702854boy 384 #22801 Posted January 19 2 minutes ago, ebinmaine said: Limited Slip Differential is very beneficial. But that would be an added benefit. Share this post Link to post Share on other sites
ebinmaine 75,740 #22802 Posted January 19 Just now, 702854boy said: We were also wanting it for the low gear selection and because more torque can really improve some things. Absolutely agreed. That's why I like my 8 speed tractors so much. 1 Share this post Link to post Share on other sites
702854boy 384 #22803 Posted January 19 How do I tell when my likeness of Wheelhorses has become an addiction? 5 Share this post Link to post Share on other sites
76c12091520h 4,002 #22804 Posted January 19 2 hours ago, 702854boy said: We have also kind of been looking for a six speed transmission to put in it but we haven't found any and the few that were at the show last year were all sold. We have both the original style and later heavier 1" hubs in stock, will come with new set screws and jamb nuts. 1 1 Share this post Link to post Share on other sites
702854boy 384 #22805 Posted January 19 1 minute ago, 76c12091520h said: We have both the original style and later heavier 1" hubs in stock, will come with new set screws and jamb nuts. We might have to look into that 1 Share this post Link to post Share on other sites
peter lena 9,556 #22806 Posted January 19 @Handy Don recently added my bush vacuum rotor weight , to rear hitch area , definitely helps with grip , just remove the hitch ball , bolt on the angle steel slide base , use the hand lever ratchet , chain hoist to lower in place , just grease the slot you are going to slide on , slight movement , makes it slide into a size to size snug fit , have same set up on my ,lawn aerators , pete wit Share this post Link to post Share on other sites
ebinmaine 75,740 #22807 Posted January 19 1 hour ago, 702854boy said: How do I tell when my likeness of Wheelhorses has become an addiction? It's. ... well if ya really need to ponder the question you're probably already there. And that's OK. We're all here to help.... Make it stronger. 4 Share this post Link to post Share on other sites
ebinmaine 75,740 #22808 Posted January 19 1 hour ago, 702854boy said: We might have to look into that Brian will treat you right. Share this post Link to post Share on other sites
Monstrosity 1,147 #22809 Posted January 19 Alright how in the world does the shoot cable go back on..... I took it apart a loooong time ago used it once with out the control on and it went horribly... Share this post Link to post Share on other sites
cleat 8,069 #22810 Posted January 19 24 minutes ago, Monstrosity said: Alright how in the world does the shoot cable go back on..... I took it apart a loooong time ago used it once with out the control on and it went horribly... This manual explains how it goes on. Snowthrower_42in_1978_OM__803737R2.pdf.pdf 1 Share this post Link to post Share on other sites
Monstrosity 1,147 #22811 Posted January 19 (edited) 52 minutes ago, cleat said: This manual explains how it goes on. Snowthrower_42in_1978_OM__803737R2.pdf.pdf 1.82 MB · 0 downloads Edited January 19 by Monstrosity Mistake Share this post Link to post Share on other sites
Sparky-(Admin) 23,986 #22812 Posted January 19 Still waiting for a couple transmission seals to show up. Got bored so I bolted up one ag tire..yeah, I’m that bored 7 1 4 Share this post Link to post Share on other sites
Monstrosity 1,147 #22813 Posted January 19 50 minutes ago, cleat said: This manual explains how it goes on. Snowthrower_42in_1978_OM__803737R2.pdf.pdf 1.82 MB · 1 download I retract my last post I apologize i did not see this page 2 Share this post Link to post Share on other sites
Handy Don 15,171 #22814 Posted January 19 2 hours ago, peter lena said: @Handy Don recently added my bush vacuum rotor weight , to rear hitch area , I don’t have any real hills to plow and the whole plowing thing is an experiment anyway so I'm not inclined to add weight at the frame yet. I just put on the chains (2-link). If, after some trial runs this winter, it looks like extra weight will be needed, I’ll either fill the tires or put weights in the wheels (or both). Share this post Link to post Share on other sites
702854boy 384 #22815 Posted January 20 On 3/2/2019 at 6:33 AM, 953 nut said: SIZE GALLONS Per Tire WEIGHT in POUNDS 16x6.50-8 2.0 21.4 18x7.00-8 3.0 32.1 18x8.50-8 3.4 36.4 18x9.50-8 4.0 42.8 23x8.50-12 5.5 58.9 23x10.50-12 6.8 72.8 6-12 3.6 38.5 Do you know how much would fit in a 4.00-8 tire? Share this post Link to post Share on other sites
midpack 1,073 #22816 Posted January 20 I managed to fix the actuator switch on the electric lift on my snowblower machine. When I was prepping the machine for the storm we're having the toggle switch decided not to work in the "up" direction. I disassembled the switch, cleaned the contacts, reassembled it, plugged it in and viola! I always thought the original switches were hard to find and expensive if they gave out, but they're really pretty simple to repair 7 2 Share this post Link to post Share on other sites
Pullstart 68,521 #22817 Posted January 20 So, I have a couple buddies and once in a while we do stupid things. We are, for lack of better descriptive words, the Dumb Chickens. 2 1 Share this post Link to post Share on other sites
Handy Don 15,171 #22818 Posted January 20 Made it go out in the cold and plow snow for the first time in my possession! The “revived” BD-4263 blade did just fine although I can see that I’ll definitely want to remove the slop in the pivot quadrant come springtime. The weight of one “large tall” operator plus the chains was plenty adequate and there was no lack of oomph to push aside 6” of dense (but not wet) snow. 0D2A13BB-E6FA-46E2-B042-88430FE52C27.heic 4 5 Share this post Link to post Share on other sites
MainelyWheelhorse 2,246 #22819 Posted January 20 (edited) On 1/19/2025 at 12:37 PM, 702854boy said: How do I tell when my likeness of Wheelhorses has become an addiction? When it nears this….😁 Edited January 20 by MainelyWheelhorse 3 1 2 Share this post Link to post Share on other sites
c-series don 10,777 #22820 Posted January 20 On 1/19/2025 at 12:37 PM, 702854boy said: How do I tell when my likeness of Wheelhorses has become an addiction? When your yard looks like this 2 7 5 Share this post Link to post Share on other sites
Bill D 2,442 #22821 Posted January 20 Or your shed looks like this. This is an old picture, it's worse now 1 7 1 2 Share this post Link to post Share on other sites
kpinnc 16,183 #22822 Posted January 20 On 1/19/2025 at 12:37 PM, 702854boy said: How do I tell when my likeness of Wheelhorses has become an addiction? If you're asking, it's too late. 5 Share this post Link to post Share on other sites
Bar Nuthin 1,810 #22823 Posted January 20 On 1/19/2025 at 12:37 PM, 702854boy said: How do I tell when my likeness of Wheelhorses has become an addiction? When someone posts this in one your threads. 5 Share this post Link to post Share on other sites
SylvanLakeWH 29,813 #22824 Posted January 20 On 1/19/2025 at 12:37 PM, 702854boy said: How do I tell when my likeness of Wheelhorses has become an addiction? Uhm... I'm told... When you use your neighbor's garage to "store" 's... 1 6 Share this post Link to post Share on other sites
ebinmaine 75,740 #22825 Posted January 20 (edited) @702854boy Did any of the 647 answers above narrow down your question? Here on our acreage Trina and I started out with a B80 for me back in late 2016. Soon after she got a 657. From then it was a fast rolling downhill snowball effect. At this point she has 5 tractors, I have at least 9 (I honestly don't know) and we share one. The Wally Digger Backhoe. Addiction? Nehhh..... Edited January 20 by ebinmaine Correct autocorrect 1 6 Share this post Link to post Share on other sites
