Ed Kennell
What have you done to your Wheel Horse today?
rjg854
Yesterday I took the 16 auto out of the shed in order to melt the snow out of the blower housing while it sat out in the sunshine.  I  heard a bang while it sat idling.  When I went to move it, it wouldn't move and the belt wasn't spinning.  OH NO :angry-banghead:  I  wanted to get it back to the shed, so I released the relief valve and I still couldn't push it. I didn't really want to "but" I got chain and the 877 and dragged back to the shed and pushed it into the shed with the plow blade against the blower.  One problem solved!  Today tore it apart and found this
Easy fix with a new belt, checked the pulley, oiled it, put it back together, closed the relief valve, and fired it up. Runs and operates like it should :handgestures-thumbupleft:
  • Like 6
  • Excellent 2
  • Sad 2
squonk
I can see that belt better on my PC than the phone. I don't see any cracks from the outer edge of the belt towards the inner edge. I sold hundreds of that kind of belt. Very unusual for a chunk to come out like that without the entire belt showing cracks everywhere. Maybe something got on a pulley (chunk of ice ect.) I got a piece of a stick in a PTO belt that took out a small chunk. Keep your eyes and ears open next time you run it.
rjg854
Plowed the snow that drifted into the driveway overnight back and then used the blower to get it back even further sounded and operated normally.
  • Like 5
squonk
I'm wondering if a piece of ice up in the fender pr belt guard melted loose and fell into the spinning belt.
squonk
Took advantage of my last oddball holiday for the school year and replace the throttle cable on HHHOOOWWWAAARRRDDD!!!
  • Like 9
cleat
I like your pics.
We should have grass like that in around 2 months from now.
Under a foot or so of snow right now.
Likely mole tunnels under that though....
Lane Ranger
The second one I am working on today is one that was rebuilt but with a suburban side plate on brake band side!  I bought redone in West Virginia!  Turns out it is an early RJ version in great condition inside!  I am going to change the brake band side to an RJ plate!
  • Like 4
  • Excellent 4
Ed Kennell
I picked up this Tecky powered Raider last week.      She runs and drives, but idles like a Tecky.    I gave her a double dose of  Sea Foam.  Hope it clears up her cough.
102_1363.JPG.215ef271060d80fbe62e588fad1c28bd.JPG102_1364.JPG.9123f66817e8c8e98d546f182e375d03.JPG
Got the lights and the cigar lighter working.
   I took advantage of the 60F temps to clean and paint the front wheels.   Old  playing cards make great masking.
Had to take one tire off and patch the tube.
If the stars line up,  you may get to know this one at the Big Show.
  • Excellent 7
balconio
I got the tires mounted and tested them out this morning. I'm now able to hop right over downed logs, churn thru mud and snow with ease, and I've got another 1.5" of ground clearance. I never got stuck once and I was really trying. The ride on asphalt is pretty choppy now but I that's a surface I rarely ride on.
As an added bonus I didn't have to raise the seat pan at all, the clearance is tight but it's there. The mudlite 2s are very impressive rear tires.
  • Excellent 6
Lane Ranger
Rodney Burger and I working on a third three piece transmission .  Pretty dirty and bad bearings and brass bushings!
Lane Ranger
Rodney Burger and I working on a third three piece transmission .  Pretty dirty and bad bearings and brass bushings in differential and axle housings on side plates!
  • Excellent 4
The Tuul Crib
Looks like you got it under control lane !
But l have to say thats an interesting
use for a drum throne!
:ROTF:
WHX??
Put a decal on a dash plate.. might seem small but a huge accomplishment for me in not screwing it up first time around! :lol:
Used windex method and worked good for old chief  ten thumbs here...
Edited by WHX24
  • Excellent 7
ebinmaine
5 hours ago, balconio said:
enjoyable on the tractor
Life is about the journey, not the destination.
Taking your time and looking around is what it's all about.
  • Like 5
bottjernat1
:ROTF:
When i had mine redone i used motion industry for my bearings,seals and bushings. Mine had the problem of someone took it apart at one time and they never put gaskets between the plates and so i had metal on metal grinding and most of the bearings were stuck. She is like brand new now. I had lots of help on mine i took it apart but i had a guy put it back together for me.
pkerot
I've never had a wheel  horse before but I got a 1981 gt2500 today. Front tires wont hold air. I'm going to take the bowl off of the carburetor and squirt diesel down the sparkplug hole and see if it will spin over and start. I'm happy to find this forum so I can learn about the wheel horse.
  • Like 5
ebinmaine
Welcome to Red square!
Great bunch of folks here.
Any questions you have, ask away...
By the way. We love our pictures....
pkerot
Thank  you.  I had to push the mower hundreds of feet to  the trailer with  4 flat tires so  I am tired and quit early  today.  I got the carburetor off, not bad inside.  I  put a hot battery on it.The key is in  the ignition but nothing happened so I jumped straight to the starter. It spins good.I had taken the sparkplug  out.  It looks good. I put diesel  down the hole and the starter blew it out so compression  looks good. The muffler looks good except the seam  is cracked. I took  it off so I can weld and one of the bolts broke off in the block. So I'll have  fun drilling it out. Got stuff to do  in the morning but later will clean electrical connections so  it turns the starter with the key and check for spark and get you guys some pictures.  I sure am glad you guys have a forum for this machine.
Rob R
Suggest you put TUBES in the tires going flat I have done this many tires some pretty badly dry rotted and this works great..... suggest you heat the tires with a heat gun or dryer so they are warm then break the bead on both sides pry the valve side past the rim, pop out the existing valve, insert the tube and replace this side under rim.
Edited by Rob R
