Ed Kennell
What have you done to your Wheel Horse today?
ebinmaine
14 minutes ago, adsm08 said:
I can't fill the fluid, because I can't find the pointy bottle cap
Still technically a win if you're not mopping up the floor.
  • Haha 1
adsm08
Eh, I found it.
I think there is still air to purge because I can't get the plow the whole way up. I've found a drill is better than the engine for that though.
cleat
1 hour ago, stvski80085 said:
Still working on the mower deck. Almost all pulleys with a bearing had to be replaced. Those are now ordered. Now doing a basic paint job to stop the rust.  Want all the moving parts working as they should.  Takes a long time but by next weekend I should start putting together.
Looks great so far.
stvski80085
From  a few feet away it looks good.  Not a perfect paint job but it's a mower deck so I'm ok with it.
stvski80085
22 hours ago, dmoore said:
Last minute checks prior to big snowfall coming Wednesday evening.:greetings-clappingyellow:
She is pretty.  I want mine to look like that some day.
dmoore
I've had this C-101 (121 now) for 30 years. She's a worker that's had a little work done. Not Joan Rivers type of work but maybe Cindy Crawford:lol:
  • Haha 5
dmoore
Not enough to justify a startup.  Drive right through.
  • Haha 4
dmoore
Darn:(
  • Haha 1
  • Sad 1
Wheelhorse#1
I hooked up my plow weeks ago for nothing apparently.
  • Haha 1
953 nut
On 2/18/2025 at 7:14 PM, OutdoorEnvy said:
have some fun in the 5 degree temps and do some spin outs and figure eights!
:woohoo:
Figure skating with a Wheel Horse, I'd give that a 10.
  • Haha 3
ebinmaine
7 hours ago, Sparky said:
Got the transmission input shaft seal in (2nd attempt, destroyed the first seal :angry-banghead:)…
And now you have another reason for why I order in bulk.
:lol:
installed fuel tank supports (still waiting on my fuel tank to be shipped)..
Man I wish I knew ya needed a tank.
I only got like 9 here.
OutdoorEnvy
20 minutes ago, 953 nut said:
:woohoo:
LMAO!  I’ll take it!  I did stick the landing :lol:
  • Haha 3
Sparky
 Appreciate that…but I wanted one with a fuel sending unit so I can use the fuel gauge in the dash.
ebinmaine
One here with the mounting hole but no senders.
lynnmor
A Dorman 55818 can be used in place of the original sending unit.
Sparky
Good to know, bought a used 520 tank off FB Marketplace that hopefully works.
wallfish
10 hours ago, Sparky said:
 carefully removed a wire harness from a “doner” tractor that originally had a Magnum 10 that I will blend with the 520’s Onan harness when I land the Kohler Magnum on i
HA, Look for the magic smoke and all of the black spots after you're done when troubleshooting the wiring issues! :ychain:
After all, Sparky is your name so no doubt you'll live up to that. LOL :scared-shocked: Bring a strap so I can tow you back to base camp at the Zag show!
  • Haha 4
TonyToro
19 hours ago, Sparky said:
On my 520-8 project: Got the transmission input shaft seal in (2nd attempt, destroyed the first seal :angry-banghead:)…installed fuel tank supports (still waiting on my fuel tank to be shipped).. carefully removed a wire harness from a “doner” tractor that originally had a Magnum 10 that I will blend with the 520’s Onan harness when I land the Kohler Magnum on it.
We have a few tanks…we take them out for the pulling tractors.you could have one or all…lol
ebinmaine
I sat and scanned through the rest of the Michael Martino book this morning.
Straight from the Horses Mouth.
Found this interesting little tidbit.
  • Excellent 2
MainelyWheelhorse
@ebinmaine It must have been in Portland or down that way as I don’t recognize any of the restaurants as being in Waterville or Augusta. But it did take place six years before I was born…..😁
stvski80085
Replaced a bearing and started putting back together after paint.  I ordered a new tension pulley but it’s like an inch bigger and won’t work. Was rubbing the belt wierd so in need to look for another.  Original is back on for now. New belt also.
Wheel horse 7434 I  ordered from wheel horse parts vendor but I am thinking it has a different part number then the manual.  The one they sent is too big.
Edited by stvski80085
  • Excellent 3
