Ed Kennell
What have you done to your Wheel Horse today?
Blasterdad
12 hours ago, WHX?? said:
Keyway bad Blaster lemme know I'll bring the broach set ... put a new one in.
All set, caught it in time. :handgestures-thumbupright: Thanks!!!
WHX??
I see that... :thumbs2:
Why does it look like that seal is in abit?
Mine are always flush with the edge.
Blasterdad
12 hours ago, ebinmaine said:
@Blasterdad
You got nice new set screws?
Usually I do but it was in like new condition, that was my last 11050 seal too, so time to restock both. :handgestures-thumbupright:
Blasterdad
That's how the old one was too. That was pushed in with my thumbs until is seated, wasn't drove in hard by any means..:confusion-shrug:
BBQVultureWings
 My sister had a big Black Walnut tree uprooted by the last storm so put Cyclops on the trailer, used a chainsaw mill attachment to slab out the trunk. Gave Cyclops a workout dragging those Heavy pieces on the yard cart. I am really Impressed with the Wheel Horse C-145. It marched right on up the hill in that back yard out to the street no matter how much weight was on there. I thiMk 1 of the loads was well over 800 lbs & No problem at all. So I gave Cyclops a real workout the past couple days. Been working on the new seat pan but my welds are horrible right now. After a little more practice, I will post pics when those welds are presentable. Also keeping the blade on for now as there are some areas in her yard that could stand a bit of grading same as mine... enjoy the pics more to come when I have more progress on that custom Diamond Plate fender too
  • Excellent 6
ebinmaine
I've seen that too. Could be the bearing was set in a bit too far by a PO or even at the factory.
That seal being able to be hand pushed should be watched. It'll probably be fine but friction holds it in.
The only one I can recall me being able to hand set was on a housing that very badly worn down by the hub riding against it.
ebinmaine
3 hours ago, BBQVultureWings said:
thiMk
Gotta be very careful doing that.
Sometimes causes thawwts.
As with plowing snow or dirt, traction is the limiter fuse here.
I built my '74 C160-8 Cinnamon Horse to be a Heavy Stuff Puller.
I'm quite sure I've pulled at least 1200 to 1500 pounds of firewood up outta the forest 🌳 on a few occasions.
No hesitation.
  • Excellent 2
Blasterdad
It was actually a snug fit, I had clean motor oil on the axle, seal, & rubber gloves. The seal itself was all black rubber with the metal ring encased inside it. I've got a special homemade driver for both the 8 speeds & hydro's, one tap satisfied my OCD. The seals with the metal exposed on the outside edge do take a bit more to seat but it's what I had. I replaced one on a different tractor with the same seal years ago with no problems. I'll definitely keep an eye on it though. :coffee:
  • Excellent 2
WHX??
Should be ok if the bearing is good.
My thought too.
BBQVultureWings
8 hours ago, ebinmaine said:
12 hours ago, BBQVultureWings said:
thiMk
:confusion-confused::ROTF:Thawwts:ROTF::confusion-confused:
  • Haha 1
nylyon
Changed the oil on the 416-8, and FINALLY found why it was running poorly, one bolt on the forward intake manifold port was loose.  Tightened it up and running great, of course I cleaned the carb again, but hey at least the carb is nice and clean!
  • Excellent 5
Blasterdad
The bearing seemed fine, no play in it, no noise, nice & smooth. The seal might be a little thinner than the original too, giving it the appearence that it is in further...
pfrederi
It is not a bad Idea to move a seal in or out  further than the one you replaced... Seals can wear a groove int the axle.  get the new seal on a better surface...
  • Like 7
ebinmaine
I've been known to flip a seal inside out and install reversed on a low or no pressure application. Often moves it just enough.
  • Like 4
rick
I had a Troy Bilt Pony come in to repair a leaking wheel axle seal.
I found someone had tried a repair previously and had gouged the axle badly trying to remove the leaking seal.  I had to put the new seal in about half way to put the seal on a good surface.  The repair was successful, the machine hasn't come back and the customer has brought other in work since.
  • Like 4
stvski80085
Put the motor back on b-80 and mower deck.  Just need some adjustments. It’s running rich but starts right up.  Verified battery is charging.  Ordered some new battery cables.  The ones I have were to long.  Finishing it up tomorrow.
  • Excellent 7
Sparky
  Started messing with this old gear drive deck for my 857. New grease and one new zerk.
 Drive pulley bearing is a bit tight. Getting a PB Blaster soak (already started moving)
squonk
1 hour ago, Chris G said:
Went and picked these 2 up today. Couldn't go wrong for $200
Yup. I saw them and thought they had your name all over them!
  • Haha 1
squonk
On 3/27/2025 at 5:17 PM, rjg854 said:
Had to put a new ignition switch in the '68 Commando 8, so while I was at it, new fuel lines, shut off and filter.
Did you clean that Day Bree around that HL switch?
ebinmaine
4 minutes ago, squonk said:
Day Bree
If'n ya find such muckage in the darker world is it Night Bree??
  • Haha 3
squonk
Better off replacing those bearings Sparks. Cheap and when that bearing seizes it will ruin the shaft it rides on.
HyperPete
Today I put the carb back on the 414-8.  I also replaced the wire nuts in the ignition circuit with waterproof connectors.  Unfortunately, I damaged the starter solenoid when trying to loosen the nut.  It was already flakey; I had to jump it once when buying it.
So, I shorted the solenoid with a big screwdriver, and it cranked but wouldn't fire
Assuming it was the carb I just rebuilt, I gave it a couple of shots of carb cleaner.  No luck, no spark.
I washed it while it was partially apart, I'm hoping it's not points.  It been several decades since I had to deal with them, and I don't have any matchbooks! 😉
When I install the new solenoid I'm going to pull apart all the connectors, clean, and use dielectric grease.
Lastly, it came with this issue.  The brake works, but I'm unsure how to fix this:
squonk
Take the points cover off and try drying the points. I've had the points get wet even with a good gasket and grommet. A few shots with a blow gun and it fires right up.
