paint it, because all of the other horses In your herd...( and you will have one ) will not accept it 1 1 Share this post Link to post Share on other sites
ebinmaine 67,271 #5389 Posted June 21, 2020 48 minutes ago, squonk said: Is it my imagination or does that cable to the solenoid look like it's too tight? 9 minutes ago, D_Mac said: Ill have to have someone who knows a little about wiring come have a look at it. Know anybody? Can you get a pic of the wire with the hood open? Share this post Link to post Share on other sites
ebinmaine 67,271 #5390 Posted June 21, 2020 9 minutes ago, johnnymag3 said: Wheel Horses are RED!!!! I hope you paint it, because all of the other horses In your herd...( and you will have one ) will not accept it Patriot. Red, white and blue. Cinnamon. Reddish brown or brownish red depending on viewpoint. 1 Share this post Link to post Share on other sites
johnnymag3 2,515 #5391 Posted June 21, 2020 1 minute ago, ebinmaine said: Can you get a pic of the wire with the hood open? Looks like a very short cable to me.... Share this post Link to post Share on other sites
johnnymag3 2,515 #5392 Posted June 21, 2020 Just now, ebinmaine said: Patriot. Red, white and blue. Cinnamon. Reddish brown or brownish red depending on viewpoint. And small bears are yellow.....%^^&* Cadet 1 Share this post Link to post Share on other sites
ebinmaine 67,271 #5393 Posted June 21, 2020 1 minute ago, johnnymag3 said: Looks like a very short cable to me.... Agreed 1 Share this post Link to post Share on other sites
8ntruck 6,991 #5394 Posted June 21, 2020 14 hours ago, Boat guy said: Just bought this today for my property I just purchased, not a big place just not quite small for a push mower. Got it and trailer for 550.00. Seemed fair.. It did not run when I purchased it, I was told everything was fined as usual. Lol. Being just shy of 60 I knew I was in for a little bit, so what did I do to my wheel horse today?. Clean the carburetor, resealed the fuel tank petcock on the bottom that was leaking like a sieve, And clean all the grunge out of it, Replace completely melted voltage regulator plug with quality marine terminals, ( Still not charging ) Change the oil, cleaned up the points so I can start it as new ones and plug have been ordered, Adjust carburetor and governor, stared at it alot... lol At 1st I thought I made a mistake Getting it for the property but after correcting all the backwards things on it from p.o. it ran like a champ. Got lots more to do as I know now it will be exactly what I need. Got lots of stuff to take apart clean adjust and re install. Gotta get to the charging situation and get that fixed. But I think it's worth it.. seems like a good old horse. Looks like a good one, though, something just seems a little off about it. Can't quite put my finger on it...... 6 Share this post Link to post Share on other sites
8ntruck 6,991 #5395 Posted June 21, 2020 7 hours ago, ebinmaine said: I've heard/read there were a few. Not sure of the colors or what states used them. I saw an ad for a Gravely L series with a sidewalk brush that was origionaly purchased by the USPS. It was a similar yellow color. 1 Share this post Link to post Share on other sites
squonk 41,022 #5396 Posted June 21, 2020 Lots of tractor companies painted their "industrial" tractors yellow like most DOT's had their road equipment.I think it looks great. There was a yellow 3 wheeled horse at the big show a couple years back that was awesome. 2 Share this post Link to post Share on other sites
ebinmaine 67,271 #5397 Posted June 21, 2020 I spent several hours today experimenting with a new tool. I bought a needle scaler a few weeks ago. I've been wanting for a year or more to repaint the rear wheels that have been on Patriot, the 1267/87 mongrel, and now live on Cinnamon Horse. I had started to simply swap wheel spacers on Cinnamon and then everything went haywire like I always do. I got to thinking... While the wheels are off I'd try the needle scaler and have the paint department throw some nice new Navajo White on. Well I removed a little paint. Then discovered it crappy paint and not worthy of a Wheelhorse. So I stripped both wheels in and out using a combination of the needle scaler and the body grinder with a wire brush. Then Trina set to painting things up a bit. I'm swapping from 3" to 2" so I can use the 3s for Colossus. Here's both sides before: The right side is particularly nasty at the inside bottom. Custom made shaded work station 4 3 1 Share this post Link to post Share on other sites
johnnymag3 2,515 #5398 Posted June 22, 2020 NICE WORK !!!!!! 1 Share this post Link to post Share on other sites
johnnymag3 2,515 #5399 Posted June 22, 2020 45 minutes ago, ebinmaine said: I spent several hours today experimenting with a new tool. I bought a needle scaler a few weeks ago. I've been wanting for a year or more to repaint the rear wheels that have been on Patriot, the 1267/87 mongrel, and now live on Cinnamon Horse. I had started to simply swap wheel spacers on Cinnamon and then everything went haywire like I always do. I got to thinking... While the wheels are off I'd try the needle scaler and have the paint department throw some nice new Navajo White on. Well I removed a little paint. Then discovered it crappy paint and not worthy of a Wheelhorse. So I stripped both wheels in and out using a combination of the needle scaler and the body grinder with a wire brush. Then Trina set to painting things up a bit. I'm swapping from 3" to 2" so I can use the 3s for Colossus. Here's both sides before: The right side is particularly nasty at the inside bottom. Custom made shaded work station And beverage station I see.....very nice 2 2 Share this post Link to post Share on other sites
ebinmaine 67,271 #5400 Posted June 22, 2020 8 minutes ago, johnnymag3 said: beverage station Oh yeah.... Share this post Link to post Share on other sites
