Ed Kennell
What have you done to your Wheel Horse today?
PeacemakerJack
:text-yeahthat:Sometimes they help and do it because they want to, other times I have to encourage them to do so.  However, I know in the long run it is very beneficial to them. They learn the proper use of mechanical tools, critical thinking skills, how things are assembled, observing what REAL quality is so that they are more able to spot cheap substitutes in the future, a general mechanical knowledge for times when they may need it and I’m not around, the list could go on.  My kids enjoy their gaming system for sure but I try to make sure it stays balanced with things that have a much greater importance to their future well being.
  • Excellent 4
  • Heart 2
WHX??
8 hours ago, PeacemakerJack said:
about the new attachment I’m picking up this weekend for it
:text-coolphotos: of that bad boy when you get it!
You need deck shells like those Jack I am quite heavy on them and need to cull a few. Just can't bring myself to scrapping them tho.
squonk
On 6/13/2020 at 10:55 PM, echris said:
Found this one today while the dash screws were a-painting.
Please don't put a cotter pin in here. Especially not a too-small cotter pin.
I guess I figured out why my lift was still cranky after lubing it up good. :)
You jinxed me. I have never run across a cotter pin in the lift arm. Still haven't but I did run across a nail with a nice 90 deg bend today!
8ntruck
Yup.  Exactly what I replaced in mine.
Snoop@ICI
4 minutes ago, WHX24 said:
Worked on some messed up hubs for @Snoop@ICI
I have seen some bad ones but these were the worst. No idea how they ever even stayed on the tractor.
The one side walked in so far the woodruff decided to do a little machining of it's own! :huh:
Did manage to save them both.
Looks great Jim.
ebinmaine
24 minutes ago, JCM said:
gluttons for punishment
That's accurate...
  • Haha 2
Lee1977
1 hour ago, ebinmaine said:
That's accurate...
Trina did all the work. We are not sure what you have been doing.
I cut up some metal to make a receiver hitch for tr 520-H. Need to pick up the receiver hitch and some bolts. Then get it welded.
Edited by Lee1977
  • Like 5
  • Haha 1
ebinmaine
8 minutes ago, Lee1977 said:
Trina did all the work. We are not sure what you been doing
As little as possible minus 10%
  • Haha 1
Lee1977
5 minutes ago, WVHillbilly520H said:
Josh my boy in WV has kept me on my toes for the past 3 months with his Federal Yellow and White collection it has been a "frustrating" but rewarding process as I only get to help him physically once every couple weeks then trying to explain how things work/go over the phone but nonetheless he has a 70s 1200 and then late 80s a 1211 Kohler Magnum 12 hydro and 1606 Briggs Vangaurd 16 Hi/Lo 3spd I just can't get him on a red WH he wants a red 82 series... Anyways what I done to my WH today "new" shoes on the rear of the 414-8 from 23x8.50s Carlisle Turf Savers to 23x9.50s Carlise Turf Masters
Looks a lot  better with the Turf Masters.
ebinmaine
We choose Horses to own/use for reliability and maintenance reasons but I'd not be too upset to have a ?82 like my Grampa did.
ebinmaine
@JMcBrew
:text-welcomeconfetti:
Nice ride there!!!
  • Like 4
echris
Remember last weekend when I offered a shiny dollar to anyone who could identify where this set screw goes and @953 nut came through, well I still owe him a dollar but...
And remember when I said I was pretty sure there was a set screw in the shifter? I wasn't wrong, kinda.
Today I thought, maybe I oughta clean the dirt off the end of that set screw and have a look.
And I found this:
Clearly the set screw broke off in the shifter mounting boss.
This job is going to have to wait until I remove the trans-axle from the machine. But hey, my shifter isn't popping out...for now...
  • Sad 1
echris
Normally, I really don't care too much about a too small cotter pin, or a bent nail. We've all done that when a field fix is necessary. But when it's in a spot like inside the dash tower, with very little wiggle room, NO! Futz around for 20 minutes trying to find the right tool to remove that cotter-ish pin in a tight spot when a simple piece of stiff wire with a hook on the end will remove any hitch clip. (usually)
echris
2 hours ago, JCM said:
Back at the 420 today and straightened out the side of the tunnel where the brake rod goes in from the pedal. Looks like someone had tried to pry on it for some reason, got out a 2x4 with a couple screws and fender washers and a ball peen hammer to flatten it out some then removed the 2x4 and used a dolly and hammer to finish it off. Pulled everything inside the tunnel out, all shafts and motion control lever and will clean it up and replace anything that needs it. The picture of the roll pin set was used to knock out broken cotter pins where there should have been hairpins, that set has always worked very well and durable. A few pics of painted items for both the 310 and the 420. My hat goes off to all of you who take on full blown restorations and builds, you are all amazing and gluttons for punishment.  :clap:
Nice hammer and dolly work! I took BOCES bodywork classes in High School. One of the first things our teacher Mr. Pender taught us was manually working steel. :wh:
  • Like 4
ebinmaine
That's a skill I'd like to work at someday
  • Heart 1
echris
It's such a satisfying skill. I've lost the art all these years later, but I remember being taught to look for the direction of impact, and reverse it.
Man, when you nail that the first time and ~80% of the panel pops back into shape... Bondo?!?! Puh-shaw...
Pullstart
Took an evening field stroll tonight.  It’s been long work days this week!
  • Like 8
D_Mac
Got the paint on the deck before it got to dark. I have to leave it outside all night, hope it dosnt rain. Was hotter then  H   E  double toothpicks out there today. Looks ok I guess, the tractor isnt here to compare the color. I have the deck decals on order from @Vinylguy . At least its going to look better then it did. < I hope >
Edited by D_Mac
  • Like 4
  • Excellent 4
Shynon
20 hours ago, PeacemakerJack said:
I’m really excited about the new attachment I’m picking up this weekend for it
:popcorn:
  • Excellent 3
