Ed Kennell
What have you done to your Wheel Horse today?
CCW
Added front weight to my 312-8 using discarded concrete post used in home building.  These were the sections cut off at a construction and they were going to be trashed.  Lashed to an extra mule drive and add approximately 65 pounds to the front end.  Helps to reduce the wheelie issue.
IMG_1148.JPG.8a37916dbbf432db78065c3387a6df44.JPGIMG_1147.JPG.1ec3b5293c804d76a410f6ea0a9acb50.JPG
  • Like 4
pfrederi
Getting the  K341 small base mounted on an Electro12 frame. Had to drill some new holes in the frame.  Needed spacers found out the spacers used on K181 shaker mounts plus 3 SAE washers exactly matches the rise of a shaker mount.
  • Like 7
  • Excellent 2
ebinmaine
That is some good information to tuckaway in the memory files
pfrederi
  Your memory files must work a heck of a lot better than mine..:P
  • Haha 2
ebinmaine
No sir. No they do not.
:ROTF:
Razorback
Nothing much..... just put a couple of GT batteries on their tenders.
RJ59
Wheel horse 800 special project of mine, had to remove busted drive pulley.
New pulley and pto mounted in this picture, almost done currently reassembling the tractor.
adsm08
I left them go swimming today.
Actually I came home to find a river running through the garage. The man door sits in a low spot and water was pooled around it and running in at the corners, right out the garage door and into the lake in the driveway. Unfortunately that means the outlet for my sump pump is currently under water, which I just realized....
  • Sad 1
SylvanLakeWH
12 minutes ago, 81blackhood said:
after 6 months my c125 is finish.
7C8192AD-BD1B-4F2F-8B58-D20D4DAC0762.jpeg.485339eea55b5d8e0511b5837e171225.jpeg4A6DC48F-9048-4EEE-A258-61950583A373.jpeg.d9f14411212958806e990aac2ede3986.jpeg
Nice job! :bow-blue:
Love the Black Hoods! :ph34r:
Achto
8 hours ago, 81blackhood said:
Looks fantastic!!! :handgestures-thumbupright:
PeacemakerJack
Got the big wheels out today to clean up the rest of the nasty apples off the trees.  Caleb and Judge has fun shaking the trees and making “baskets” with the old apples into the trailer.  About the time we were finishing, Achto stopped by and so I asked him if he wanted to drive Rusty up to the shed...
Of course he took me up on it!  We both agreed that it could use a new seat and some fresh “linen” paint on the wheels.  I need to get Terry’s decals on it too...Fun afternoon
Claudia picked through a couple of the “good” apples that Caleb found and made a scrumptious apple pie!  We just finished eating some of that—yum!
Edited by PeacemakerJack
  • Like 4
  • Excellent 3
  • Heart 2
19richie66
Apple pie with vanilla ice cream ❤️
  • Heart 3
Macwrench
It's ALIVE!
  • Excellent 6
WHX??
Nice job on that one @81blackhood Love your selection of rubber and the metal fender pan! :handgestures-thumbupright:
adsm08
On 11/3/2019 at 6:01 AM, SylvanLakeWH said:
Added dually’s to the WHrat WHrecker...
Used 12” pvc pipe with a 2” spacer width...12” carriage bolts. Tires are 23x8.5x12.
It looks like it is coming for my immortal soul.
I love it.
  • Like 4
Razorback
Was getting the Wheel Horse C160 out to clean and remove the tiller. One-year-old Duralast gold battery from AutoZone was toast. It was kept on a tender all last winter, GT was used earlier this year to till the garden. Battery would not take a charge. Looked up the warranty on the battery.... 3 MONTHS!!!!! I guess they know they sell a piece o’crap. Never again!!!
Grabbed the fairly new one out of the Cub Cadet 123 (that needs a new right front axle) and it fired right up. I cleaned up the tiller and got it stored away, got the front blade out and more accessible, but ran out of light before I could get it mounted on the C160, in anticipation for snow this winter.
Meanwhile, also removed the bagger from the Craftsman PGT9000 and put it away.
I am hoping to get the Speedex 1631 out soon and plough the garden..... hopefully that will help with the weeds next year.
Off to local Battery Outfitters shop for a new battery tomorrow..... hopefully will have better than a stinkin’ 3-month warranty on their GT batteries.
953 nut
I had a problem with a tender boiling a good battery dry a few years back. I now put the tender on a timer where it will only be on one hour a day, works for me.
Edited by 953 nut
  • Excellent 4
Razorback
14 minutes ago, 953 nut said:
I had a problem with a tender boiling a good battery dry a few years back. I now put tyhe tender on a timer where it will only be on one hour a day, works for me.
That’s a great idea. Thank you.
(I still think Duralast batteries are less than good... we’ll see.... the only reason I got that battery was because my local O’Reilly shop was out of the battery I needed. All of my other batteries come from Battery Outfitters.... I think I’ll check out their GT batteries.)
McGrew
About a month ago, I was using my Raider 10 for yard work.  It required lots of shutting the engine off and restarting.  Toward the end of the day, the tractor would barely start, and I had to jump it to put it away.  I found the original regulator (dated 1971) had gone belly up.  I replaced the regulator, and all is fine.  I decided to add a volt gauge so I could monitor the charging system.  Ebay to the rescue!  $7.64 later, I have a voltage gauge...  I didn’t realize how nasty the steering wheel was...  Danny
  • Like 6
  • Excellent 2
Achto
That is a very cool looking volt meter!! Care to share a link to it?? I also like the little cotter key that keeps you throttle knob from spinning on the shaft. Great idea!:handgestures-thumbupright:
Pullstart
Hot Wheels has the same volt meter, maybe @953 nut knows the source too?
Razorback
Now THIS is more like it.... Pro-Series L&G battery, 450 CA, 360 CCA, ONE YEAR WARRANTY, for the same price as the Dura(not)Last!
https://tractorfanatics.com/attachments/image-jpg.19631/
