Red Stallion 85 #23026 Posted yesterday at 06:41 AM On 2/24/2025 at 2:33 AM, lynnmor said: So did you make a simple puller to remove the flywheel? I got lucky with a harmonic balancer remover. Just needed to have some courage to wind it up proper. Still used the obligatory squirt with penetrant and a couple of taps to break the seal, but having said that, the taper didn't have any signs of corrosion or binding. (Which reminds me I still need to put 50ft lbs of torque on the bolt) 3 Share this post Link to post Share on other sites
953 nut 56,823 #23027 Posted yesterday at 01:10 PM 6 hours ago, Red Stallion said: I got lucky with a harmonic balancer remover. Just needed to have some courage to wind it up proper. Still used the obligatory squirt with penetrant and a couple of taps to break the seal, but having said that, the taper didn't have any signs of corrosion or binding. (Which reminds me I still need to put 50ft lbs of torque on the bolt) When removing a flywheel with a harmonic balancer puller I have found that hitting the end of the puller screw a couple times after it is under tension tends to pop the flywheel off its taper. 5 1 Share this post Link to post Share on other sites
Red Stallion 85 #23028 Posted 22 hours ago That is exactly what I did. Tension, plus penetrant, couple of love taps, more tension, time, penetrant, then rattle gun. Came off way easier than I was expecting. Unlike the clutch in my chainsaw which is truly siezed on. 1 1 Share this post Link to post Share on other sites
wallfish 17,218 #23029 Posted 20 hours ago On 2/23/2025 at 6:55 PM, TonyToro said: @TonyToro Jr. and I stripped down a Suburban. Strange. That's an RJ foot pedal and the trans arm is an RJ set up as well. I'd be interested in the foot rests, my 400 doesn't have any 1 Share this post Link to post Share on other sites
Red Stallion 85 #23030 Posted 10 hours ago Started re-assembling my 520HC enough to turn over the engine (after some noodle scratching and forgetting that thr safety switches all work now). Just ordered a new set of decal stickers to I can freshen them up once I'm finished painting. Starting to get to the fun bit now! 4 1 Share this post Link to post Share on other sites
953 nut 56,823 #23031 Posted 9 hours ago 1 hour ago, Red Stallion said: new set of decal stickers to I can freshen them up once I'm finished painting. If you are using rattle can paint be sure to let it cure for thirty days or more before applying the decals. Spray paint tends to off-gas for several weeks and would loose adhesion if covered too soon. Share this post Link to post Share on other sites
TonyToro 1,097 #23032 Posted 3 hours ago 17 hours ago, wallfish said: Strange. That's an RJ foot pedal and the trans arm is an RJ set up as well. I'd be interested in the foot rests, my 400 doesn't have any We were told it was a suburban… I’m by far an expert in the models. I’ll message you. Share this post Link to post Share on other sites
