balconio 606 #4626 Posted May 1, 2020 6 minutes ago, tom2p said: as eb would say - don't ask me how I know this ... lol one seat spring on my 312 was apparently rubbing / pushing on the top of the dipstick (handle) and it apparently caused the end of the dipstick to contact moving parts in the gearbox and ground a small notch in the end of the dipstick of course this happened after a recent trans fluid change ... so had to do it again the top of the dipstick should sit lower and/or the plate (the seat springs rest on) should be higher ... on the topic of oil- i'm a believer in full synthetic for my cars/trucks, but i'm having doubts about using it in these old tractors. i know there's a fair bit of (dis)information on the web, but i read some things about how full synthetics might not be good for older engines in terms of seals and leaks. i'm going to err on the side of believing this and plan to use only dino-oil in the engine/transaxle. i experienced this exact thing in an older AYP lawn tractor, where i did a full synthetic oil change with 10W-30 and it leaked out the rear main seal. the idea is that the detergents are too strong and effective at cleaning out minor sludge which actually helps to seal these older engines which have looser tolerances and old-school rubber seals 2 1 Share this post Link to post Share on other sites
Pullstart 62,838 #4627 Posted May 1, 2020 Yep, 30 weight non-detergent oil is the way to go. Dino version works just fine 4 Share this post Link to post Share on other sites
Achto 27,565 #4628 Posted May 1, 2020 I'm a true believer in synthetic's myself in newer engines. But if a 50+ year old engine spent it's whole life running 30wt dino juice and is still running today. Well, I guess that kinda speaks for it's self. 6 Share this post Link to post Share on other sites
johnnymag3 2,520 #4629 Posted May 1, 2020 ok....so now that I exposed the wires.....where do I go from here? Why is there a rectifier in my 310-8? do I have a stator? or is that a diode in the factory line and I still have a alternator? Ive never seen anything like this.... Should I start it and measure the output of the 2 yellow wires coming from the shroud to the regulator? Will that give me an answer? I have never seen a regulator bolted or mounted to the back of a dash on a 310-8? wandering aimlessly and scratching my head.... Share this post Link to post Share on other sites
Tractorhead 9,064 #4630 Posted May 1, 2020 7 minutes ago, johnnymag3 said: ok....so now that I exposed the wires.....where do I go from here? Why is there a rectifier in my 310-8? do I have a stator? or is that a diode in the factory line and I still have a alternator? Ive never seen anything like this.... Should I start it and measure the output of the 2 yellow wires coming from the shroud to the regulator? Will that give me an answer? I have never seen a regulator bolted or mounted to the back of a dash on a 310-8? wandering aimlessly and scratching my head.... Do you have pic‘s Share this post Link to post Share on other sites
pfrederi 17,729 #4631 Posted May 1, 2020 9 minutes ago, johnnymag3 said: ok....so now that I exposed the wires.....where do I go from here? Why is there a rectifier in my 310-8? do I have a stator? or is that a diode in the factory line and I still have a alternator? Ive never seen anything like this.... Should I start it and measure the output of the 2 yellow wires coming from the shroud to the regulator? Will that give me an answer? I have never seen a regulator bolted or mounted to the back of a dash on a 310-8? wandering aimlessly and scratching my head.... You should start a separate thread in electrical system. To hard to find you pictures and previous posts buried in here. 1 1 1 Share this post Link to post Share on other sites
johnnymag3 2,520 #4632 Posted May 1, 2020 yes...look back a few posts, I posted them 12 hrs.ago. Thanks. In this thread Share this post Link to post Share on other sites
johnnymag3 2,520 #4633 Posted May 1, 2020 On 4/30/2020 at 3:32 PM, johnnymag3 said: Made some headway today on the 310-8. doing all of the wiring over......its a rats nest....but it does work !! Wire nuts, scotch locks...whatever he had in reach I guess Also found a regulator rectifier behind the dash plate...!!!!!!! Whats the deal here I ask. I thought it was one of those unregulated systems.... Hmmmmm I guess the previous owner may know....but maybe not. Remember he is 88 years old. This is part of my Covid….19....Corona deal 3 weeks ago HELP Share this post Link to post Share on other sites
johnnymag3 2,520 #4634 Posted May 1, 2020 21 hours ago, johnnymag3 said: this is what I found under the covering Share this post Link to post Share on other sites
pfrederi 17,729 #4635 Posted May 1, 2020 6 minutes ago, johnnymag3 said: Check the Ac voltage just on the yellow wire (unbroken one) mifht be tehhead light circuit. Try to read DC on the wire with the thing in it. If it is a diode it will be DC down stream Hard to tell from picture if that is a diode or just a connecter. Need to move this to and separate posting in Electrical. 1 Share this post Link to post Share on other sites
johnnymag3 2,520 #4636 Posted May 1, 2020 I moved it.....thank you also there is no broken wire, it appears that the seal on the yellow wire is factory. Do they put the diode in there? Thanks again Share this post Link to post Share on other sites
balconio 606 #4637 Posted May 1, 2020 Today it's cosmetics, painted the wheel weights since they were looking grungy. I also greased the deck while it's off and will get to work on replacing the brake shaft seal. One front tire is dry rotted so I'll toss on that spare in the foreground. Oh yeah and added an "aircraft style" switch cover just because 6 1 Share this post Link to post Share on other sites
Greentored 3,201 #4638 Posted May 2, 2020 The 1277 is getting a buff out while the shop stove cooks my late dinner. This ones getting a shine on what’s left and done. Probably a very good idea to put something other than hops and barley in my belly, was a rough week👍 5 2 1 Share this post Link to post Share on other sites
ebinmaine 67,438 #4639 Posted May 2, 2020 (edited) Messed around outside most of the day. Excellent weather and the blackflies are just starting to wake up so not too bad yet. Amongst a bunch of other things I hauled 3-1/2 loads of wood out and Trina pulled 2. She and her mom stacked it in the woodshed. Edited May 2, 2020 by ebinmaine 2 2 Share this post Link to post Share on other sites
953 nut 55,194 #4640 Posted May 2, 2020 12 minutes ago, ebinmaine said: Amongst a bunch of other things I hauled 3-1/2 loads of wood out and Trina pulled 2. She and her mom stacked it in the woodshed. You were asking for running board ideas for "Colossus" the other day. I think I just spotted a good one. 1 8 Share this post Link to post Share on other sites
ebinmaine 67,438 #4641 Posted May 2, 2020 31 minutes ago, 953 nut said: You were asking for running board ideas for "Colossus" the other day. I think I just spotted a good one. HAHAHAHAHAHAHAHA!!!! Well done sir. I'll have my lead woodpile stacker and organizer remove that immediately. 3 Share this post Link to post Share on other sites
D_Mac 8,607 #4642 Posted May 3, 2020 Pull it out like Jenga and it all comes down ! 2 2 Share this post Link to post Share on other sites
D_Mac 8,607 #4643 Posted May 3, 2020 @balconio We are neighbors ! Grew up in Webster, live in the city now. 1 Share this post Link to post Share on other sites
Andy N. 2,143 #4644 Posted May 3, 2020 Put the tiller on the 312-8 for a fun day of garden tilling! IMG_0350.mp4 2 3 Share this post Link to post Share on other sites
johnnymag3 2,520 #4645 Posted May 3, 2020 Today I put the mask on the 418 A , again....we are heading out to roll the lawn as we give the grass a haircut. Gotta wait until the dampness is gone though 1 1 8 1 Share this post Link to post Share on other sites
Pullstart 62,838 #4646 Posted May 3, 2020 29 minutes ago, johnnymag3 said: Today I put the mask on the 418 A , again....we are heading out to roll the lawn as we give the grass a haircut. Gotta wait until the dampness is gone though that Horse won’t catch no virus! 1 2 Share this post Link to post Share on other sites
tom2p 2,394 #4647 Posted May 3, 2020 On 5/1/2020 at 11:07 AM, balconio said: on the topic of oil- i'm a believer in full synthetic for my cars/trucks, but i'm having doubts about using it in these old tractors. i know there's a fair bit of (dis)information on the web, but i read some things about how full synthetics might not be good for older engines in terms of seals and leaks. i'm going to err on the side of believing this and plan to use only dino-oil in the engine/transaxle. i experienced this exact thing in an older AYP lawn tractor, where i did a full synthetic oil change with 10W-30 and it leaked out the rear main seal. the idea is that the detergents are too strong and effective at cleaning out minor sludge which actually helps to seal these older engines which have looser tolerances and old-school rubber seals the issue you observed is not uncommon - newer synthetic oils can result in leaks due to the properties of the oil if for no other reason - even and including synthetic oils that promote seal compatibility ... they (basically) just flow better the other issue is it can also be a challenge to find synthetics in the proper viscosity ... fortunately there are a number of good quality conventional motor oils ... they might not protect as well as the top performing synthetics when used for an extended period - but still perform very well (and better than some well marketed synthetics) in the past I've used Valvoline, Castrol, and Kendall conventional motor oils - but unfortunately availability became more of a challenge and I got lazy and began to use synthetic in everything - including our 704 ... Share this post Link to post Share on other sites
Lane Ranger 10,968 #4648 Posted May 3, 2020 Cleaned out the garage today! Took out six of my nine Wheel Horse tractors including all three RJ’s ! Still working on another RJ in garage . Nice day for it. All six tractors started and I even trimmed the lawn on the edges of the driveway with the RJ with the mower deck on it! 12 1 3 Share this post Link to post Share on other sites
Pullstart 62,838 #4649 Posted May 3, 2020 @Lane Ranger that middle RJ, is that the patina pattern or a shadow? It looks awesome! 2 Share this post Link to post Share on other sites
Lane Ranger 10,968 #4650 Posted May 3, 2020 Patina 1958 from Oklahoma. -no Date code on transmission so early 1 Share this post Link to post Share on other sites
